modeng2000 | 24/02/2022 17:33:07 |
311 forum posts 1 photos | I would like to be able to remove a SMD chip resistor. Unfortunately it has been fixed with adhesive and soldered. I assume the adhesive won't soften with heat so what is the best way to approach this? John |
Martin Connelly | 24/02/2022 17:38:48 |
![]() 2182 forum posts 227 photos | The controls department where I used to work used a hot air tool specifically designed for this type of thing. Looks more like a soldering iron than a hairdryer. Martin C |
Joseph Noci 1 | 24/02/2022 17:53:56 |
1099 forum posts 1317 photos | Heat does work even if the adhesive is epoxy, etc. Use 20-40watt iron with a tip that can cover both ends of the SMD, put a blob of solder on the tip and apply to the smd - keep it in contact with both ends for 10-15sec. Use a small jewellers type screwdriver to gently prod at the smd every few seconds - it will move away.. This will not work well if the PCB is phenolic/resin impregnated paper, etc - works fine on fibreglass pcb's - FR4, etc. Hot air may work, but will take longer and will heat the surrounding bits more than necessary. |
modeng2000 | 24/02/2022 19:41:13 |
311 forum posts 1 photos | Thanks both for your helpful replies. The pcb is fibreglass so I'll give it a try. John |
Andrew Johnston | 24/02/2022 20:06:27 |
![]() 6674 forum posts 701 photos | How big is the resistor and what sort is it? For standard thick film chip resistors I use two 80W irons, one on each end. Even with glue once the solder is molten the resistor can be removed by pushing gently with the irons. Andrew |
Grizzly bear | 24/02/2022 20:08:33 |
303 forum posts 8 photos | How To Remove Surface Mount IC/smd IC - Learn 4 Neat Methods - YouTube Good luck ........... |
noel shelley | 24/02/2022 21:25:33 |
1444 forum posts 23 photos | I would use hot air, especially to fit a new one. Use foil to protect other components around the site.Noel. Edited By noel shelley on 24/02/2022 21:27:36 |
modeng2000 | 25/02/2022 10:52:58 |
311 forum posts 1 photos | The resistor is approx 3mm long, value 110k I'm sure it will let go with sufficient heat on both tags. John |
Andrew Johnston | 25/02/2022 12:12:00 |
![]() 6674 forum posts 701 photos | Posted by modeng2000 on 25/02/2022 10:52:58:
...resistor is approx 3mm long... Probably 1206, ie, 120 thou by 60 thou, or 3216 in metric. Huge, should be no problem removing it. Andrew |
Joseph Noci 1 | 25/02/2022 13:15:54 |
1099 forum posts 1317 photos | Is the resistor broken/open cct? Do you need to fit a different value? If you need a lower value, put a suitable value in parallel - easier than removing the present one. If you need a larger value.... Joe |
modeng2000 | 25/02/2022 20:57:14 |
311 forum posts 1 photos | Thanks Andrew. Joe, I believe it is o/c and will consider paralleling with a conventional resistor for test purposes if this is the case. Not sure if there is room to leave a wire-ended resistor in place when reassembled. John |
