Sherline lathe
Mini locking levers
geoff walker 122/04/2022 16:12:15
487 forum posts
187 photos
Just received some mini locking levers from the far east.
Installed one on the tailstock and one on the cross slide stop.
Really pleased with them, I would guess most sherline users get fed up reaching for the tee key and I'm no exception.
5mm thread so you need to re thread with 5mm tap.
Got them off ali express at jadkinsta official store, cheap as chips, £2.38 for the two.20220422_154051.jpg
Geoff
ega22/04/2022 17:37:12
2543 forum posts
201 photos
Thanks for the tip. They look similar to those supplied by Eccentric Engineering with their Acute sharpening kit.
BTW, is your lathe sitting on Blu Tack?
geoff walker 122/04/2022 18:52:07
487 forum posts
187 photos
Hi eva,
Yes they are a useful addition to the lathe.
Forgot to mention they are spring loaded around a hexagonal top so are adjustable for position.
No it may look like blue tack but it's just a cardboard cereal box base. Just felt a little compression was a good idea when mounting the lathe on the baseboard
Geoff
ega22/04/2022 22:52:44
2543 forum posts
201 photos
Geoff:
Thanks for mentioning the adjustment feature. I prefer the hexagonal top kind as it is then easy enough to substitute a threaded (or tapped) component to suit the particular application; most of these handles seem to come in metric which is not always what's wanted.
bernard towers23/04/2022 13:55:18
619 forum posts
109 photos
As it is the socket part of the handle that most people have trouble making why not buy the handles and then make the new male piece to match you lathes threads, that way not altering the lathe.
not done it yet23/04/2022 15:53:31
6812 forum posts
20 photos
Spot on, Bernard.
That is what I did on my imperial mill.
I removed the threaded part and replaced it with a rod I threaded metric on one end and imperial for the business end. Not a five minute job - but not that long to do it.
There are loads of choice on epay or ama zon for adjustable clamping/locking levers.
I bought mine from Arceuro long ago, before they stopped stocking them.
Possibly not quite as cheap, but can get them next day with Prime?
ega11/05/2022 14:58:25
2543 forum posts
201 photos
geoff walker 1:
I bought some of the adjustable handles you mentioned and have fitted one as the topslide lock on my Myford:
Obviously, they don't come in BA sizes and I opted to modify a 6mm one to 2BA. This was quite fiddly and another time I think I would make the threaded "spindle" from scratch.
The handle is aesthetically out of tune with the rest of the machine but seems to work well and, of course, this is a prime location for an adjustable handle.I have shown a dismantled handle in the photo.
geoff walker 111/05/2022 23:42:03
487 forum posts
187 photos
Hi ega,
Yes they do work well and are much better than using a tee key.
I opted to change the thread on the sherline from 10-32 to 5mm. Not a problem as the pitches are almost identical at 32 and 31.75 and the 5mm tap removes just a small amount of metal from the 3/16" 10-32 thread.
I've just bought these on ali express to fit the tool posts on the sherline. With postage tax and a £5 discount I get 4 levers for £4.01p, yes £4.01p
20220511_232554.jpggeoff
Rapid RC
Dreweatts
