Martin King 2 | 17/02/2022 18:35:55 |
1005 forum posts 450 photos | Hi all. We have just bought a load of almost new tools by VERITAS of Canada, all in lovely condition. They include a VARIJIG adjustable system for routers etc. There is one small very simple item missing which is called an anti-tilt block I was wondering if anyone has one of these could I please have the dimensions so I can knock one up? Cheers, Martin |
Martin King 2 | 17/02/2022 22:53:29 |
1005 forum posts 450 photos | Bump
Mark Easingwood | 17/02/2022 23:29:41 |
![]() 49 forum posts 15 photos | Hi Martin, I don't have this particular jig, but I think the block will be the same thickness as the frame, other dimensions not critical. I guess it is screwed to router base to stop router tipping over, when balancing on the narrow frame. I just stick a suitable block of wood on the base with double sided tape, when using home made jigs. Instructions for Varijig are here ;- Mark. |
Martin King 2 | 18/02/2022 09:13:25 |
1005 forum posts 450 photos | Hi Mark, Thanks for getting back to me. I guess the missing part is on a router somewhere. I will make up a small alloy block with a suitable thread and put that with the jig. I have been looking at the Veritas tenon and dovetail saws that we got and they really are top notch quality, I had forgotten how good Veritas tools are, although some are a bit on the gimmicky side. Cheers, Martin |
Martin Connelly | 18/02/2022 09:27:59 |
![]() 2137 forum posts 222 photos | I think it will be the same thickness as the frame plus the thickness of the part of the template guide that rests on top of the frame. Martin C |
John Haine | 18/02/2022 10:33:22 |
4675 forum posts 273 photos |
£3.90 from Trend Direct. |
Mark Easingwood | 18/02/2022 12:55:49 |
Hi again, Trend Router Bases are tapped M6, so you only need a clearance hole and counterbore. Plastic/Nylon/Wood would also be ok to use. The Trend one is probably plastic, so it won't mark the job. For Reference the piece in this picture is 70mm long x 20mm wide. The Guide Bushes are flush with the router base, so don't add anything to the thickness of the jig. Regards, Mark |
Jeff Dayman | 18/02/2022 13:22:00 |
2225 forum posts 47 photos | You might be able to get info directly from Lee Valley / Veritas, they are in Ottawa Ontario Canada and are very much still in business. Link to their customer service info is below https://www.leevalley.com/en-ca/customerservice |
