peak4 | 10/04/2022 13:51:10 |
![]() 1712 forum posts 183 photos | Another query for the hive mind. |
Andy_G | 11/04/2022 18:21:37 |
![]() 173 forum posts | We used to use them a lot at work (some LED, but mostly LCD) - They were branded Cadar though. I don't remember there being anything special about the on/off switch. It's a while ago, but I'm pretty sure that they charged whether off or on, and could work off the charger if the battery was flat. They often used to be plugged in to the charger 24/7 which tended to kill the batteries after a few years (you only found out if you tried to take one away to use elsewhere - which it sounds like what has happened to yours). I replaced the batteries in a number of them - they are just a stack of NiCad coin cells inside the end cover; easy enough to change. (4.8V from memory, but don't trust that). I *think* that the LCD ones may have had a serial interface and clicking on the thumb button sent the reading to whatever was plugged into the other end. They were very rugged and dependable for such accurate instruments - and they held their accuracy extremely well, even in a shiftwork production environment. Edited By Andy_G on 11/04/2022 18:22:42 |
peak4 | 11/04/2022 21:35:59 |
![]() 1712 forum posts 183 photos | Thanks Andy, it's not that the on/off switch is special; it's just a conventional microswitch, with the NO terminal cut off. |
peak4 | 11/04/2022 21:38:06 |
![]() 1712 forum posts 183 photos | There's a thread or two on Vintage Radio Net about them if anyone's interested. |
Steven Corston | 19/05/2022 22:47:52 |
8 forum posts | I have only just found this thread so hope this reply isn't too late. On the LED M&W micro 2000's the on/off switch is the sliding switch on top. Yellow for the mm ones and red for the inch ones. The Cadar LCD ones have a very similar design BUT the top sliding switch is a measurement hold switch, either just press it to hold the measurement or slide it forwards to hold the measurement. to turn on press and hold the Z (left hand) button, once the micrometer is turned on a momentary press will zero the display. (provided the hold function isn't on) The S button (right hand) changes between mm and inch. The C button (middle) ???? it lights up a letter C at the bottom of the display but I can't remember what it's function is. I never used it. Hope this helps. Steve |
Steven Corston | 19/05/2022 22:50:16 |
8 forum posts | Forgot to say that the Cadar ones turn off automatically after a period of being idle. |
peak4 | 19/05/2022 23:24:38 |
![]() 1712 forum posts 183 photos | Posted by Steven Corston on 19/05/2022 22:50:16:
Forgot to say that the Cadar ones turn off automatically after a period of being idle. Thanks Steve, this explains much of my confusion. |
Steven Corston | 20/05/2022 10:57:07 |
8 forum posts | Bill, That may well be your problem with the battery flattening. I last charged mine in February, it has been sat on a shelf out of use since then and has held it's charge. Provided your battery isn't duff yours should be the same. My LED ones only hold their charge for a month or so. Steve |
peak4 | 20/05/2022 12:15:16 |
![]() 1712 forum posts 183 photos | Posted by Steven Corston on 20/05/2022 10:57:07:
Bill, That may well be your problem with the battery flattening. I last charged mine in February, it has been sat on a shelf out of use since then and has held it's charge. Provided your battery isn't duff yours should be the same. My LED ones only hold their charge for a month or so. Steve I wonder if that may be down to battery technology? |
Steven Corston | 20/05/2022 15:45:12 |
8 forum posts | Playing with mine today I discovered that pressing the Z button twice quickly turns it off. I have always just left it to turn itself off though. Maybe I should have read the instruction manual 40 years ago! Or if I did I should have remembered it. |
