John Smith 47 | 14/01/2022 14:58:21 |
393 forum posts 12 photos | Hello I need to glue/bond ABS plastic (Acrylonitrile Butadiene Styrene) onto NRL (Natural Rubber Latex). Any suggestions? Edited By John Smith 47 on 14/01/2022 14:59:30 |
Dave S | 14/01/2022 17:52:14 |
361 forum posts 90 photos | Are you covering the abs with a layer of rubber, joining abs to rubber to something else? Geometry of the joint may make a difference to recommendations. Do you need the glue to be thin as possible, or is a thick glue line acceptable? Often rubber bits on plastic are 2 shot moulded - the plastic is molded the loaded into another mold and the rubber injected. The surface design of the plastic substrate and the heat assist in a bond. More info will help a better answer, but in the absence of it (cos it’s bound to be secret and “not relevant&rdquo
Michael Gilligan | 14/01/2022 18:01:10 |
![]() 20057 forum posts 1040 photos | Double-sided tape [as used by carpet-fitters] might do the job neatly. … but, of course, it has zero working-time, so you would need to get positioning ‘right first time’ MichaelG. |
Ady1 | 14/01/2022 18:09:53 |
![]() 5065 forum posts 734 photos | pinkgrip Everything I've done with it has kept going and going Changed the angle of my bandsaw blade a year ago by using it on rubber/aluminium and here we are a year later with no issues so far Edited By Ady1 on 14/01/2022 18:23:15 |
JasonB | 14/01/2022 18:34:24 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | If it was not for the slow setting requirement then Loctite 380 "blackmax" would do nicely |
Engine Doctor ( Phil ) | 14/01/2022 19:58:09 |
![]() 18 forum posts 1 photos | Use a slow setting Cyanocryalate (cyano or super Glue) for a permanent no creep bond . Generally the thicker superglues are slower. |
John Smith 47 | 14/01/2022 21:09:51 |
393 forum posts 12 photos | Posted by Dave S on 14/01/2022 17:52:14:
> Are you covering the abs with a layer of rubber, joining abs to rubber to something else? > Often rubber bits on plastic are 2 shot moulded
It certainly is amazingly tacky! (i.e. sticky) The results can be seriously smart, and with care it is slightly (but not very) repositionable, in that with patience you can generally peel it back off a solid surface.
John Smith 47 | 14/01/2022 21:17:26 |
393 forum posts 12 photos | Posted by Ady1 on 14/01/2022 18:09:53:
pinkgrip Everything I've done with it has kept going and going Changed the angle of my bandsaw blade a year ago by using it on rubber/aluminium and here we are a year later with no issues so far Edited By Ady1 on 14/01/2022 18:23:15 Have you tried Pinkgrip with rubber? I couldn't see any mention of rubber... |
Robert Atkinson 2 | 14/01/2022 21:24:18 |
![]() 1195 forum posts 20 photos | + 1 for 3M VHB tape suggested by John. If you need fiddle time wet one of the surfaces with water. Second choice would be a toughened acrylic adhesive such as Loctite Multibond 330. Permabond also make these. They are a clear glue (like UHU) but it needs an activator brushed on one surface. In this case ativator goes on the ABS Robert G8RPI. |
John Smith 47 | 14/01/2022 21:37:40 |
393 forum posts 12 photos | Posted by Philip Fearn on 14/01/2022 19:58:09:
Use a slow setting Cyanocryalate (cyano or super Glue) for a permanent no creep bond . Generally the thicker superglues are slower. I did try a couple of different types of Superglue. One had extremely strong instant grab and was an instant disaster. The other was slightly less aggressive, but there was very little repositioning and the rubber quickly swelled like crazy causing it to curl. Also CA seems to denature the rubber, and any spillage on the front surface will leave a nasty reflective marking. If all else fails, I could probably get it to work... but to be honest I've always rather hated CA, because:
John Smith 47 | 14/01/2022 21:46:20 |
393 forum posts 12 photos | Posted by Robert Atkinson 2 on 14/01/2022 21:24:18:
+ 1 for 3M VHB tape suggested by John. If you need fiddle time wet one of the surfaces with water. Interesting suggestion. For precision work, would you literally paint water on with a paintbrush? Or try to use a fine spray/mist? Either way does the bond end up being just as strong as normal? J
Robert Atkinson 2 | 15/01/2022 15:15:15 |
![]() 1195 forum posts 20 photos | Spray / mist is best. A tiny amount, literaly a drop in a liter of washing up liquid can help with wetting. Final bond is just as good as dry but takes longer. pressing on join forces the water out. Edited By Robert Atkinson 2 on 15/01/2022 15:16:31 |
John Smith 47 | 15/01/2022 16:50:31 |
393 forum posts 12 photos | Posted by Robert Atkinson 2 on 15/01/2022 15:15:15:
Spray / mist is best. A tiny amount, literaly a drop in a liter of washing up liquid can help with wetting. Final bond is just as good as dry but takes longer. pressing on join forces the water out. Edited By Robert Atkinson 2 on 15/01/2022 15:16:31 Extremely interesting. I now just need to find a sprayer somewhere! |
Frances IoM | 15/01/2022 17:49:10 |
1247 forum posts 28 photos | ask a friend for an empty perfume bottle - they usually produce a fine mist. |
Robert Atkinson 2 | 15/01/2022 18:58:03 |
![]() 1195 forum posts 20 photos | 3M VHB stays flexable long term. It' used for things like sticking th aluminium sides of commercial vehicles on. |
Gerhard Novak | 15/01/2022 21:16:55 |
![]() 109 forum posts 114 photos | I would be careful with long term bond strength. If one of the materials contains a softener (I suppose the NR compound would, I am not sure about the tape itself) you could get softener migration which could either make the material brittle or slimy sticky in the contact area. Best thing is to try, it may be fine for a long time. I don't think UV is a problem for the 3M material, there are many additives on the market which prevent accelerated ageing by UV rays. |
John Smith 47 | 20/01/2022 22:57:41 |
393 forum posts 12 photos | OK, 3M's VHB is a failure. B. Dowsil 732 ("Multi-Purpose Silicone Sealant" ) C. Elastosil E41 from Wacker ("Moisture Curing Silicone Rubber" ) Edited By John Smith 47 on 20/01/2022 22:58:15 |
Dave S | 21/01/2022 08:22:37 |
361 forum posts 90 photos | When hunting a Unicorn it is usually best to start with the Unicorn breeders Henkel, Sika both have very helpful technical teams
Gerhard Novak | 21/01/2022 08:43:59 |
![]() 109 forum posts 114 photos | If you want a really good bond from a tape try a worktop edge one, like UNIKA worktop tape. available for 6£ from screwfix. Bond is incedible strong, tape is quite thin. What I said a few posts up is still valid - you don't know about the long term performance. |
Robert Atkinson 2 | 21/01/2022 08:59:39 |
![]() 1195 forum posts 20 photos | Rubber to ABS with high dynamic peel forces is a severe challenge for any adhesive. I wish you luck but won't be placing any bets...... Robert G8RPI. |
