Making the Entablature
ADRIAN THOMPSON 3 | 23/01/2022 19:41:19 |
![]() 3 forum posts 6 photos | Hi I am building the M E Beam engine and I have posted problems with the Reeves castings. When I phoned they admitted the entablature castings were all chilled and so I decided to fabricate the entablature from steel. I obtained a strip of 4mm mild steel and machined a groove down the centre. see photo. Next I realised that using heat to form it into a `U` shape would distort it, so I made a simple bending jig and that worked really well. I cut the shape to size and silver soldered the entablature together. see photo. I left the entablature in one piece rather than cut the end in two and mounted it on the column. I think it looks good and took less time and machining a casting. I was not very keen on the brown mahogany base so I covered the top in aluminium and will engine turn the aluminium to give it a more modern look. What do people think of this? Adrian |
Former Member | 23/01/2022 19:44:07 |
1085 forum posts | [This posting has been removed] |
JasonB | 23/01/2022 19:46:37 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | That came out well, personally I would stick with a traditional base |
bernard towers | 23/01/2022 22:17:47 |
568 forum posts 109 photos | Heat your chilled Castings to red heat and hold for several mins then wrap in insulation to slow the cooling process.should be ok after that. |
Bob Wild | 23/01/2022 23:14:47 |
86 forum posts 63 photos | Hi Adrian. I got a set of castings from Reeves for Lady Stephanie. The entablature casting was distorted all over the place. So I sent it back to the address on the drawings. When it didn’t arrive they told me that they had moved from that address years ago!!! They would not do anything until I returned the faulty casting which I said was impossible since I had sent it to the address on their drawings. Very disappointed with their service and ended up prefabricating the part which turned out fine. Not a great fan of Reeves now. |
ADRIAN THOMPSON 3 | 04/02/2022 16:43:21 |
I have been busy with the beam and have machined the bearings and placed them in situ. I never realised how important alignment is when trying to align the cylinder and beam. I think this is going to be the worse job of the build. Let me know what you think. Adrian |
Frank Gorse | 04/02/2022 19:23:21 |
82 forum posts | Looks very nice. I’m building this engine too and am increasingly inclined to fabricate parts rather than use castings. Two questions:did you bend the bar for the entablature cold or hot? You’d have to be quick to get it into the jig before it cooled so I’m guessing cold. And please can you tell me where to find the article by David Haythornthwaite,I’ve looked on his website without success and i could use all the help I can get! Definitely going with the 12 studs anyway.
JasonB | 05/02/2022 07:48:46 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | The articles mentioned started in ME No 4603 |
