0-6-0 pannier tank
JACK SIDEBOTHAM | 08/04/2022 09:26:28 |
14 forum posts | Hello all,l am working on the lbsc pansy as redesigned by doug hewson,can anyone confirm the hole sizes in the frames??,as far as l can see only a few holes are actually given a size on the drawings,l am guessing at No43/8ba for the stretchers but if anyone has or is building this engine and can offer guidance l would be very grateful |
Neil Rimmer 1 | 08/04/2022 09:33:08 |
8 forum posts | I am building the Doug Hewson Pansy, I have used 8 BA for the buffer beam brackets, brake hangers, platform support, tank supports, there is a lot of 8BA in the frames. The cylinder and strechers, I used 3 mm countersink hex socket bolts, and filled them. felt theses needed a bit more strength. |
JACK SIDEBOTHAM | 15/05/2022 17:16:30 |
14 forum posts | Hi all,l am having a problem with the drag box on doug hewsons PANSY,the drawings only show one side section view,with no reference to drag hook mounting,or whether it has a top and bottom plate,l am guessing that it does,but if anyone knows for sure it would be much appreciated,thanks,jack. |
