Bill Dawes | 08/03/2022 20:03:09 |
534 forum posts | Having had time now to consider these design as they stride across the levels near to where we live in Somerset, I have decided I don't like them. When we were first told about these new designs they sounded better than the gargantuan lattice ones, however now changed my mind, true they are neater and smaller but it is because of that they seem more in your face probably because there are more of them, I assume this is because they are lower and need to spaced closertogether to keep the cable droop to a safe level. Too late now of course. Bill D. |
Bill Dawes | 08/03/2022 20:04:33 |
534 forum posts | closertogether was not intentional!!!!!!! Bill D. |
Michael Gilligan | 08/03/2022 20:37:56 |
![]() 20200 forum posts 1053 photos | Ticks "all the right boxes" ...but yes, they are weird : **LINK** https://www.powerpylons.com/ MichaelG. |
duncan webster | 08/03/2022 20:52:19 |
3990 forum posts 65 photos | Posted by Bill Dawes on 08/03/2022 20:04:33:
closertogether was not intentional!!!!!!! Bill D. ??? Surely they didn't make such a basic mistake, closer means more expensive as there are more of them, unless the new ones are cheaper and so the total cost including more foundations s less. Also, each side has its own earth (lightning conductor?) at the top whereas old ones only had one, more expense? The big advantage with air insulation is that it self heals. If you get an arc with solid insulation it gets damaged and isn't an insulator any more Edited By duncan webster on 08/03/2022 20:55:09 |
Hopper | 08/03/2022 22:35:07 |
![]() 6421 forum posts 335 photos | Posted by duncan webster on 08/03/2022 20:52:19:
closertogether was not intentional!!!!!!! Bill D. ??? Surely they didn't make such a basic mistake, closer means more expensive as there are more of them, unless the new ones are cheaper and so the total cost including more foundations s less. ...They are cheaper. That's why they use them. "Cost efficient" is the term they use. |
Bazyle | 08/03/2022 23:08:03 |
![]() 6325 forum posts 222 photos | The individual metal elements of the old ones were thin so if not on the skyline but seen with a backgouund of trees they blend in better. The driving force behind them is probably lifecycle costs. The metal ones have to be painted regularly which is a very manual and expensive process. |
Michael Gilligan | 08/03/2022 23:23:37 |
![]() 20200 forum posts 1053 photos | Duncan, This is just one page on from the link I provided earlier: **LINK** https://www.powerpylons.com/design-engineering That’s a lot of ‘right boxes’ ticked. MichaelG. Edited By Michael Gilligan on 08/03/2022 23:28:37 |
Hopper | 09/03/2022 04:39:25 |
![]() 6421 forum posts 335 photos | Posted by Michael Gilligan on 08/03/2022 23:23:37:
What language are they speaking? "...compact power pylons that are respectable to the landscape and environment..." and "... optimized throughout the value chain".
not done it yet | 09/03/2022 05:33:12 |
6812 forum posts 20 photos | Bill, You have a PM. Edited By not done it yet on 09/03/2022 05:34:26 |
Michael Gilligan | 09/03/2022 06:19:45 |
![]() 20200 forum posts 1053 photos | Posted by Hopper on 09/03/2022 04:39:25: . What language are they speaking?
. ”Box-ticking” MichaelG. |
Sam Longley 1 | 09/03/2022 08:38:43 |
942 forum posts 34 photos | What are they constructed from? One would assume the old metal ones would be recyclable. But if the new ones are in GRP, then I would question that they can be recycled so easily. Lifetime is possibly more. The old style does last quite a while, I have seen them being replaced. More often re strung, or insulators changed. Edited By Sam Longley 1 on 09/03/2022 08:39:41 |
Sam Longley 1 | 09/03/2022 08:44:11 |
942 forum posts 34 photos | Posted by Bazyle on 08/03/2022 23:08:03:
The metal ones have to be painted regularly which is a very manual and expensive process. Have you actually seen them being re painted. I saw some old ones being taken down & the galvanising was still fairly good. I thought that painting previously galvanised surfaces is not quite so straight forward, as it is to bare, or pre painted steel. Edited By Sam Longley 1 on 09/03/2022 08:45:14 |
Hopper | 09/03/2022 08:47:50 |
![]() 6421 forum posts 335 photos | Posted by Sam Longley 1 on 09/03/2022 08:38:43:
What are they constructed from? One would assume the old metal ones would be recyclable. But if the new ones are in GRP, then I would question that they can be recycled so easily. Lifetime is possibly more. The old style does last quite a while, I have seen them being replaced. More often re strung, or insulators changed. Edited By Sam Longley 1 on 09/03/2022 08:39:41 Says on MG"s link they are galvanised steel. Some sort of pressed or rolled and welded monocoque by the looks. Glorified lamp posts. |
Samsaranda | 09/03/2022 10:13:35 |
![]() 1430 forum posts 5 photos | Can’t imagine why anyone would need to paint the old style pylons as they are galvanised, ever tried to get paint to adhere to galvanise, it won’t. Dave W |
Hopper | 09/03/2022 10:15:53 |
![]() 6421 forum posts 335 photos | Posted by Samsaranda on 09/03/2022 10:13:35:
Can’t imagine why anyone would need to paint the old style pylons as they are galvanised, ever tried to get paint to adhere to galvanise, it won’t. Dave W Rub it down with vinegar first to etch the surface. But heck of a lot of vinegar per pylon I reckon. |
Nicholas Wheeler 1 | 09/03/2022 10:17:56 |
930 forum posts 87 photos | Posted by Hopper on 09/03/2022 04:39:25:
Job justification which is the native tongue of all middle managers. This one seems to be American from the 'z' in optimised |
Oldiron | 09/03/2022 10:39:54 |
976 forum posts 40 photos | Posted by Samsaranda on 09/03/2022 10:13:35:
Mordant Solution or T-Wash is used to etch galvanised items to allow a paint to be applied. It is water based and very effective. regards |
SillyOldDuffer | 09/03/2022 11:23:29 |
Moderator 8699 forum posts 1967 photos | Posted by Nicholas Wheeler 1 on 09/03/2022 10:17:56:
Job justification which is the native tongue of all middle managers. This one seems to be American from the 'z' in optimised "...compact power pylons that are respectable to the landscape and environment..." is bad English wherever she is spoke! ""... optimized throughout the value chain" is less criminal because it has a particular business management and accounting meaning. It's the language one might see in the Management Summary introducing a hefty business case full of spreadsheets and risk assessments justifying spending big money. Laziness is a likely cause - someone created the web page by cannibalising a Management Summary rather than engaging brain and re-writing it for a general audience. In the right context 'optimized throughout the value chain' is pithy jargon. Quite hard to explain what it means in plain English because 'Value Chain Management' is a chunky manufacturing discipline, the goal being to 'maximise value at the lowest total cost'. Whereas a production engineer might reduce costs by simplifying and adjusting the design to suit manufacture, VCM considers all possible economies, including sacking the workforce, turning the factory into a housing estate and moving production abroad! Production Engineers are nice cuddly chaps: Value Chain Analysts are spawn of Darth Vader... Dave |
roy entwistle | 09/03/2022 11:34:16 |
1525 forum posts | Why do we have to buy from Denmark? Why can't we make them ourselves? Roy
Tony Pratt 1 | 09/03/2022 12:20:21 |
1967 forum posts 12 photos | Posted by roy entwistle on 09/03/2022 11:34:16:
It seems like we have to buy / import everything, look where that has led us. Tony
