John Smith 47 | 17/01/2022 12:09:35 |
393 forum posts 12 photos | Hello Can you suggest an epoxy adhesive that sets SLIGHTLY slower than the modern "5 minute" type of epoxies? So I need something in the middle. Even a 10 minute setting time, rather than 5 minutes would help me quite a lot!
EDIT: I prefer separate tubes if possible, as I find them easier to dispense accurately. Edited By John Smith 47 on 17/01/2022 12:16:06 |
Brian Baker 1 | 17/01/2022 12:16:46 |
![]() 194 forum posts 36 photos | Greetings John, epoxy is used quite a lot for small boat repairs, so if you have a boat chandlers near you, it would be a good place to look, they usually sell quick & slow setting. The brand I use is SPX I think, will check that tomorrow when I next visit the boat. All epoxy is temperature sensitive, and should not be used below 10 degree C, and the slower the setting time of the type you select, the stronger the bond. Regards Brian B |
JasonB | 17/01/2022 12:21:24 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | Not used any for a while but Zap make some decent ones though may be more than you want in teh two 4oz bottles Or Araldite Crystal has around a 20min working time Edited By JasonB on 17/01/2022 12:27:33 |
John Smith 47 | 17/01/2022 12:41:12 |
393 forum posts 12 photos | Posted by JasonB on 17/01/2022 12:21:24:
Not used any for a while but Zap make some decent ones though may be more than you want in teh two 4oz bottles Or Araldite Crystal has around a 20min working time Edited By JasonB on 17/01/2022 12:27:33 Zap looks promising. I need a faster supplier though. Yandles only seem to do 2nd class post.
Edited By John Smith 47 on 17/01/2022 12:41:41 |
SillyOldDuffer | 17/01/2022 13:16:30 |
Moderator 8469 forum posts 1885 photos | Posted by John Smith 47 on 17/01/2022 12:41:12:
Zap looks promising. I need a faster supplier though. Yandles only seem to do 2nd class post. ... Rejecting a glue because the supplier only does 2nd class post seems pretty daft to me! The requirement is tricky enough without adding non-technical obstacles. Focussing on what matters saves a lot of time and effort in engineering. Be careful - it's all too easy to be distracted by trivia and red herrings. Unless working to an important fixed deadline a short postal delay won't alter the price of fish. Impatience is a sin. It's never a good reason for doing anything. Dave |
Ramon Wilson | 17/01/2022 13:20:46 |
![]() 1283 forum posts 367 photos | I have used Zap epoxies for several years now. About the best available at the moment in reasonable small volumes but there are others. An eBay search should get you a rapid supplier - I bought my last from 'Als Hobbies. 5, 15 and 30 min all available in 2oz and 4oz sizes Tug |
John Smith 47 | 17/01/2022 13:37:02 |
393 forum posts 12 photos | To answer my own question, I have found this stuff: "MID-CURE epoxy 15min (BSI203)" made by Bob Smith Industries (BSI)
In truth, a working time of only 10 minutes is still a BIT fast for me. However it is certainly much better than their "5 min" Quik-Cure™ Epoxy, which begins to set in 4 or 5 minutes, in my experience. J
Edited By John Smith 47 on 17/01/2022 13:46:21 |
John Smith 47 | 17/01/2022 13:50:03 |
393 forum posts 12 photos | Posted by Ramon Wilson on 17/01/2022 13:20:46:
I have used Zap epoxies for several years now. About the best available at the moment in reasonable small volumes but there are others. An eBay search should get you a rapid supplier - I bought my last from 'Als Hobbies. 5, 15 and 30 min all available in 2oz and 4oz sizes Tug Noted. Thanks. |
Nicholas Wheeler 1 | 17/01/2022 14:01:36 |
906 forum posts 86 photos | You need to speak to the technical department of a glue manufacturer. It's just the sort of question they're for. |
JasonB | 17/01/2022 14:05:47 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | Order the Zap from here in the next hour and you will have it tomorrow But I don't suppose you will want to pay the premium for fast delivery Edited By JasonB on 17/01/2022 14:06:50 |
Joseph Noci 1 | 17/01/2022 14:15:27 |
1069 forum posts 1307 photos | +1 for ZAP epoxies - I use it extensively building these...Works very well
Derek Lane | 17/01/2022 14:24:04 |
![]() 719 forum posts 164 photos | +1 for Zap epoxy I use the 5 minute one but it is a good glue |
Ramon Wilson | 17/01/2022 14:30:15 |
![]() 1283 forum posts 367 photos | John (Smith) I was not aware Bob Smith Industries glues were available in the UK. Their CA glues are well recommended in USA so would 'assume' (not always a good idea!) that their epoxy would be of a similar quality. I'll certainly be ordering some epoxy and CA to try out and compare with the Zap I usually search eBay mainly to see the variation in price of items - amazing sometimes the considerable differences in cost of some products - never had an issue with archived purchases either but each to his own Thanks for that link Tug |
John Smith 47 | 17/01/2022 16:35:14 |
393 forum posts 12 photos | Do any of you have experience of Zap's "Z-Poxy 30 Minute" epoxy resin adhesive? J Edited By John Smith 47 on 17/01/2022 16:36:05 |
Michael Gilligan | 17/01/2022 16:44:56 |
![]() 20057 forum posts 1040 photos | Posted by John Smith 47 on 17/01/2022 16:35:14:
[…] . It’s none of my business, John … but I will ask anyway : For the trivial sum that you are [presumably] spending at this stage; do you really need a VAT invoice ? MichaelG. Edited By Michael Gilligan on 17/01/2022 16:48:57 |
ega | 17/01/2022 16:57:52 |
2487 forum posts 199 photos | Whatever happened to Araldite? I think they used to have a technical department which would advise on questions like this? What about the West brand, too? |
Ramon Wilson | 17/01/2022 16:59:27 |
![]() 1283 forum posts 367 photos | Posted by John Smith 47 on 17/01/2022 16:35:14:
Yes - Zap 30 min has around 25-30 mins work time depending on the ambient temperature. It my workshop - usually around 65C it will begin to gel after about 20mins. Once that begins there is little time left to work with. I find a good hour has to pass before handling it with safety but that of course depends on what the workpiece actually is.
Tug |
John Smith 47 | 18/01/2022 15:32:10 |
393 forum posts 12 photos | Zap Epoxy seems to have a lot fans here.
John Smith 47 | 18/01/2022 15:35:13 |
393 forum posts 12 photos | Posted by Michael Gilligan on 17/01/2022 16:44:56:
J
Michael Gilligan | 18/01/2022 16:03:14 |
![]() 20057 forum posts 1040 photos | Posted by John Smith 47 on 18/01/2022 15:35:13:
. . i.e.
Oh well MichaelG. |
