Donald MacDonald 1 | 17/04/2022 15:35:19 |
50 forum posts | Hello What type of pen do you recommend to draw the finest possible lines on ordinary paper & tracing paper? Major bonus factors: Use: PS This is what I currently use: (0.05mm Uni Pin Fineliner drawing pens)
Edited By Donald MacDonald 1 on 17/04/2022 15:35:48 |
pgk pgk | 17/04/2022 16:01:44 |
2563 forum posts 293 photos | I doubt it meets your criteria,.but many moons ago I played about copying a woodcut print using a fine mapping dip-pen. It did draw very fine lines with Indian Ink but one had to check on a scrap first after any dip.
Edited By pgk pgk on 17/04/2022 16:02:06 |
old mart | 17/04/2022 16:12:16 |
3775 forum posts 233 photos | When I was working on aircraft parts manufacturing, we used Rotring pens exclusively, partly because the ink was approved for that use. They were easy to use. It would be worth checking their products. |
Speedy Builder5 | 17/04/2022 16:22:16 |
2613 forum posts 212 photos | Draw 2 x size and photo reduce to size. or these ?? You would have to test suitability and availability in the UK Edited By Speedy Builder5 on 17/04/2022 16:25:40 |
SillyOldDuffer | 17/04/2022 16:34:26 |
Moderator 8692 forum posts 1967 photos | Ordinary paper puts a severe limit on the fineness of lines because it's very porous. Best results need professional drawing paper, which eventually became sheets of plastic. Common enough when drawing boards ruled the world but I couldn't find any last time I looked. CAD may have done for it. I used Rotring and Mapping Pens. The latter, being sharp dippers, produced the thinnest lines, but I found Rotrings easier to control; constant ink flow and fewer messy accidents! From memory, my lightest Rotring pen was 0.1mm Erasing was always unsatisfactory, maybe I had the wrong ink! Dave
Dave S | 17/04/2022 16:44:08 |
370 forum posts 90 photos | Rotring are the thoroughbred horse here. There is no unicorn Dave |
HOWARDT | 17/04/2022 16:50:40 |
908 forum posts 39 photos | Draughting (drafting) film, sometimes refereed to as Mylar. Seems to be plenty about, mostly in smaller sheet sizes. In my day I am sure we used two types as well as an ammonia processed print one for modifying copies. Definitely better to produce fine lines in ink than paper based products. |
Danny M2Z | 17/04/2022 17:34:05 |
![]() 963 forum posts 2 photos | As SOD remarked, ordinary paper is a limitation. Drafting paper is good for fine work and readily available, at a cost - Drafting Papers My roll of 3M drafting Mylar was donated from a cartographer as it had reached it's 'use by date' and so shrinkage of less than 0.1% was not guaranteed beyond that point. I reasoned that if I drew my plans on it then if the shrinkage' continued at the same rate then another 20 years of life might be obtained. As for pens (none of which use erasable inks) then once again, they cost a bit but are a great investment for serious work Technical Drawing Pens I use Rotring pens for my own work as the same cartographer recommended them and donated a few. Clean the tips in an ultrasonic cleaner or they can clog up. I use this equipment to draw model aircraft plans and any mistakes may be erased/scratched out with the point of a sharp modelling knife but that section of the Mylar will no longer accept ink so it pays to get things correct the first time around. * danny *
Georgineer | 17/04/2022 17:35:47 |
577 forum posts 32 photos | I did try mapping pens (my Mum, a tracer, produced some wonderful work with them) but I'm left-handed which makes me literally a pen-pusher. On paper the straight nib caught in the fibres of the paper then broke loose with a splat. Later I used Rotring pens on tracing paper, then Rotring on mylar which is my favourite. We had tungsten carbide tipped pens because the mylar wore down ordinary pens too quickly. Later there were plastic pencil leads (permanent or erasable) for use on mylar film and they were horrible. George |
Mike Poole | 17/04/2022 17:37:23 |
![]() Moderator 3339 forum posts 73 photos | The Pilot Frixion pens can be erased by heat but 0.5mm seems to be on the large side for your requirements. Mike |
Alan Jackson | 17/04/2022 18:09:29 |
![]() 258 forum posts 146 photos | I used to use plastic leads on drawing film. By rotating the pencil as you moved it, it was quite easy to draw a fine thin line. The other trick was to push the pencil so that the lead was in compression, not bending. Alan |
JasonB | 17/04/2022 18:22:10 |
![]() Moderator 22750 forum posts 2653 photos 1 articles | Draw it in CAD, set a fine line thickness and it will come out better than a lot of pens. Added bonus is you can get your sizes to as many decimal places as you want and easy to "rub out" on the screen.
Donald MacDonald 1 | 18/04/2022 00:52:39 |
50 forum posts |
2. Are you suggesting search for "mapping pens" on Amazon?
Re Rotring/refillable Technical Drawing Pens (what we used to call Indian ink), about 20 years ago I used to own some Staelder Marsmatic Technical Pens, which I think we found to be slightly less scratchy than Rotring but both types clogged up quite quickly if not used and I also found they had to be used very vertically to the paper. So I threw mine out many years ago. That said, I see Rotring also make a "Rotring Tikky Graphic 0.10mm Black Fibre Tip Pen". However the thinnest one they make is that "0.1mm", whereas other manufacturers seem to much thinner (?).
Maybe they mean the line thickness...(??)
Or what about the "Art-n-Fly FineLine Drawing Pens" which have an "Ultra Fine Tip 003" - and claim to draw a "0.15mm" line, which claims to use Archival Japanese Ink, which they claim work well on non-porous surface and "won't feather or bleed through most papers" Edited By Donald MacDonald 1 on 18/04/2022 00:54:38 |
Bill Pudney | 18/04/2022 03:22:35 |
611 forum posts 24 photos | I started to use a email, but this super page disappeared. So this will be a shorter. As Jason used ...get a CAD As I used, use mylar, tracing paper is fine with pencils, mylar is much better for drafting Treat yourself to a Rotring 0.10mm, and a decent quality of ink to use on mylar film. If you are seriously hoping to use some sort of felt pin, look for Unicorns cheers Bill |
Michael Gilligan | 18/04/2022 06:03:42 |
![]() 20182 forum posts 1053 photos | Posted by Donald MacDonald 1 on 17/04/2022 15:35:19:
Hello […] PS This is what I currently use: (0.05mm Uni Pin Fineliner drawing pens) . I am intrigued … and will be trying that one for myself ! [ it looks promising for writing on microscope slide labels ] What width, and quality, of line does it actually produce on ‘ordinary paper’ ? … a photo would be appreciated, if you can provide one MichaelG. . Edit: Unfortunately, this is the most informative page I have found so far: https://www.bunbougu.com.au/blogs/blog/uni-pin-fineliner-introduction
Edited By Michael Gilligan on 18/04/2022 06:19:51 |
Speedy Builder5 | 18/04/2022 06:41:22 |
2613 forum posts 212 photos | Uni Pin Fineliner do a 0.1mm pen - however Amazon uk show a search error at the moment. Otherwise try feeding a spider on black ink ? |
JasonB | 18/04/2022 07:31:39 |
![]() Moderator 22750 forum posts 2653 photos 1 articles | Posted by Donald MacDonald 1 on 18/04/2022 00:52:39:
Now you have moved the goalpost from wanting the pens to draw on paper and tracing paper to wanting to write on all manner of surfaces, many of which are muck more porous and open fibred than your original requirement. Suggest you use different pend for this particularly if you go down the tubular tip route. Having spent 20 years in the Graphic and fine art retail trade I have all the types of pens mentioned and know a fair bit about them but if I needed to draw something that fine onto paper or tracing these days would not reach for a pen. The best white paper to use pen on is /was Frisk's CS10 which was a smooth white and had china clay in it but I don't think they make it now (lack of demand due to computers) Edited By JasonB on 18/04/2022 07:32:03 |
Michael Gilligan | 18/04/2022 07:42:49 |
![]() 20182 forum posts 1053 photos | Posted by Donald MacDonald 1 on 18/04/2022 00:52:39:
MichaelG. . Edit: __ Lots of guff here, but nothing technical: https://uniball.co.uk/wp-content/uploads/2021/11/Positively-Pin.pdf Edited By Michael Gilligan on 18/04/2022 07:57:06 |
Michael Gilligan | 18/04/2022 08:08:27 |
![]() 20182 forum posts 1053 photos | This seems to be a reasonable overview of available ‘ineliners: **LINK** https://www.pullingers.com/what-is-the-best-fineliner-pen MichaelG. |
JasonB | 18/04/2022 08:10:27 |
![]() Moderator 22750 forum posts 2653 photos 1 articles | Yes just goes to show that technical drawing is not done with pens these days. Michael. if you happened to have time it would be interesting if you could "measure" the line as you have done for other detailed items in the past. This is a quick freehand drawn line on photo copy paper using a 0.1mm Pilot DR pen. The "size" of many pens sold is often based on the diameter of one of the components of the nib not the line it will produce as there are so many variables such as paper, pressure applied, angle pen is held at, speed pen moved at, etc |
