Gearbox splines internal and external
Col2107/05/2022 18:22:54
14 forum posts
4 photos
Hi there
Ive got an external splined shaft that’s stripped the splines. Was thinking to machine a new spline shaft but would it have to be hardened after machining. It’s about 100mm diameter by about 150mm long about 30ish splines. Also the hub splines it locates into has stripped about 5 splines of it. What type of welding rod would one use to build back up to remachine.
SillyOldDuffer08/05/2022 18:34:33
8672 forum posts
1961 photos
I don't know! The late, great John Stevenson did this sort of work but it's out of my league. Anyone else into repairing splines?
Clive Foster08/05/2022 19:48:06
3135 forum posts
109 photos
Google is probably your friend here.
Did a quick search with building up splines with weld as the text and got a number of useful hits from reliable sites
Only one I looked at was a thread on the MIG Welding Forum titled Spline Repair. Nice thing about MIG Welding Forum is that its UK based and (usually) doesn't call out anything uber hard to get over here.
Start Quote from one reply
You don’t want to use anything too exotic like SuperMissileWeld which is basically just a jumped up nickel rod.
Either 309/312 if you think the original shaft is a hardenable material.
Or just go right ahead and weld it with ER70s2 TIG or 7018 stick
End quote
Edited By Clive Foster on 08/05/2022 19:48:51
John ATTLEE08/05/2022 19:58:40
23 forum posts
What machine is it for and do you know what caused it to fail. Is the hardening to resist the wear or to increase the strength? How come only five internal splines are stripped? I would have expected it to be all or none! Is the shaft 150 mm long or is that just the length of the splines? How long are the internal splines? What is the form of the spines?
Hopper08/05/2022 23:56:04
6388 forum posts
334 photos
Driveshaft for a 10 ton truck? Or agitator drive for a washing machine? Could make a difference with rod choice.
duncan webster09/05/2022 00:54:14
3984 forum posts
65 photos
If a new one would have to be hardened after machining, so would a built up one. At least with new material you know what it is, what it's current state is, and how to harden/temper it
Bill Davies 209/05/2022 13:46:39
283 forum posts
11 photos
Col21, since there are a lot of splines, I guess they are vee or involute, probably the latter as these can be hobbed like gears.
So, if you plan to machine one, you might check for curved teeth.
Bill
Rapid RC
Dreweatts
