Sam Longley 1 | 09/01/2022 09:19:03 |
948 forum posts 34 photos | Hopefully someone can help me here but I am having a bad hair day I am refurbishing the cab on our club Ford 4000 tractor & it involves removing some of the glass panels, dealing with rust, then replacing the glass. The glass is held in with a simple "H" section strip. I want to replicate that strip - I do NOT want the types with inserts etc - just the H type that one fixes with a cord. I have spent the last hour on tractor sites, auto factors & rubber seal sites but no one seems to do it. Plus I am having problems knowing what to google to find it. I keep coming up with door & window draught excluder strips Does anyone, into vehicle restoration, know where I can get a cheap H section strip, or what I should be googling for, please. I probably need about 10-15 metres, but not sure yet. Money is tight so I am very limited on spend Thanks Sam Longley Edited By Sam Longley 1 on 09/01/2022 09:19:51 |
martin haysom | 09/01/2022 09:50:46 |
![]() 107 forum posts | woolies sell this sort of stuff google woolies car restoration cos if you just put in woolies you get information about a high street shop |
Former Member | 09/01/2022 09:56:38 |
1085 forum posts | [This posting has been removed] |
Sam Longley 1 | 09/01/2022 09:57:44 |
948 forum posts 34 photos | martin Thanks, But unfortunately they do not list the simple "H" section. Only the one with the break in the front. Edited By Sam Longley 1 on 09/01/2022 10:06:41 |
Andy Stopford | 09/01/2022 10:28:40 |
166 forum posts 25 photos | Try COH Baines of Tunbridge Wells |
pgk pgk | 09/01/2022 10:36:18 |
2605 forum posts 293 photos | Googling 'H section vehicle weatherstrip' might find what you need. Or try your local agri engineers for help. pgk |
Gerald Howarth | 09/01/2022 10:49:39 |
6 forum posts | Could try Seals Direct, https://www.sealsdirect.co.uk/, they seem to have most shapes in their catalogue. |
Sam Longley 1 | 09/01/2022 11:19:26 |
948 forum posts 34 photos | Posted by Gerald Howarth on 09/01/2022 10:49:39:
Could try Seals Direct, https://www.sealsdirect.co.uk/, they seem to have most shapes in their catalogue. Thanks but All the filler type |
Sam Longley 1 | 09/01/2022 11:42:13 |
948 forum posts 34 photos | Posted by Andy Stopford on 09/01/2022 10:28:40:
Try COH Baines of Tunbridge Wells Hurrah, Hurrah- Thankyou ,Thankyou Finally found it. Someone who does the actual section I was looking for & it is cheap( relatively that is!!) as well Really apreciate that ---Thanks for the link Sam Longley Edited By Sam Longley 1 on 09/01/2022 11:43:03 |
Speedy Builder5 | 09/01/2022 12:45:44 |
2653 forum posts 219 photos | Plus 1 for Seals Direct. Ring them up as they have some odd sections not listed. Used them on my Citroen 2CV windows. Good tip, fit the seals on a warm day especially if you have tight radius on the corners. |
Sam Longley 1 | 09/01/2022 13:10:01 |
948 forum posts 34 photos | Posted by Speedy Builder5 on 09/01/2022 12:45:44:
Good tip, fit the seals on a warm day especially if you have tight radius on the corners. I have completely dismantled the cab & it is in my workshop for painting etc. so I will follow that advice & turn the heat up. I will not need a lot of persuasion in this weather. Thanks. |
