Unknown tool
GeoffT26/01/2022 16:13:08
8 forum posts
5 photos
20220126_091119.jpg20220126_090927.jpgHi, I came across this the other day and wondered if anybody knows what it is.
It looks like a small file but the two faces are smooth, the edges have very fine teeth like a file. It is 150mm long x 6mm wide x 1.5mm thick. The handle is stamped with Bedford, Sheffield, England and it has a number 4 stamped on.
Thanks
Geoff
Clive Brown 126/01/2022 16:22:59
807 forum posts
39 photos
It's a fairly standard needle file for filing the base of a narrow slot. Many other shapes are available. Bedford is the maker's trade-name. The 4 will be the "cut", fairly smooth.
Edited By Clive Brown 1 on 26/01/2022 16:23:43
Brian H26/01/2022 16:25:30
2312 forum posts
112 photos
Usually known as a warding file I believe, due to their use to cut the ward (slots) in lock components including keys.
The are useful when filing slots as they will only cut on the edge and do not widen the slot.
Rod Renshaw26/01/2022 17:26:14
375 forum posts
I agree with Clive's thoughts, but I am not so sure about it being a warding file.
I understand a warding file to be a slimmer version of a normal "flat file", usually double cut on both flat faces and single cut on both edges, and used by locksmiths and others needing narrow slots.
Rod
Edited By Rod Renshaw on 26/01/2022 17:42:13
Edited By Rod Renshaw on 26/01/2022 17:42:46
Ketan Swali26/01/2022 17:43:18
1416 forum posts
133 photos
Link: Joint Square Edge Needle Files
It was discussed on this forum in 2018: Link
Link: Joint Round Edge Needle Files
Ketan at ARC
Edited By Ketan Swali on 26/01/2022 17:51:13
GeoffT26/01/2022 19:18:02
8 forum posts
5 photos
Thanks for all the answers. Just shows you never stop learning!
Geoff
Dreweatts
Rapid RC
