Milling machine, but which brand ?
Die Hardenedbedway12/01/2022 16:46:02
30 forum posts
14 photos
Hi all
Undecided on what machine to go for. I have a small clapped out warco mill which needs replacing, however, looking around I see that most of them from differing suppliers are pretty much the same machine apart from a paint job !
I dont mind spending a few quid but Id rather not buy the 'same' machine as I have now, after all, theyre all probably made in the same place.
Im looking for compact desk version rather than a free standing. Any ideas other than Chester, Axminster or Warco ?
Ta all
C
Oldiron12/01/2022 17:02:37
960 forum posts
40 photos
Many many posts on here about that subject. Try a search. It will bring many answers.
regards
Former Member12/01/2022 17:07:06
1085 forum posts
Journeyman12/01/2022 17:09:44
1146 forum posts
230 photos
Not that many manufactures but lots of brands! Most of the Warco, Chester, Amadeal, SPG are variations on a theme made by Weiss. The other manufacturers are Sieg (Arc, Axminster) and Some of the European manufacturers/finishers like Optimum and Wabeco. If you want Wabeco you need deep pockets. If not one of these then you are looking for good used but these are often ex-industrial and a bit larger. (Further thoughts on milling machines *** HERE ***)
Martyn Edwards 212/01/2022 17:10:31
18 forum posts
34 photos
Have a look at Sieg bench top Mills. Personally I believe they're a step above Warco offerings in terms of quality. Have seen both being manufactured in China in their respective factories.
Trevor Drabble12/01/2022 18:01:20
280 forum posts
5 photos
DH , The Centec that G&M have for sale of any interest ?
Die Hardenedbedway13/01/2022 08:20:55
30 forum posts
14 photos
Cheers folks.. so many options !
@Martyn Looking at the Seig, this one looks quite nice and feature rich ? SIEG SX3.5ZP
Thor 🇳🇴13/01/2022 10:11:07
1598 forum posts
45 photos
The Sieg SX3.5ZP is a nice milling machine with a motor to lift the head and with powerfeed. If I didn't already have a milling machine from Weiss, the Sieg would be of interest to me. A friend of mine owns a SX3 and is very happy with his.
Thor
Die Hardenedbedway25/01/2022 06:26:51
30 forum posts
14 photos
I went for the SIEG SX3.5ZP in the end. As Martyn says, it does seem to be a notch above the Warco in terms of build quality.
old mart25/01/2022 12:16:10
3717 forum posts
233 photos
An excellent choice for a benchtop, with a higher than average spec.
Thor 🇳🇴25/01/2022 12:55:36
1598 forum posts
45 photos
Congratulations with your new Sieg SX3.5, let us know how you get on with your new toy.
Thor
Bazyle25/01/2022 18:15:33
6295 forum posts
222 photos
Posted by old mart on 25/01/2022 12:16:10:
But your benchtop looks a bit flimsy and may vibrate. If you pull it forward to give your knuckle some respite on that Y axis handle you will keep knocking it. So I suggest finding a heavy (council spec) 3x2 paving slab to raise it up and give you a solid base.
Die Hardenedbedway25/01/2022 18:23:24
30 forum posts
14 photos
Yes. Im going to put it on some risers and bolt through. The bench is solid enough I think. Its on 20mm ply on top of a hard wood top of around 15mm. The bench is then fixed to batons along the shed. Its not super unmovable but good enough for me I recon.
Steviegtr25/01/2022 22:24:35
2421 forum posts
336 photos
Very nice. They have a good spec too. Congrats.
Steve.
Dreweatts
Rapid RC
