Hammer Handle Supplier??
William Chitham09/03/2022 10:20:17
139 forum posts
57 photos
I have a 1lb ball pien hammer in need of a new handle. I've found lots of suppliers of wooden handles on line but none yet (outside the US) that specify the size properly by length and eye size. Mine has a 1"x3/4" oval eye, not too bothered about length. Any suggestions for a supplier?
Thanks, William.
Derek Lane09/03/2022 10:33:51
761 forum posts
171 photos
If all else fails have you thought about making your own
roy entwistle09/03/2022 11:26:54
1525 forum posts
I've always had to shave them down to fit the eye of the hammer head.
Roy
KWIL09/03/2022 11:33:15
3554 forum posts
70 photos
There if you search correctly.
"Wooden Tool Handles"
This leads you to Richard Carter Ltd, a Huddersfiel company that makes every sort of wooden handle including club hammer ones!
William Chitham09/03/2022 11:37:04
139 forum posts
57 photos
Posted by KWIL on 09/03/2022 11:33:15:
Just found Rich Carter but they only specify by length, I've sent an email enquiry. I found a Faithful that is the right eye size but at 16" seems a bit long to me.
W.
Former Member09/03/2022 11:53:14
1085 forum posts
Circlip09/03/2022 11:57:37
1510 forum posts
"But with what shall I saw it dear Bill Dear Bill, wth what shall I saw it Dear Bill, with what?
Regards Ian.
Craig Brown 209/03/2022 11:59:45
63 forum posts
33 photos
I always shape the handle for a good tight fit in the hammer head.
My handles are purchased from a local farm/agricultural supply business, might be worth looking for one local to you
Former Member09/03/2022 12:02:35
1085 forum posts
Circlip09/03/2022 12:05:32
1510 forum posts
But make sure it's made from Hickory dear doc.
Regards Ian.
Former Member09/03/2022 12:22:13
1085 forum posts
William Chitham09/03/2022 12:37:46
139 forum posts
57 photos
What a hilarious lot you are.
I could make my own but time is short and ready made handles are inexpensive, probably cheaper than the material would cost.
I expect to have to do some fitting but as far as I know you can't "shave up" a handle that is too small.
If I "search correctly" I find many suppliers but very few that specify by eye size as well as length. Length isn't an adequate way to specify a handle. Richard Carter for example only quote length and apparently don't sell to consumers anyway.
Handles are not cylindrical, a 16" hammer handle with 2" sawn off isn't a 14" hammer handle, it is a 16" handle with the end sawn off.
The most important dimensions are of the eye but on consideration I think that I would prefer a handle 12" - 14" long.
W.
Former Member09/03/2022 12:44:47
1085 forum posts
KWIL09/03/2022 15:16:00
3554 forum posts
70 photos
Length of handle should not be a problem, just stand closer (or further away) from the impact target.
Unless you have extremely short arms, the required effort should not really vary.
derek hall 109/03/2022 15:40:17
223 forum posts
During my apprenticeship in the shipyard many moons ago I was given a new 1lb ball pien hammer and told to cut 2 inches off the length of the shaft as it was deemed "better for close controlled hammering"...
I think the main issue William has is the business end of the wooden shaft. Surely it has to be shaped to size to fit the hammer head before the wedge is knocked into the end grain? Never bought a new wooden handle for a hammer to be honest, when the handle got damaged I bought a new hammer.
My grandfather used to make handles for hammers etc but sadly I dont have his skills in woodwork
Regards to all
Derek
KWIL09/03/2022 15:51:34
3554 forum posts
70 photos
Derek,
I think you Apprentice advice was similar to going to the stores for a long wait or left handed screwdriver..wink
Old School09/03/2022 16:02:59
406 forum posts
39 photos
My father was a working clockmaker and made predominantly skeleton clocks from the simple to orrery,s in batches of 5.
When he died his tools were shared out between us three brothers, as part of my lot I got a ball pien hammer with a short handle it’s turned out to be the go to hammer easy to handle and heavy enough to do what’s needed.
JasonB09/03/2022 16:18:45
22747 forum posts
2653 photos
Regardless of final shaping of the shaft to fit the eye you still want a shaft of the right proportions to suit the weight of the head. Just buying by length could get you a spindly one more suited to an 8oz head or a 2lbs one.
As for suggestions to cut a bit off the end you have to bear in mind that a good shaft will widen towards the end which make sit comfortable to grip and less likely to slip out of the hand. Saw too much off and you loose that thicker end.
Zoro have a range and indicate the size of head the shaft (not handle) will suit, length in proportion to head size. And another supplier of shafts
Edited By JasonB on 09/03/2022 16:22:20
Former Member09/03/2022 16:27:59
1085 forum posts
William Chitham09/03/2022 16:38:52
139 forum posts
57 photos
Posted by JasonB on 09/03/2022 16:18:45:
Thanks Jason, I've seen the Zoro range but I'm reluctant to buy without seeing the eye dimension. Zoro are particularly hopeless at properly specifying items in my experience. The other link is interesting as they are selling the Richard Carter handles, I have sent an email to them asking for dimensions. This is the only uk supplier I have found so far with the proper info but the the 16" one that would fit is too long for me: FAITHFUL
This one in the states looks just the job, I'm sure I'll find one in the uk eventually: Hammersource
William.
Edited By William Chitham on 09/03/2022 16:39:50
Rapid RC
Dreweatts
