Anyone come across a 15/32 AF spanner?
Can't find this spanner size
Mark Rand12/03/2022 20:25:05
1272 forum posts
28 photos
Yesterday I decided to try and get the Taylor & Hobson Model C engraver going that's been sitting in the shed for 10-15 years. I made new drive belts from round PU belting and tried it out. There is slack in some of the pantograph linkages, although it looks like vertical play rather than radial play is the major culprit. As it happens the linkages involved are adjustable, But:-
They seem to have nuts that are 15/32" AF. This isn't a size that I've come across before and doesn't seem to match any series that I can find reference to.
I can use my smallest adjustable spanner and could mill a pair of fitting spanners out of gauge plate, then harden them, but I'm curious as to if anyone has ever come across this size?
JasonB12/03/2022 20:34:43
22744 forum posts
2653 photos
would 12mm be too loose?
David-Clark 112/03/2022 20:42:05
220 forum posts
Here’s one on eBay. About £5.
bernard towers12/03/2022 20:42:32
612 forum posts
109 photos
My AF spanner set from the late 60s went up in 32nds and I still have them, Britool of course and the chrome is still on them!!!
noel shelley12/03/2022 21:53:14
1339 forum posts
21 photos
Take a 7/16" or 11mm AF open end and file or use a grinding disc to increase it to 15/32" ! Done it with a 50mm to convert to 2" Good luck. Noel
Mark Rand12/03/2022 22:18:12
1272 forum posts
28 photos
Posted by JasonB on 12/03/2022 20:34:43:
12mm is a very sloppy fit, even though it's the closest that I had.
Posted by noel shelley on 12/03/2022 21:53:14:
My mind had been working along those lines as an option. Possibly with the surface grinder or an endmill.
Hey, after I get the engraver working I gan grind off the original markings and engrave some new ones. laugh
Nicholas Wheeler 112/03/2022 23:41:56
930 forum posts
87 photos
Posted by Mark Rand on 12/03/2022 22:18:12:
How about supergluing a shim in the jaws to tighten the sloppy fit? That's ought to be good enough for a few uses. A cheap set of feeler gauges is worth having for such jobs.
Or you could machine some new nuts to match other fittings on the machine. Which is a permanent fix.
Edited By Nicholas Wheeler 1 on 12/03/2022 23:43:19
Hopper13/03/2022 05:01:27
6388 forum posts
334 photos
15/32 is .469". And 12mm is .472".
How tight a fit do you want? Less than 3 thou?? Spanners are normally made five to ten thou bigger than the nominal hex size for easy use.
Michael Gilligan13/03/2022 10:14:03
20182 forum posts
1053 photos
If a sloppy-fitting spanner risks rounding the ‘corners’ of the hexagon … try flank drive
Split Pin13/03/2022 10:29:56
13 forum posts
Given that it is an old English manufactured machine, the fastners are probably all whithworth, in whick case it will be 1/4" whit which requires a 3/16" whit spanner. Hexagon size is 0.454" and the spanner size is 0.445"
Steven
Edited By Split Pin on 13/03/2022 10:30:29
Anthony Kendall13/03/2022 10:39:45
152 forum posts
Posted by Michael Gilligan on 13/03/2022 10:14:03:
Agree - I use a metrinch set for most things.
Pete Rimmer13/03/2022 10:44:40
1233 forum posts
65 photos
I'll have a look when I get home it's possible I might have one.
Mark Rand13/03/2022 12:57:07
1272 forum posts
28 photos
It isn't a Whitworth size, or a 12mm metric size, or a BA size.
Mr Micrometer says its 0.467" AF.
Tony Pratt 113/03/2022 13:06:18
1961 forum posts
12 photos
From a Taylor Hobson engraver it is likely to be a 15/32" but I'm sure a 12 mm A/F will suffice.
Tony
Michael Gilligan13/03/2022 13:36:01
20182 forum posts
1053 photos
Mark
In case you fancy making a pair of thin spanners … the basic geometry is here: **LINK**
https://worldwide.espacenet.com/patent/search?q=pn%3DGB1138546A
… and yes, it’s adaptable to open-enders
Nicholas Farr13/03/2022 14:42:03
3360 forum posts
1542 photos
Hi Mark, I don't think 15/32" A/F is a standard size in the UK, however 1/4" BSF / 3/16" Whit is supposed to be 0.445". I've just measured three 1/4 BSF / 3/16 Whit open ended spanners of mine, one is 0.452", one is 0.453" and the other is 0.459", so I would say one of those should fit your nut, which is a lot closer than a 12mm spanner that I have measuring 0.480".
Regards Nick.
Mark Rand14/03/2022 14:20:22
1272 forum posts
28 photos
Right:- update time.
I discovered that my only 12mm open ended spanner has got slightly sprung jaws. Doesn't normally affect it, since my normal reaction to a 12mm AF nut is to replace it with something else.
A 12mm hex (not bi-hex) socket fitted the outer, accessible nuts quite well.
A Bahco 4" adjustable spanner was thin enough to get to the inner, less accessible nuts.
The engraver produces far straighter lines once the play in the two joints is taken up. It isn't prefect yet, but it's better than it was.
oldvelo14/03/2022 19:43:12
295 forum posts
56 photos
Grip Master 12 mm spanner as used by ICI Instrument Artificers 60 + years ago will do the job as they grip the flats on the nut back from the corners on four places.
John Reese21/03/2022 03:39:38
1035 forum posts
About 65 years ago I purchased a set of open end wrenches from Sears Roebuck. I contained a couple of wrenches with odd 1/32 openings. I never found anything they fit.
mark costello 121/03/2022 18:03:19
716 forum posts
12 photos
Old American cars used some of those sizes.
Rapid RC
Dreweatts
