Chris Stevens 2 | 08/05/2022 17:47:11 |
2 forum posts | I wonder if there is anyone close to Southampton, who might be able to help with milling SOHC Honda cylinder heads, to accept camshafts fitted with a bearing, rather than running directly in the head? Have a few I need doing, and could be more in future. TIA to anyone who responds to this. |
Chris Evans 6 | 08/05/2022 19:45:05 |
![]() 2057 forum posts | I can't help being up in the midlands but are we looking at car or motorcycle application ? |
Chris Stevens 2 | 08/05/2022 19:59:28 |
2 forum posts | Single cylinder Honda motorcycle engines, Chris. Wear is very common on these heads, but as most check them without releasing tension on the cam chain, the play/wear doesn't get detected that often. |
John ATTLEE | 09/05/2022 10:02:24 |
24 forum posts | I am between Petersfield and Portsmouth. I have a Victoria U2 milling machine. Why not make some tooling (which might need a milling machine) and line bore using a lathe with the line boring tool running between centres and the tooling replacing the compound slide? That should keep the set up time down. Happy to chat on 'phone. John |
