Murad Cadet Restoration Project
Xed21/03/2022 19:14:51
18 forum posts
75 photos
Hello! I recently acquired a Murad Cadet benchtop lathe that will eventually take over from my unbranded Chinese minilathe for general tinkering. I couldn't find a huge amount of information online about them other than the lathes.co.uk page so I thought I'd document my attempts at a restoration project here. It's also my first attempt at trying to restore something that isn't just a small hand tool, so I'm looking forward to getting stuck in.
Murad Cadet unloaded
It's my first time dealing with a machine this substantial, but the seller kindly helped unload it onto the rolling bench. As you can see it arrived with a coat of rust on the machine surfaces.
Cadet headstock gearing
A look under the headstock cover and all the gearing seems in good condition from what I can tell - I might just leave it at changing the oil for the headstock internals but we'll cross that bridge when we come to it.
Nameplate
Obligatory nameplate shot.
Some of the tooling
Some of the tooling that came with the lathe - a full set of change gears and an interesting dividing/indexing attachment as well as what I'm presuming is a milling attachment. There was also a huge amount of drills and cutter (not picture) that sadly look like they've spent a couple of years sat in a tin full of water.
Original motor
A quick look at the motor it came with - whether it's original or not I'm not certain - it's branded Hoover.
Headstock removed
Breaking down the larger parts - I've removed everything from the bed and individual assemblies are bagged so I can take it a chunk at a time.
Derusting the ways
After getting off most of the surface rust with WD-40 and some 0000 steel wool, I switched to Evaporust soaked paper towels under clingfilm for the really stubborn stuff.
Clean(er) ways
24 hours later, and with the Evaporust coating scrubbed off and there's a decent improvement. There's some marks and pitting remaining, but the surface is smooth at least.
Cleaned up up 3 jaw chuck
I also dismantled and soaked the chuck in Evaporust, after which a gentle session with a scotchbrite wheel gave a decent finish.
Phil Whitley22/03/2022 18:43:25
1449 forum posts
147 photos
Very nice machine, and quite a rarity! I shall be watching with interest! I will be starting on my little holbrook soon, which is about the same size!
Phil
old mart22/03/2022 20:12:49
3892 forum posts
268 photos
That could turn out to be a very nice machine. I'm glad to hear of your approach to removing the rust, there will be some imperfections and some people would ruin the bed by insisting on removing them, which looks pretty, but not recommended. Keep us up to date with your progress. We have a Hoover three phase motor on the Fobco drill press, made in Scotland.
 And welcome to the forum.
Edited By old mart on 22/03/2022 20:14:13
Edited By old mart on 22/03/2022 20:15:34
Nigel Graham 222/03/2022 22:16:12
2281 forum posts
33 photos
Good to see it receiving lots of sympathetic TLC.
It looks to have been well cared for then simply lay unused for a long time in a damp workshop. The bed has cleaned up well - those pits won't affect it seriously. The chuck has cleaned up with a nice patina, and shows no sign of abuse or accidental collisions. Another good sign: the chuck key's not been bashed about either.
'Evaporust'... I'll have to keep that name in mind!
I'd be a bit wary of using that motor though, at least not without having it PA-tested first. Simply replacing more-or-less with similar, sticking with 1-phase, should be easy enough as the larger power-tool suppliers like Machine Mart* stock suitable motors. You may need modify the existing mountings for it a little, or make an intervening adaptor-plate. (I did that for my BCA jig-borer.)
* I write as a customer, when the motor on my generic band-sawing machine went "POP!" in mid-cut.
Ady122/03/2022 22:58:27
5170 forum posts
738 photos
Looks like a great project with real potential, that hoover motor could be a real asset too
Don't go mad cleaning the ways, using the machine regularly for moderate work will wear the ways relatively quickly anyway so only the worst of it needs to be removed
Good luck
Hopper22/03/2022 23:40:58
6653 forum posts
347 photos
Interesting. Do keep us posted.
The son of Mr Murad used to post on this forum a few years back in relation to the Murad Bormilathe.
Xed24/03/2022 17:50:02
18 forum posts
75 photos
Thanks for the warm welcome everyone!
I am leaning towards motor replacement at the moment, purely as it'll be one less thing to worry about I'll see how I feel when I have a poke around that area.
Currently the plan is to clean/strip/paint the stand and the bed casting, then move them into more or less final position. After that I can just restore and bolt on an assembly at a time as I do them - not the most efficient maybe but helps keep track of things.
Stripping the junction box
Speaking of paint, I stripped down the wiring box from the back of the machine to use as a guinea pig for the new paint job. It's not super clear what the original colour was, so I've gone with something similar to what's on the lathe now: a kind of blue-grey with red highlights. Paints are on order from Paragon.
Aluminium
Cleaned up pretty well with generic paint stripper gel - this part (as well as the headstock cover) appear to be aluminium so will be etch-primed. I've got some red oxide primer for the main castings.
Leadscrew Derusting rig
The lead screw has also been taking a bath in my unspeakably high-tech derusting apparatus...
Shiny lead screw
...and has turned up a treat. A rinse, a gentle wire brushing to get off residue and a light coating of 3-in-1 oil for protection was applied.
noel shelley24/03/2022 21:11:15
1442 forum posts
23 photos
Welcome to the party ! You do not indicate where you are UK ? I would put the motor in the airing cupboard for a few days then wire it up to a plug and run it. Make sure the earth is attached. If your near me I will tast it for you. The hoover motor was a good unit. If you need help in wiring it up come back to me/the forum and well help. Best wishes Noel.
Hopper25/03/2022 06:06:01
6653 forum posts
347 photos
Looks like a good substantial machine. And looks like that Evaporust does a great job. Might have to try it.
You have the right idea not to tear down every nut and bolt at once, but do the bed and then do each sub assembly and put it back in place. Much easier to keep track of what's what that way. I've seen many old motorbikes torn down to ridiculous smallest parts, then the owner throws them all in a box and gets overwhelmed by it all and reassembly never progresses. Much better to take small bites at a time, and much more satisfying to get on thing done after another.
Mike Hurley25/03/2022 09:10:27
325 forum posts
87 photos
Looks a cracking good project, and its nice to see you are approaching it in a methodical, careful way. I very much agree with Hopper & others that avoiding the 'bull at the gate' approach will pay dividends in the long run.
Do keep us updated as you progress - things like this allways make interesting reading.
all the best, Mike
John Hall 1126/03/2022 01:16:44
1 forum posts
10 photos
I Hi Iv just bought a murad cadet aswell, mine has been sat in a garage for over 40 years
Xed29/03/2022 22:55:50
18 forum posts
75 photos
This last few days have been busy - who knew so much of the time taking on a project like this involved waiting for paint to dry?
While the enamel hardens on the stand and bed casting, I thought I'd do some preliminary poking around the wiring. I've buzzed out the switch configuration with a meter and got plenty of pictures to document what was already on the lathe when I got it. An important note however, it was already partially disassembled and wiring to the motor was cut, and the starter wiring completely removed so I can't vouch for this as a working configuration, I'm just documenting what was there. I was assured that it did run on single phase.
Main barrel switch
The barrel switch that mounts in the bed casting – I did strip the paint because I'm like a magpie with shiny brass objects.
Original Switch Wiring
This was how things looked with a multimeter in continuity – there's a third set of internal terminals that I've marked with an I for completeness. I do appreciate the previous owner marking things up
Original wiring switch side
This is the switch side of the terminal board that lived in the little electrics box on the back of the lathe. I'd documented this corresponding with John before I buzzed out the switch so unfortunately don't have the mapping back to the switch terminals. I do know that G1 and G2 were ganged together onto L1, with G3 on Z1
Original wiring motor side
And this is the other side with power input and motor output.
Original Motor Wiring
And finally the motor wiring side, with bonus appearance from the starter.
I'm still in two minds about reusing the Hoover motor, but the starter I do want to replace with something more modern that has a nice big E-Stop. I'd also like to be able to use the main barrel switch for control without switching the main motor load through it – I don't know enough about that kind of thing yet to see if that's a thing. More research required!
Edited By Xed on 29/03/2022 22:57:27
noel shelley29/03/2022 23:52:59
1442 forum posts
23 photos
Mostly it makes sense, but not at this time of night I will sort it out in the morning ! may have to ask a few questions. Noel.
Lee Rogers30/03/2022 00:21:57
176 forum posts
I like your gentle approach to the job. I wouldn't be gentle with that motor though, lose it . Hoover motors are nasty noisy things and the Murad is rigid enough to take a 1hp motor easily.
John Olsen30/03/2022 07:00:24
1256 forum posts
94 photos
If you are going to change the motor anyway, put on a three phase with a VFD. Well worth any extra cost.
noel shelley30/03/2022 09:38:46
1442 forum posts
23 photos
L1 and L2 are the mains live and neutral. Z1 and Z2 are the start windings A1 and A2 are the run windings. To reverse swap Z1and Z2. I will give more detail later if needed ! Noel.
noel shelley30/03/2022 16:31:19
1442 forum posts
23 photos
Check the coil voltage on the contactor coil, should be 220V and also the trip current which will be in the region of 1.5 - 4Amps. The MEM DOL starter is easy to wire, check out ME 4643 mid july 2020. Your wish for a BIG RED panic button is easy as you wire it into the DOL stop circuit in series with the stop button on the DOL as a normally closed switch. You then take Live and neutral to the drum reverser. Now we need the letters or numbers on the motor terminal plate to assertain the various connections. there were numerous letters and numbers used by various maker. what do you have ? wire colours coming from inside the motor may be helpful. Over to you ! Noel.
Phil Whitley30/03/2022 18:38:17
1449 forum posts
147 photos
Personally I would stick with the motor for now, and the starter, far better quality than you can buy nowadays! I have never come across a hoover motor that was noisy unless it was faulty! You can easily change it later if it proves to be underpowered. Why bother with the expense of a three phase motor and a VFD on a lathe that was not designed to run at high speeds anyway. By all means get the motor tested, but I doubt there will be much wrong with it, they were very rugged and reliable, as were the MEM starters, but I always recomend fitting the starter to the wall rather than the machine to prevent arcing at the overload contacts. Noel knows the game!
Phil
Edited By Phil Whitley on 30/03/2022 19:59:42
Xed30/03/2022 20:53:17
18 forum posts
75 photos
That's fantastic info Noel, thanks so much! I've done more poking around on the back of the motor and drawn out the diagram with the cable colours. The terminal numbers match the back of the motor:
Original Motor Wiring Diagram
Original Motor Internal Wiring
This is how it looks with the external wiring to the switch removed - insulation is a bit sketchy on the red wire and seems to have completely disintegrated on the capacitor wiring. I'm guessing finding a replacement cap would be a good idea?
Edited By Xed on 30/03/2022 20:53:41
Edited By Xed on 30/03/2022 20:54:21
noel shelley30/03/2022 22:42:21
1442 forum posts
23 photos
The way the wires have deteriorated would indicate the motor is oldish may be 60s, but still a good motor. I would expect 4 wires yet I can only see 3, I think ? he cap wires and the motor wires need to be sleeved to maintain insulation. Your diagram only shows 3 motor wires ? If you undo the small roundhead screws are there connections on the rear of 2 and 6 ? One wire will go to the cap from the cap to the centrifugal switch and then on to the start winding, the other end of the start winding will be a terminal. The run windings will be the straight to terminals. this gives you 4 terminals that should be taken to the reverser. In a effort to check the whole motor it would be a good idea to remove the 4 through bolts and strip. You can check the cent switch and it will be much easier to sleeve the wires and check which 2 are run and which are start based on the above. I will send a PM. Noel
Rapid RC
Dreweatts
