48dp Muffett spur gears wanted
Richard Smith 1302/01/2022 12:57:07
2 forum posts
I have twice written to Muffetts to try and buy some of their steel spur gears - I am building a Chenery Gnome engine and he calls for 9 of their standard products. They have not replied to either email, has anyone else attempted to buy from them?
Thanks for any help.
Richard
Michael Gilligan02/01/2022 13:47:56
20057 forum posts
1040 photos
Is this the Muffett in question, Richard ?
**LINK** : https://www.muffettgears.co.uk
… it doesn’t look like they do ‘standard gears’ these days dont know
I wonder if the business has been restructured.
JasonB02/01/2022 14:06:26
22560 forum posts
2634 photos
As Michael says I don't think they do "stock" gears anymore and would likely be quite expensive to get them to make up a set.
The spur gears should be easy enough to cut or source from elsewhere and the worm and wheel could be hobbed with a tap as Stephen Wessel did with his 1/3rd version
Assuming they are DP take a look at HPC who do carry a good range off the shelf if you prefer to buy.
Keith Long02/01/2022 14:47:57
876 forum posts
11 photos
Be worth looking at SMD Direct as well **LINK** it looks as though they have a pretty comprehensive range and are priced individually. An internet search of 48dp gears throws up a lot of options as they are used in rc cars amongst other things.
Edited By Keith Long on 02/01/2022 14:56:39
Richard Smith 1302/01/2022 16:53:11
2 forum posts
Thank you both, good information, useful to know. The ones at SMD are alloy so I will do it according to drawing and use the steel ones from HPC. It will be slightly cheaper than buying the gear cutters - I don't have any at all and because I need 16, 24, 32 and 72 tooth gears it will be four new cutters at £25 each.
Richard
Andy Stopford02/01/2022 19:20:52
155 forum posts
17 photos
Posted by Michael Gilligan on 02/01/2022 13:47:56:
I think you're probably right there Michael, their factory has a rather intimidatingly corporate look now, not like the old days behind the bus station when you could just wander in in search of bits of bronze.
Rapid RC
Dreweatts
