John Billard 1 | 24/01/2022 13:02:37 |
108 forum posts | What is the best sealant to use these days for screwed joints within a 5" gauge boiler when subsequent access might be "difficult". Best wishes John B |
Former Member | 24/01/2022 13:22:14 |
1085 forum posts | [This posting has been removed] |
Former Member | 24/01/2022 13:22:15 |
KWIL | 24/01/2022 15:03:51 |
3549 forum posts 70 photos | br, It must be something you do, does not happen to me! |
Grindstone Cowboy | 24/01/2022 15:58:49 |
854 forum posts 64 photos | Not saying it's the cause of multiple posts, but I sometimes double-click where I should single-click. And to (partly) answer John B's original question, I'm afraid I've never built a boiler. However, I have had success with this for other sealing requirements, and I'm sure I read somewhere that it's suitable for steam. Doubt whether it has any thread-locking capabilities, though. Rob Links to https://rectorseal.com/rectorseal-tru-blu-group/ |
John Rutzen | 25/01/2022 08:42:48 |
348 forum posts 19 photos | Hi, I think Loctite is ok with steam for say screwing a thread into a boiler to hold on a support bracket but it does lose it's strength as I found out. I had screwed my regulator rod into the cam it used to operate the device and sealed it with loctite. I steamed up and wondered why the loco wouldn't move - the thread had unlocked itself! So I don't know of any thread sealant which will do anything other than seal inside a boiler. |
John Billard 1 | 25/01/2022 11:50:26 |
108 forum posts | Thanks for the replies. I am just interested in sealing threads at the moment e.g.main steam pipe in to the regulator and oil pipes etc into unions/bushes. Farmer para 287 uses Boss White but this was 1964. John B
Paul Lousick | 25/01/2022 12:16:14 |
2009 forum posts 711 photos | I used graphite sealant on the studs that screw into the barrel on my boiler. Graphite based compound is the traditional sealant for threaded and flanged connections on steam engines. |
old mart | 25/01/2022 12:21:30 |
3717 forum posts 233 photos | Google Loctite thread sealants to get the exact specifications. https://www.turtle.com/ASSETS/DOCUMENTS/ITEMS/EN/Loctite_21472_Catalog.pdf
Edited By old mart on 25/01/2022 12:24:09 |
John Purdy | 25/01/2022 18:14:29 |
![]() 337 forum posts 198 photos | I have used Loctite PST high temperature thread sealant #567 on my boiler fittings (internal and external), for many years and have never had a problem. Its a white paste in a tube, Loctite part #56747. It doesn't set hard so fittings can be easily removed in the future. According to the spec sheet its strength reduces to 55% of initial strength after 1000 hours exposure at 250C (482F). That's equivalent to a boiler pressure of about 550 PSI. John
Edited By John Purdy on 25/01/2022 18:20:19 Edited By John Purdy on 25/01/2022 18:51:58 |
