Can you identify this?
AJAX23/01/2022 20:41:27
395 forum posts
42 photos
I have a "thing" that most probably belonged to a larger thing. Some parts bear a similarity to those found on a scribing block or indicator stand. I'd be most interested to know what the indexed conical part is for.
The dovetail and gib strip has a very smooth fit. It appears to be well made.
20220123-202934 20220123-202926 20220123-202946 20220123-202951 20220123-202956 20220123-203007 20220123-203021 20220123-203050
Chris Evans 623/01/2022 21:03:13
2066 forum posts
It is a well made holder for a DTI. I have no idea re the spindle taper though.
old mart23/01/2022 21:14:01
3885 forum posts
264 photos
There is one of those tapers kicking around the workshop at the museum, I believe it is for a quick release milling or maybe drilling spindle. It is probably one of the short lived fittings that were killed off by BT 30 AND 40. The DTI holder would work well on any mill spindle or lathe tailstock. I would get a blank end arbor to fit it on as the blank ends are made soft to be machined.
Edited By old mart on 23/01/2022 21:15:05
Edited By old mart on 23/01/2022 21:16:23
AJAX23/01/2022 22:23:47
395 forum posts
42 photos
Posted by old mart on 23/01/2022 21:14:01:
Now you've mentioned it, I think you're right. Many thanks.
Pete Rimmer24/01/2022 00:11:49
1255 forum posts
69 photos
Strange way of indexing on a taper though. If the dimples are not drilled perfectly, it could prevent the taper from seating. I'd agree it's well made and for a particular machine not a one-off item going by the black crinkle finish.
Tony Pratt 124/01/2022 08:53:19
2018 forum posts
12 photos
I would suggest a commercially made DTI holder for a Jig borer, not sure what make though?
Tony
Tony Pratt 124/01/2022 09:51:05
2018 forum posts
12 photos
Hi AJAX, are there any markings on the part?
Tony
mgnbuk24/01/2022 10:03:53
1198 forum posts
72 photos
More likely "retaining" than "indexing" I suspect., rather like the Easychange holders.
Is the taper pressed in to the dovetail slide or retained with a screw ? Either way it should not be difficult to separate the two and put a parallel spigot in place of the taper - you could use it on anything then. I have something similar (but not as nicely made) with a parallel stub - much easier to set up for clocking a bore on the mill than a DTI arm lash-up.
Nigel B.
old mart24/01/2022 18:02:23
3885 forum posts
264 photos
I did find out what the taper was, but have forgotten and checking through googled machine tapers has not had any luck for me.
If I can find the one at the museum, I will post a picture.
Edited By old mart on 24/01/2022 18:04:28
AJAX24/01/2022 18:42:37
395 forum posts
42 photos
Posted by Tony Pratt 1 on 24/01/2022 09:51:05:
Tony
None that I am aware of. I will post an update if I see any.
AJAX24/01/2022 18:51:51
395 forum posts
42 photos
Posted by old mart on 24/01/2022 18:02:23:
Thanks. But unless someone has a use for this taper it will be removed and replaced with a straight shank.
old mart24/01/2022 20:49:04
3885 forum posts
264 photos
Thats exactly what I would do with it. But I do hate an unsolved mystery.
Versaboss25/01/2022 12:32:10
493 forum posts
71 photos
It is good being active on other forums also. I suspected having seen that before, but did not remember where. So I asked around, and in a couple of hours I got the answer.
This quick-change taper belongs to an Aciera 22 drilling machine. See here
Kind regards,
Hans
Edited By Versaboss on 25/01/2022 12:32:58
AJAX25/01/2022 13:00:00
395 forum posts
42 photos
Posted by Versaboss on 25/01/2022 12:32:10:
Kind regards,
Hans
Well done, Hans!
This page shows an example tool holder
http://lathes.co.uk/aciera22/page2.html
old mart25/01/2022 13:36:53
3885 forum posts
264 photos
I'm very pleased to know the answer.
AJAX25/01/2022 21:01:09
395 forum posts
42 photos
Posted by old mart on 25/01/2022 13:36:53:
Me too, but now I've checked the Aciera 22 drilling machine web page I feel short-changed by having only the tool holder! They look very nice machines.
old mart25/01/2022 21:09:49
3885 forum posts
264 photos
They were production machines, now rather superceded by CNC.
TheBlackOne26/01/2022 08:22:09
1 forum posts
Hey AJAX!
My name is Carsten, I saw the inquiry in the other forum where we identified the cone as the quick change system used in Aciera 22 / 23.
This is probably a long shot, but I guess it can never hurt to ask: In case you are interested to sell this to holder (and others of the same kind), let me know. I own a Aciera 22 and I am always on the lookout for these tool holders.
Cheers
Carsten
old mart26/01/2022 20:43:51
3885 forum posts
264 photos
I found the one at the museum, it has a MT3 socket in it. The body is about twice the length of the one pictured.
old mart27/01/2022 20:21:16
3885 forum posts
264 photos
Here it is, in good condition and the MT3 tanged socket is undamaged.
Edited By old mart on 27/01/2022 20:23:08
Rapid RC
Dreweatts
