Stiff Start
Bob Astill | 22/01/2022 16:45:45 |
![]() 111 forum posts 19 photos | Hi all finaley nearly got the J&S finished ended up getting the motor rewound thats what the smoke was
Thank you Bob |
noel shelley | 22/01/2022 16:49:50 |
1284 forum posts 21 photos | WHAT OIL SHOULD BE USED ? what oil did you use ? Noel. |
Dave S | 22/01/2022 17:05:51 |
362 forum posts 90 photos | Iirc it’s 32 weight hydraulic oil. Think I put Castrol Magna SW 32 in mine. Which lever is giving you trouble? Dave |
Baz | 22/01/2022 17:20:30 |
713 forum posts 2 photos | I think we used Tellus22 in ours, but it was a long time ago, the only thing that makes me sure is that I still have gallons of the oil in the back of the workshop. |
Pete Rimmer | 22/01/2022 17:43:43 |
1219 forum posts 63 photos | Mine ran ok on iso32. HAve you looked at checking the oil pressure and perhaps adjusting it? Mine was an older model but it had a pressure regulator on the top of the pump. |
Mark Rand | 22/01/2022 19:28:42 |
1239 forum posts 28 photos | The J&S recommendation is Vacuoline 1405. That's also ISO32. |
noel shelley | 22/01/2022 21:32:40 |
1284 forum posts 21 photos | iso 32 is SAE 10. |
Chris Crew | 22/01/2022 21:33:14 |
![]() 194 forum posts | The manual states that maximum hydraulic oil pressure is 120 lb/sq.in (.4 kg/sq.cm). It states that adjustment will rarely be necessary but to use a pressure gauge on the output when adjusting the relief valve. If you PM me with an email address I can try to send you a scan of the relevant pages from the manual if you don't already have one but that is about all it says. There is an illustration of the relevant parts and a hydraulic circuit diagram, if that is any help? |
Bob Astill | 23/01/2022 17:12:26 |
![]() 111 forum posts 19 photos | Posted by noel shelley on 22/01/2022 16:49:50:
Hi Noel I can't remember a friend gave me it saying it would do I think I am going to have to change it to find out I just wondered if its thicker would that be the problem?
Bob Astill | 23/01/2022 17:14:58 |
![]() 111 forum posts 19 photos | Thank you all for the replies I am going to order some 32 and see if it curers the problem if not I will buy a pressure gauge to check it I have the manual so should not be to hard.
Bob
Mark Rand | 23/01/2022 19:37:09 |
1239 forum posts 28 photos | A major reason for the recommendation of a 'thin' oil is that it is also the way oil. The ways on the grinder move a lot more rapidly than lathe ways! |
Bob Astill | 26/01/2022 10:24:53 |
![]() 111 forum posts 19 photos | Hi guys sorry for the delay flat out at work My friend said its Morris Lubricants Triad iso 46 oil so i hope this is the problem i assume 46 is a fair bit thicker than the iso 32?
Bob |
mgnbuk | 26/01/2022 11:24:07 |
1176 forum posts 71 photos | i assume 46 is a fair bit thicker than the iso 32? Yes, 46 is noticably thicker than 32. The Gildemeister lathes at work use 46 hydraulic oil for spindle gearbox lubrication & the difference in thickness can be seen over 32 (kept for hydraulic top-ups) when decanting from barrel to jug. Hopefully changing to the correct grade will sort your problems. Nigel B. |
Bob Astill | 26/01/2022 16:25:59 |
![]() 111 forum posts 19 photos | Posted by mgnbuk on 26/01/2022 11:24:07:
i assume 46 is a fair bit thicker than the iso 32? Yes, 46 is noticably thicker than 32. The Gildemeister lathes at work use 46 hydraulic oil for spindle gearbox lubrication & the difference in thickness can be seen over 32 (kept for hydraulic top-ups) when decanting from barrel to jug. Hopefully changing to the correct grade will sort your problems. Nigel B. I hope so as well Bob |
Bob Astill | 24/03/2022 11:26:21 |
![]() 111 forum posts 19 photos | Latest update. Hi all many thanks for all the advice it turned out to be several problems firstly the motor was bad and needed a rewire (not cheap) the 40 oil was to thick ans lastly i had the 2 pipes to the pump the wrong way round they are supposed to cross over (seems wrong to me ) but it is now running great and doing a loverly job so thank you all. |
David George 1 | 26/03/2022 06:53:25 |
![]() 1808 forum posts 503 photos | Hi Bob nice to hear that your grinder is working well. So many times we don't hear the outcome of restorations and work done on here. David |
