C T | 23/01/2022 19:04:13 |
![]() 54 forum posts 2 photos |
Edited By C T on 23/01/2022 19:05:33 |
Michael Gilligan | 23/01/2022 19:28:23 |
![]() 20057 forum posts 1040 photos | BSA M20 is in with a chance : **LINK** https://classic-motorbikes.net/wp-content/uploads/2015/10/10715.jpg MichaelG. |
Former Member | 23/01/2022 19:31:57 |
1085 forum posts | [This posting has been removed] |
C T | 23/01/2022 19:41:00 |
![]() 54 forum posts 2 photos | The BSA M20 was the closest match I could find but no not quite. Unless there was slight changes during production period, the shape of the casing changed. |
Andrew Tinsley | 23/01/2022 19:57:26 |
1610 forum posts | Looks like my father's pre war James 198cc twinport. Andrew. |
Mark Rand | 23/01/2022 19:58:45 |
1236 forum posts 28 photos | There were an awful lot of M20s made over nearly 20 years, in both military and civilian versions, so there was a fair bit of variation. |
Michael Gilligan | 23/01/2022 20:06:21 |
![]() 20057 forum posts 1040 photos | Is there a certificated Rivet-Counter on the forum ? … We need your assistance: MichaelG.
Former Member | 23/01/2022 20:28:46 |
Steviegtr | 23/01/2022 20:30:02 |
![]() 2421 forum posts 336 photos | There was also a M21 600cc version. Or could it be an Aerial. ?? really no idea . |
C T | 23/01/2022 20:33:00 |
![]() 54 forum posts 2 photos | I have looked at many images of the BSA M20 through its production run and am unable to find a match. I thought I was looking at a sidevalve engine but now not sure if it's possibly a 2stroke. Again the James surgested can't find a match. The owner of the motorcycle in the photograph had quite a number of bikes over a number of years. I have found many photographs of him his wife with their transport, his wife also rode bikes. I have extracted 6 bikes so far from an outbuilding. The bike in the photograph is not one of them yet. |
duncan webster | 23/01/2022 20:49:11 |
3919 forum posts 61 photos | Looks a lot like a BSA C10, I had one once, horrible thing |
JohnF | 23/01/2022 20:52:29 |
![]() 1146 forum posts 189 photos | My observations are it appears have a solid frame and girder forks so most probable pre war or at least pre 1950 I think, Had a short search and a BSA C10 c1939 seems a possibility, the timing cover looks similar and its a side valve engine [C10 was made for several years well into the 50's with tele forks] See a couple of links https://www.feked.com/images/detailed/32/IMG_4849-1000.jpg https://classic-motorbikes.net/wp-content/uploads/2015/10/9092.jpg John edit -- Ha! Duncan beat me to it Edited By JohnF on 23/01/2022 20:53:30 |
Chris Evans 6 | 23/01/2022 20:57:18 |
![]() 2050 forum posts | Another vote for sidevalve BSA C10. Second thoughts the girder fork side links don't look like BSA. Edited By Chris Evans 6 on 23/01/2022 20:59:40 |
C T | 23/01/2022 21:00:21 |
![]() 54 forum posts 2 photos | Thank you for that yes a BSA C10 from around 1940 looks to fit the bill. Now as an addition I have found an owner's manual for the BSA "C" range of engines giving a little more credence to the C10. Thanks again |
Robert Butler | 23/01/2022 21:02:12 |
382 forum posts 6 photos | The OP image does not show access to the valve chest so unlikely to be a C10. I am inclined more to the two stroke theory. Robert Butler |
Bill Pudney | 23/01/2022 21:53:33 |
606 forum posts 24 photos | Whatever it is, or isn't, it's what used to be described by "One Track", in Motorcycle Sport as "....grey porridge...." cheers Bill |
Robert Butler | 23/01/2022 22:20:44 |
382 forum posts 6 photos | Also no sign of an oil tank and most 4 strokes of that era are dry sump. Robert Butler |
mgnbuk | 23/01/2022 22:32:41 |
1175 forum posts 71 photos | Carb mounts at the top of the cylinder, so unlikely to be a two stroke. No idea of the maker though. Nigel B. |
Michael Gilligan | 23/01/2022 22:48:33 |
![]() 20057 forum posts 1040 photos | |
Robert Butler | 23/01/2022 22:52:05 |
382 forum posts 6 photos | May be, but carb may not be bolted directly to cylinder, may be a manifold or downdraft mounting. The puzzle is there appears to be a timing chest or it could be a mag dyno drive?? The no oil tank is a pointer to 2 stroke. The Classic Motorcycle - Richard Rosenthal expert on old motorcycles. Robert Butler |
