Clarke cl500m mill head bearings
Anyone know to lubricate them?
Stuart Cox 323/01/2022 18:37:28
152 forum posts
25 photos
Hi all
Does anyone know how to lubricate the bearings in the mill head of the Clarke CL500M?
Many thanks
Stu
old mart24/01/2022 17:58:18
3717 forum posts
233 photos
If the bearings are taper roller, I would recommend a high melting point lithium grease, as used for older car wheel bearings. Be sure to leave at least 50% air space when packing them.
Stuart Cox 324/01/2022 19:09:18
152 forum posts
25 photos
Thanks, I'm not sure if they are tapered bearings as I haven't taken it apart yet. I was hoping someone who has managed to do this could advise?......
old mart24/01/2022 19:53:05
3717 forum posts
233 photos
I found the parts list, they are very likely taper roller, but that grease would work with any ball or roller bearings. Why do you want to replace them?
Stuart Cox 324/01/2022 20:16:37
152 forum posts
25 photos
Thanks, I don't want to replace them, I just want to know how you get to them to lubricate them. I'm presuming I don't have to strip the mill head apart every time they need lubricating....
Stuart Cox 324/01/2022 20:17:17
152 forum posts
25 photos
...or maybe I do?
SillyOldDuffer24/01/2022 20:40:25
8469 forum posts
1885 photos
Can anyone confirm the bearings need maintenance? I've an idea they're sealed for life and are replaced if they clap out.
old mart24/01/2022 20:57:41
3717 forum posts
233 photos
I agree with SOD here, they are probably not intended to be lubricated during their lifespan. The manual should show lubrication points and there may not be any mentioned for the lathe spindle either.
Stuart Cox 324/01/2022 21:06:12
152 forum posts
25 photos
All it says in the manual is .. 'Lead screw and mill head spindle should be oiled weekly '.... so maybe you're right. The bearings are a little noisy so looks I may have to replace them then.
Thanks Stu
old mart24/01/2022 21:28:41
3717 forum posts
233 photos
Strange, I downloaded the CL500M manual from the Clarke website, and the routine lubrication on page 23 does not show any lubrication of the milling spindle.
Stuart Cox 324/01/2022 21:48:03
152 forum posts
25 photos
..page 23 under the heading Weekly
Stuart Cox 324/01/2022 21:49:40
152 forum posts
25 photos
..although there's no diagram or reference though show how to oil the mill head spindle
old mart24/01/2022 22:10:33
3717 forum posts
233 photos
I can see the oiling of the quill lever spindle, that is all there is on the mill .
Dreweatts
Rapid RC
