Tonny Andre | 28/01/2022 16:35:52 |
17 forum posts 9 photos | Good Afternoon! I have bought a new single phase motor for my Aasbrink. And I have the original drum switch that I want to use, but do anyone have a wire diagram or something similar? I found this on youtube , but I am uncertain since my motor is different connections. https://www.youtube.com/watch?v=Jp-M0OySotU&t=1111s |
not done it yet | 28/01/2022 16:39:43 |
6719 forum posts 20 photos | Is there not a wiring schematic in the cover of that terminal box? |
Tonny Andre | 28/01/2022 16:41:04 |
17 forum posts 9 photos | No nothing I am afraid.. |
Les Jones 1 | 28/01/2022 17:16:20 |
2255 forum posts 156 photos | Although your switch looks similar to the one in the video the connections may not be the same. The first step will be to test the way the switch behaves. If there are no markings on the connections mark them with numbers or letters to identify them. Then create a table showing connectivity between the connections in all three positions. (Off, forward, reverse.). When you have done this post the results so can give you a digram of how to connect it, Les.
Tonny Andre | 28/01/2022 17:56:29 |
17 forum posts 9 photos | Just checked and it works the same as the one in the youtube video. I have a diagram, but dont understand it. No U, V or W and what pattern, delta or star and the black and red wire must come from the capacitor? I can wire sockets, lamps and easy things, but struggle on this sort of stuff.. |
Tonny Andre | 28/01/2022 18:30:45 |
17 forum posts 9 photos | Ohh and when in Off position is none contact between any of them |
Les Jones 1 | 28/01/2022 19:31:18 |
2255 forum posts 156 photos | Remove the two metal links on the motor. (leave the wires from inside the motor on the original terminals.) This should do what you want, If forward and reverse are the wrong way round swap over the wires to terminals U2 and W2 Les. |
Tonny Andre | 28/01/2022 20:00:47 |
17 forum posts 9 photos | Thank you so much Les! Will give it a try😁 |
