Tristan Luscombe | 04/05/2022 09:41:02 |
21 forum posts 7 photos | Hello everyone,
I had such fantastic responses to my thread on the Senior Milling Machine that naturally my first thought was to ask here again with my next quandry. Our DT department has had a Warco GH-1322 lathe (affectionately known as 'Big Green' ) in the department for as long as anyone can remember. Legend has it that it came from another school, but it has never been hooked up to the power let alone used. Anyway, being a good 50 years newer than the next youngest lathe I decided it would be an idea to get our service partner to wire it to the three phase when they were doing their annual check last week and so I've spent the last couple of days playing with it. My assumption (I know, I know) was that as a 'new' lathe in the UK it would naturally come with Metric threading gears, but my attempt to follow the chart on the gearbox to produce threads of a given pitch failed. I took the gear cover off and checked and instead of the 42-127-120-42 gear series that I believe it ought to have for Metric threads it has 32-85-100. According to the chart this appears to be for mm/r instead. This is a notation I haven't encountered before. Does anyone know what this is for, if there is a way to get this to cut 'usual' threads like M10x1.5 or if there is a way to still get alternative change gears for this lathe? I'm very aware that this is stuff I 'should' know, but my experience with lathes was from a long long time ago and it was using them, not setting them up, so I apologise for any exasperated eye-rolling my cluelessness may be causing.
Thanks folks! Edited By Tristan Luscombe on 04/05/2022 09:41:59 |
Thor 🇳🇴 | 04/05/2022 10:01:27 |
![]() 1632 forum posts 46 photos | Hi Tristan, Are you sure you are looking at threading? To me, mm/revolution sounds like you are looking at the feed chart. Thor |
JasonB | 04/05/2022 10:03:16 |
![]() Moderator 22764 forum posts 2656 photos 1 articles | That chart is for carriage and cross slide feed rates not gear cutting. There should be another chart for screw cutting You want to be looking at the top third of the chart shown on page 13 (12 actual) of the manual for metric and imperial threads, Module and DP in the middle are seldom used and the feeds you show are at the bottom. Edited By JasonB on 04/05/2022 10:09:56 |
John P | 04/05/2022 10:08:18 |
407 forum posts 259 photos | Hi the plate you have shown is the lathe feed chart. In this video there should be above this at 1.03 minutes shows the listings for pitch. TPI ,module and DP.
Tristan Luscombe | 04/05/2022 10:20:27 |
21 forum posts 7 photos | Hi Thor, It's entirely possible. The only reason I was looking at that chart was that it's the only one that has the same three gears that I found within the gearbox. The other charts (Pitch, TPI, Module and DP) all have four gears of varying sizes. For reference, I was looking at the gears at the far left of the headstock, the only ones readily accessible without dismantling the whole thing as far as I can see. |
Thor 🇳🇴 | 04/05/2022 10:33:23 |
![]() 1632 forum posts 46 photos | Hi Tristan, The Warco 1322 with 32-85-100 gears are the setup used for metric feeds. It should be possible to remove those gears and replace them with others. The 42-127-120-42 combination of gears you give in your first post is for metric threading, other gears are needed for imperial threading as given in the manual Jason linked to. You should have a collection of change-gears for the lathe. Thor |
Tristan Luscombe | 04/05/2022 10:55:56 |
I see quite a few people responded while I was replying to Thor, thank you everyone! Sadly it doesn't look as though we got any more gears with this lathe, only a couple of faceplates so I'll have to see if I can find a Metric set online and hope the school will splash out on them as I really wanted to show the students screwcutting on the lathe as an alternative to the tap and die sets they usually use. Thanks again to everyone for your help, at least I wasn't missing something obvious.
Cheers! Tristan. |
Martin Connelly | 04/05/2022 11:19:49 |
![]() 2137 forum posts 222 photos | I suggest looking at this Grizzly manual for their G9036 lathe which I think is the same as yours but as usual Grizzly have far better manuals than seem to be supplied in the UK. Martin C |
Tristan Luscombe | 04/05/2022 11:29:16 |
21 forum posts 7 photos | Thanks Martin, that manual is orders of magnitude better than the manual from Warco! Brilliant! |
peak4 | 04/05/2022 12:25:29 |
![]() 1714 forum posts 183 photos | Tristan, just a quick warning that there might be slight differences between the Grizzly and Warco manuals, though the lathe is essentially the same. |
Tristan Luscombe | 04/05/2022 12:40:31 |
21 forum posts 7 photos | Thanks Bill, I'll be sure to keep my eyes peeled for any anomalies between the two. For some reason I vaguely had the notion that Warco were no longer trading in the UK, but I did a search and found them and I've sent them a query about accessories and spares. No-one on the staff was here at the time this lathe arrived, so no-one knows if it came with anything else. I suspect I would have clocked a spare set of gears laying around in the time I've been here. Still, never say never, I do occasionally unearth treasurein the depths of the stock room! |
JasonB | 04/05/2022 13:05:59 |
![]() Moderator 22764 forum posts 2656 photos 1 articles | Does the school have any 3D printers? You could print some of the missing gears and provided you don't get too greedy with depth of cut they will do to cut some threads for yourself as well as showing the students. Most CAD packages have a gear drawing function so should be easy enough to produce a file to print, thickness and bore can be measured from the other gears as well as using them to calculate the MOD size of the teeth. |
DC31k | 04/05/2022 13:14:55 |
687 forum posts 2 photos | Posted by Thor 🇳🇴 on 04/05/2022 10:33:23:
The 42-127-120-42 combination of gears you give in your first post is for metric threading... If the standard chart on the machine gives the feeds in mm per revolution, that suggests to me that it a native metric machine. Why would you need a 127 gear to do metric threads on a metric machine? Looking in the manual that Jason linked to, the 127 gear is shown behind the 120 gear when metric threading, so is not in mesh with anything. In addition, the 120 gear is only an idler between the two 42t gears, so the ratio is 1:1. So, if the OP only wants to cut metric threads, he absolutely will not need the four gears above. Depending on the physical layout of the lathe and adjustment possible on the banjo, it may be possible to buy just a single 32t gear and use the 100t as an idler. If not, a pair of gears of identical but larger tooth count would do. Edit: look for a piece of software called GearDXF if you want to go the 3DP route. Edited By DC31k on 04/05/2022 13:15:59 |
Calum Galleitch | 04/05/2022 13:42:48 |
![]() 191 forum posts 65 photos | Posted by DC31k on 04/05/2022 13:14:55:
Why would you need a 127 gear to do metric threads on a metric machine? I'd guess it was listed as such to act as a spacer. Tristan, it's worth looking at your chart and thinking carefully about what's physically going on, because there's often different ways of doing something when it comes to the change gears. My lathe for example lists a specific setup for most metric pitches, one of the gears for which I don't have (my lathe also came from a school and arrived without the other changewheels...some kind of vortex, perhaps). However, close inspection reveals the "missing" gear is just an idler, so can be replaced with any gear that can be made to fit. It's also worth figuring out what the calculation is to derive the thread pitch, as once you have that you can then work backwards and invent your own change wheel combinations. |
Tristan Luscombe | 04/05/2022 13:48:35 |
21 forum posts 7 photos | What an interesting thought, we do have a couple of 3d printers, I never imagined you could print a gear that would be robust enough to function in a lathe! Ooooh... I will have to look in to that! Thank you DC31K, it hadn't occurred to me that not all those gears would be engaged, you make an excellent point! |
Tristan Luscombe | 04/05/2022 14:00:07 |
21 forum posts 7 photos | Another thought occurs to me, does anyone have any recommendations for a quick change toolpost that might be suitable for this lathe? I intend to upgrade all the department lathes to them eventually but this would be a good place to start. Thanks again for everyone's input, by the way |
peak4 | 04/05/2022 14:22:57 |
![]() 1714 forum posts 183 photos | Posted by Tristan Luscombe on 04/05/2022 14:00:07:
Another thought occurs to me, does anyone have any recommendations for a quick change toolpost that might be suitable for this lathe? I intend to upgrade all the department lathes to them eventually but this would be a good place to start. Thanks again for everyone's input, by the way Mine has the Warco version of the 250-200, which is the piston locking style of dovetail toolpost. (top right on the link. https://www.warco.co.uk/2926-quick-change-tool-posts p.s. you may find that Toolco's closing down sale will include the gears you need. Edited By peak4 on 04/05/2022 14:47:00 |
Tristan Luscombe | 04/05/2022 14:38:23 |
21 forum posts 7 photos | Fantastic, thanks Bill! |
DC31k | 04/05/2022 18:53:07 |
687 forum posts 2 photos | The spirit of John Stevenson came upon me and reminded me what he did with his Bantam: he removed the change gears altogether and replaced with a toothed belt and pulleys. On the machine in this thread, you would just have to measure the pulley centres and choose a combination of belt size and tooth count to suit that distance. |
not done it yet | 04/05/2022 19:13:31 |
6812 forum posts 20 photos | I would not (but a school might) buy a set such as shown. I would buy only the tool post and, say, three tool holders, initially. I bought a full set when I bought mine and have regretted it🙂 . You give no indication of your locality/area. Arceurotrade, near Leicester, are a very much favoured (by the forum) supplier for all sorts of machinery and accessories. Ian is a very helpful and knowledgeable person to speak to. Likely better prices than some other suppliers for the same or similar items, as well. |
