Meddings Pillar Drill chuck change
approx 1950's Floor standing.
Martin Chamberlain20/02/2022 11:30:08
14 forum posts
23 photos
Hi,
The chuck is getting a bit knackered and was hoping to change it for a nice new one I aquired but upon inspection of the quill noticed there is no slot for a 'Drift' (?) taper key to dislodge a Tapered shaft.
At the base of the quill is a knurled free spinning round 'nut' which does seem to engage with some threaded...? part but can find no way of removing the chuck.
There is no drawbar up to the spline... No little screw inside the chuck.. I have administered reasonable force to the top of the chuck... But nothing...
All I can see is what may be a few mm's of an mt2 at the top of the chuck.
Has anyone had any experience here.. I did phone Meddings and was met with a youthful 'Dunno mate..' Work experience day probably..
JohnF20/02/2022 12:34:14
1152 forum posts
190 photos
Hi Martin, what model is your machine? Maybe a photo will help to ID the machine or see the problem
Hopper20/02/2022 12:42:03
6412 forum posts
334 photos
If the chuck is mounted on a male taper on the end of the spindle, you may have to use tapered wedges to remove chuck from its taper. You can buy such wedges made for the purpose. But you need to be sure that is how the chuck i smounted before applying such force. Pics would help.
SillyOldDuffer20/02/2022 13:04:48
8698 forum posts
1967 photos
This Instructables explains wedges quite well. ArcEurotrade used to sell wedges but it looks as if they only have drifts at the moment.
Martin Chamberlain20/02/2022 13:42:46
14 forum posts
23 photos
Hi Guys Thank you for your responses.
I do have some pics of the offending Chuck but am unsure how to upload them.. Advice plis..
If the chuck had an internal taper (B?..) I think my pounding on the top of the chuck with a narrow bolster would have dislodged it and have previoulsy attempted a 'Wedge' seperation again with violent encouragement but was fearful of damaging some other part.
I beleive this is probably the original chuck to the drill. The only thing I havent tried is to put the chuck key in and smack it to the left with a big 'ammer.. I doubt this was common practice back then and have only seen this on certain electric hand drills..
I think this strange 'floating' nut has a part to play but ???...
John Paton 120/02/2022 19:04:39
324 forum posts
20 photos
Martin, have you tried phoning Meddings (Ivybridge, Devon)? I have found them very helpful although their knowledge of early machines is a bit hot and mess as the older workforce have now retired.
Of the early drills I have seen the larger ones had a MT internal taper with slot through the quill for use of a freeing wedge. The medium and smaller drills had male Jacobs tapers and require shallow tapered folding wedges to spring the chuck off ( drive them together hard then tap the chuck and the shock will release its grip on the taper) as Hopper has advised.
I am not sure what arrangement the more recent Meddings drills have but suspect it is still a Jacobs taper.
hope this helps
not done it yet20/02/2022 19:43:25
6812 forum posts
20 photos
One wedge is inefficient and likely even counter-productive - especially with violent encouragement!
You need two proper wedges acting in opposite directions, thus providing a force in the direction of ejection.
Generally, ejection only need a ‘stop’ on one wedge and the other tapping with a mallet. I use them whenever I need to eject a morse taper from my my mills, if more than gentle persuasion is needed for removal.
The wedges need to have a long taper, so they overlap each other when in use.
DC31k20/02/2022 20:14:36
686 forum posts
This thread has some useful information:
https://www.model-engineer.co.uk/forums/postings.asp?th=165978&p=1
Dimensions for wedges, should you wish to make your own as attached (derived from measuring the ones supplied by Arc).
Martin Chamberlain21/02/2022 08:47:15
14 forum posts
23 photos
Hi Guys,
Thank you again. The consensus does seem to favor some form of wedged fitting. Jacobs, Morse et al.
I have managed to open a gallery (Marcham med chuck8) with a few pics of the knurled nut in up and down positions. Travel of about 10mm.
There is a freely rotating threaded section inside this nut which in my view may work as folding wedges but with a tool that is no longer with the machine.. Possibly a short lived experiment by Meddings..
I do not beleive this nut was used for holding the depth stop as there is enough of the quill showing to fix there.
I do not think my skills (or machinery) would encompase actually making wedges and for the time being I am hoping that someone may recognise/or have this unusual arrangement themselves.
Martin Chamberlain21/02/2022 10:34:13
14 forum posts
23 photos
Hi Mr Moderator Dave,
Sorry, I did not realise the 'Indestructables' was a link.. (Duh..)
I am unfamiliar with the site but looks very much worth exploring. Thank you.
The article you reference does show what appears to be a similar aparatus for chuck dis-lodgement and can see the thinking behind it and possiblly why Meddings attempted it..
I wish to dislodge the quill shaft rather than just knocking off the chuck leaving a 'B' stub which will not accomodate my new chuck with a 1/2" UNF 20 fitting.
roy entwistle21/02/2022 11:42:25
1525 forum posts
If your new chuck has a screw fitting, it will have to be screwed to an arbor. Quills on drilling machines are not usually threaded.
Roy
AJAX21/02/2022 12:44:49
387 forum posts
42 photos
Martin, you may find this link useful to identify your machine.
http://www.lathes.co.uk/meddings-pacera/
I had a look at your album photos but was unable to find a match. Are you sure it is a meddings? I used to have a startrite drill with something similar looking on the arbour. Wife has a 10 speed startrite with an epicyclic gearbox on the spindle but it accepts a standard mt2 chuck. Also have other Meddings drills but they are Morse taper too.
If you unscrew that knurled ring upwards, does it act as an extractor?
AJAX21/02/2022 12:48:48
387 forum posts
42 photos
If you need wedges, I've found it easy to make disposable ones using an angle grinder and scraps of mild steel flat.
Martin Chamberlain21/02/2022 12:53:22
14 forum posts
23 photos
Hi,
I apologise for any confusion.. I meant to dislodge the Arbor from the quill.
I assumed that most (if not all..) quills will have a tapered Arbor as an insert with various stubbs or threads to accomodate a chuck.
I do not know enough about what options were used and why at any given time.
In my case I do not have a slot in the quill so that tells me.. It's not a tang.. And it's not a drawbar.. So...
Which the only logical option is a MT2/3 or JT released by folding wedges but which action may remove the chuck and not the arbor..
AJAX21/02/2022 13:02:39
387 forum posts
42 photos
Martin, you may find this drill has a fixed male arbor onto which a female chuck is mounted. If so, the arbor would not be removable so you should go easy on persuading it out. I can only recall one Meddings drill with a fixed arbour (possibly fitted with a B16 nose) but when I phoned Meddings they said it was a cheap import they had badged as Meddings -- a short-lived trial if I understood correctly. I don't think your drill falls into that category.
Martin Chamberlain21/02/2022 13:07:58
14 forum posts
23 photos
Hi Ajax,
Yes its a Meddings Pacera MF2.. 'F' for floor standing.
There is a 4 part Pacera MB4 re-build vid on YT which unfortunatly just skirts around the chuck but it does look like he has the 'floating collar/nut' but fits a drill guard onto it so.. I am still guessing..
As to making some wedges I may well need to go down that route but as I mentioned above I don't want to just knock the chuck off..
Perhaps there is a little grub screw I have missed..
AJAX21/02/2022 13:12:54
387 forum posts
42 photos
Martin,
This web page states the knurled component is the chuck extractor, as I previously suggested.
https://www.mig-welding.co.uk/forum/threads/pillar-drill-identification.65649/
I hope that helps,
Martin Chamberlain21/02/2022 13:17:56
14 forum posts
23 photos
Hi Ajax,
We overlapped there..
Your description sounds quite convincing.
If it's a cheap import I don't think they would have fitted this floating nut thing which is quite complicated.
I am beginning to think I should remove the quill and bore it out on the lathe. I do have an MT3 Reamer.. but I didn't really want to turn this into a big project..
Aaaargh What to do..
Martin Chamberlain21/02/2022 13:25:41
14 forum posts
23 photos
Ajax,
Thank you.. Nice one..
Would not have thought to look under Mig Welding..
But there it is and referred to as a chuck extractor so I shall follow this thread ..
Thanks again.
Martin Chamberlain21/02/2022 14:18:59
14 forum posts
23 photos
I have added the Meddings MF2 description to my photo's album and clearly states an MT1 spindle but also under accessories is a Woodworkers Mortice chisel set which would probably have fitted to this floating 'nut'..
I shall lavish it in WD40 prior to attempting the rotary nut option..
If no response I am probably in ICU..
Thanks everyone for your assistance..
Dreweatts
Rapid RC
