Georgineer | 31/03/2022 10:36:50 |
589 forum posts 33 photos | Posted by HOWARDT on 30/03/2022 20:54:51:
Many years ago built my own kitchen cupboards, chipboard doors covered with Formica fixed with Evostick contact adhesive. Never came off while I lived with it, moved after ten years. Dad used Formica stuck down with Evostik in Mum's kitchen in 1966. It was still all firmly fixed when we sold the house in 2005. Nobody seems to have mentioned thixotropic cements like Thixofix and Timebond. They are similar to Evostik but are more forgiving of accidental touch-downs. George |
JasonB | 31/03/2022 10:38:14 |
![]() Moderator 22999 forum posts 2757 photos 1 articles | Posted by Hopper on 31/03/2022 09:11:31:
Posted by Donald MacDonald 1 on 31/03/2022 00:10:40:
Yes I am bonding 2 large 100cm x 100cm sheets of Melamine Faced MDF. I am wanting to create a rigid work surface that is as flat as possible. Most of the time it will be used on a table but under a cutting mats.
So why not make life easy and use a piece of readily purchased MDF board with Melamine already glued on both sides in the factory? He has melamine faced board which I've only ever seen coated on both sides, if it were one sides it would not be balanced and warp all over the place. I use it regularly and often buy in a ton at a time. OP would need to buy a belt sander to remove the LPL and as he wants a flat surface would need to be very carful to no sand to different depths, really wants a thickness sander to do it properly. |
Circlip | 31/03/2022 10:57:16 |
1521 forum posts | Yep, kitchen worktop, 32mm thick available but 1000mm wide? Regards Ian. |
Hopper | 31/03/2022 11:11:23 |
![]() 6603 forum posts 345 photos | Bit of plywood would be good enough to throw a cutting mat on top of. Comes any size you want pretty much. |
JasonB | 31/03/2022 11:19:59 |
![]() Moderator 22999 forum posts 2757 photos 1 articles | 900 x 2000 breakfast bar would come close if you went the worktop route but you would have to buy the whole 2m length Melamine or Laminate top is nice if you are glueing up on it as it is easier to wipe off excess glue |
Tim Stevens | 31/03/2022 12:20:09 |
![]() 1616 forum posts | One factor which needs to be considered, too, is the range of conditions in which the bonded parts will exist. Several clever adhesives are modified (or destroyed) by heat or cold, vibration, or by solvents, including everyday cleaning chemicals. Advice offered in the absence of detail like this may be nugatory. Or worse. Cheers, Tim |
larry phelan 1 | 31/03/2022 12:58:59 |
1190 forum posts 15 photos | The glue I used years ago was called "Cascamite", and it did exactly what it said on the tin [or sack, in my case ] I t was cheap, simple to use, and never failed. I used it to bond plastic laminate to chipboard and mdf board and for wood -to-wood joints. For sheet work, I used a rubber roller, being faster and giving a better spread. Dont know if it is still around, I no longer do that work, but it might be worth looking into. As I remember, it was made by Borden Chemical Co. Might not be what you are seeking, but worth a try. |
Donald MacDonald 1 | 31/03/2022 13:34:43 |
50 forum posts | No, Hopper, the whole point is that my sheets of MDF already come with melamine glued to both sides. And that is why I am needing to bond melamine to melamine. Single sided would warp all over the place, with every change in atmospheric temperature & moisture.
...and it is 18mm thick and A0 sized and on the table I have it flexes just enough to be annoying.
A lot of glues would work if only ONE side is plastic. "Cascamite" is a "Powdered urea/formaldehyde resin glue" so sounds like a powder which is activate by adding water. It sounds brilliant. But I am keen if possible to use up some of my existing glues of which I now have quite a collection. If my 2 tubes of J-B weld aren't going to be enough, maybe I'll just us some epoxy resin glue. |
JasonB | 31/03/2022 13:59:37 |
![]() Moderator 22999 forum posts 2757 photos 1 articles | Another option would be Cyano, 50ml bottle of one of the "mitre" adhesives or bottle of ZAP would be enough to run a continuous straight bead every 50mm, don't do circles as you will bet air trapped. You would not need the activator. I've used it enough times to stick various trims to MFC and NFMDF and it usually pulls the thin melamine layer off the substrate if you try and pull them apart |
Dave S | 31/03/2022 15:31:39 |
373 forum posts 90 photos | If 3/4” dual faced mdf flexes annoyingly on the current table I would suggest the current table is likely to be the issue. Dave |
Grindstone Cowboy | 31/03/2022 16:36:21 |
892 forum posts 64 photos | Agree with Dave S. Like a building, it's only going to be as good as the foundations. (Waits for someone to come up with an example that disproves it... Rob |
not done it yet | 31/03/2022 16:51:50 |
6874 forum posts 20 photos | KISS Principle. Screw them together? |
Donald MacDonald 1 | 31/03/2022 19:02:00 |
50 forum posts | Posted by not done it yet on 31/03/2022 16:51:50:
KISS Principle. Screw them together? Buying a new table is definitely not KISS! Don
Frances IoM | 31/03/2022 19:28:53 |
1280 forum posts 28 photos | can you screw from underneath ? or is the intention to turn it over when you have badly scored one side. If 16mm backed MDF flexes then you need to apply less pressure or strengthen the base - sounds as tho you are trying to work on a folding card table. |
Hopper | 01/04/2022 07:24:55 |
![]() 6603 forum posts 345 photos | I agree with Frances above ^^^^^ It seems like way overkill or overthinking on gluing two pieces of board together in order to create a surface on top of an existing bench for the very simple purpose of resting a cutting mat. If it is this difficult -- two pages of forum discussion with not one suggestion being "just right" -- something is wrong at basic principles level. Edited By Hopper on 01/04/2022 07:30:17 |
Ramon Wilson | 01/04/2022 08:02:35 |
![]() 1379 forum posts 425 photos | It seems to me that the use of JB Weld in this situation is rather a waste of the product. The thing to bear in mind once this gluing of two surfaces together - to provide a flat one - is the inability to part them if it does warp. Not suggesting it will but am saying it might - too late then. NDIY's and others suggestion of screwing is to me the most logical. Correctly done the screws can be equally spaced to ensure even pressure across the area and the heads countersunk enough to either be flush or filled over. The original poster does say that for most of the time it will be used under cutting matts so screws shouldn't be an issue. The environment would appear to present a challenge with -5 to + 40 and relevant humidity changes - another thing to be considered. I have in my workshop a very flat bench top - MDF on top of MDF on top of Chipboard - all screwed together. It is checked for flatness and warpage each time I build a model - so far the stability has remained since I placed the last layer on
As always the pics are to assist the recommendation but what I do does require an absolutely flat working surface - the above has proved admirably successful for me. Someone suggests this is probably being over thought, yes the question was about which glue type to use but it's time to think outside the envelope perhaps.
Regards - Tug
Edited By Ramon Wilson on 01/04/2022 08:04:11 Edited By Ramon Wilson on 01/04/2022 08:11:55 |
Hopper | 01/04/2022 08:19:19 |
![]() 6603 forum posts 345 photos | Ramon - not overthinking at all for your purposes where you are using it as a jig/fixture base for building large complex structures that must be dead flat/straight/true, such as airfoil sections as shown. But for resting a cutting mat as the OP describes -- not so much. |
Ramon Wilson | 01/04/2022 08:39:06 |
![]() 1379 forum posts 425 photos | Hi Hopper, Maybe so but the principle's the same - the object is to get two pieces of board together to provide a flat surface without it warping or delaminating. My approach is on the basis of once bonded it's bonded - if a warp does then ensue it rather defeats the object - atmospheric conditions can, and will, play a part in trying to do what you want to prevent.. FWIW all the MDF two layer bases I make for my plastic models are screwed together for the same reason but - 'yer pays yer' money etc. Tug |
Hopper | 01/04/2022 09:47:38 |
![]() 6603 forum posts 345 photos | Yes indeed good from that point of view. And as you say, screw holes could be filled with bog and filed/sanded down flat, What kind of screws work best in MDF though? Ordinary wood screws? Chipboard screws? Or are there special MDF screws? |
Ramon Wilson | 01/04/2022 10:14:59 |
![]() 1379 forum posts 425 photos | I use basic 'Screwfix' silver screws but I'm sure any 'modern' parallel thread screw would do. I would think an acrylic filler for the melamine surface would be best. If done with care they would be hard pushed to see let alone feel. T
