Harrison M300 advice
Dougie Swan26/04/2022 08:56:21
235 forum posts
53 photos
Hi
I have a Harrison M300 lathe and th project I'm working on requires a part to be bored between centres
The crosslide doesn't have any t slots but has v groves along its side
Are there any attachments available so that I can clamp an angle plate to it?
Thanks
Dougie
KWIL26/04/2022 10:19:11
3554 forum posts
70 photos
Here is one example. Copy of Harrison clamp on design (from Harrison M300 Manual) with a 7.25 Black 5 cylinder being bored between centres.
Highlander/Black5 SteamValve
steamdave26/04/2022 11:41:20
511 forum posts
44 photos
Here's an auxiliary boring table that I made for my M300. Clamps to the cross slide with wedge blocks as per Harrison's design. Plate was ex 12mm and screw holes are M10.
The Emerald Isle
Andrew Johnston26/04/2022 12:33:23
6602 forum posts
701 photos
I made a plate similar to that by 'steamdave' from hot rolled steel for my hydraulic copy unit:
I've never seen a similar commericlal item.
Dougie Swan26/04/2022 15:25:22
235 forum posts
53 photos
Thanks for the replies
Dave, can you send me pictures of the clamps?
Dougie
steamdave26/04/2022 20:50:39
511 forum posts
44 photos
Dougie
This is the best I can do. I sold the lathe a couple of years ago.
From memory, the angle of the V is 70 degrees, but you had better check it!
The Emerald Isle
Dougie Swan26/04/2022 21:37:36
235 forum posts
53 photos
Thanks Dave
That makes sense now
That helps a lot
Dougie
Dreweatts
Rapid RC
