What Did you do Today 2022
JasonB01/01/2022 07:11:16
22559 forum posts
2634 photos
Please use this new thread from now on, last year's is here
OldMetaller01/01/2022 09:29:02
202 forum posts
25 photos
I got 2022 off to a good start by finishing the Guardian quick crossword in under four minutes, a personal best, and that was whilst fending off the cat, who thinks she's helping.
Hopefully I'll get the workshop tidied up today, and get my G3 wagons finished to clear the decks for the new loco.
Happy New Year to all!
John.
roy entwistle01/01/2022 09:35:38
1504 forum posts
Just got up 9-15am and have no intention of doing much. Happy new year to all
Roy
Derek Lane01/01/2022 11:15:41
719 forum posts
164 photos
Ordered metal and some tooling so that I can make a start on my first project this year. The adventure begins as well as many hours of learning along with some mistakes I am sure will happen. As I say "Those that never made a mistake never made anything" and I have made my fair share when making models from wood.
Some of my work
Most are just slide shows and excuse the music on some just turn off the sound
Edited By Derek Lane on 01/01/2022 11:16:52
David George 101/01/2022 12:22:10
1808 forum posts
503 photos
Polished a Lincoln Imp car mascot I found in father-in-law,s workshop when clearing it.
Something to do.
David
Edited By David George 1 on 01/01/2022 12:23:00
sean logie01/01/2022 20:31:24
605 forum posts
7 photos
Up at 5am (normal for me) cleaned up my wee shed ,it'll only take 5 min and it'll be back where it was , some repairs to the lathe and caravan . Then did some contemplating .
Sean
Nicholas Wheeler 101/01/2022 21:36:12
906 forum posts
86 photos
Finished the Mx5 engine and gearbox mounts for a friend's Cortina based kit car, and bolted the parts in place. Then we refitted the body, admired his wheel and tyre combination, added the radiator and intake trunking to see if there's room(barely) and discussed the way to get the seats, pedals, steering column, dash and Land Rover windscreen installed.
That's a good day, as it now looks like a car rather than a pile of junk. Although there is plenty of that left over from a very rusty Mazda.
bricky01/01/2022 22:34:51
571 forum posts
68 photos
Made three plug guages to fit a ball race a existing bored gear and a pulley so that I could get accurate readings when I make the arbour for all three.This is a part for the making of a shaper which I am trying to finish when the original maker died and left it 80% complete but with no idea of his thinking I am makeing the most of it.The plans are labled putnook but he never followed them completely which is making it difficult.
Frank
John Haine03/01/2022 18:21:49
4622 forum posts
273 photos
Nearly 3 years ago I posted about the cross-slide homing system I installed on my CNC Super 7. Despite scepticism at the time it has worked fine ever since, but I have been aware that the homing accuracy has slightly degraded. This I think is mainly due to the slight deformation of the fixed contact pad that gets grounded by a sprung rod on the slide. The pad had a beryllium copper plate soldered to a piece of PCB - the bit that is contacted by the rod has developed a little "dimple" with time, because the BeCu plate wasn't soldered flush and had a little cavity behind it.
Finally I got round to making a new contact block. This is made from Corian with a beryllium copper plate glued to its surface (using Gorilla Glue clear).
Already I've managed to get a greasy fingerprint on it. Spent a tedious couple of hours recalibrating all my lathe tools that are fixed in QC toolholders.
Derek Lane06/01/2022 16:48:17
719 forum posts
164 photos
Spent the first part of the afternoon sorting out my metal delivery like cleaning the ends of some bar stock and stamping that with type of steel the smaller piece I had to resort to using a power engraver. I followed that up be doing some woodturning which I had not been able to do properly for 9 months due to renovations and new workshop rebuild.
Now that I have the metal and plans for the Rob Roy I want to build I may be able to make a start still waiting for some numbered drill bits to arrive to drill these as well as the build book(Thought that maybe helpful during the build)
Derek Lane12/01/2022 17:50:23
719 forum posts
164 photos
At last I have now started my first model it is a Rob Roy loco, frames rough cut to size with a little extra so that I can mill off where the steel was cut on a guillotine. Holes drilled so that I can rivet them together. I am sure I will make mistakes but it is only metal at the end of the day I will also learn plenty.
I have spent quite a few hours studying the plans for the frames and working out the best way to approach the work hopefully without having to move them too many times. I am going to buy some storage boxes for parts so that I can keep them safe.
Wish me luck I have already forgotten how many times I have measured just the two frames before even cutting them.
I do have a plan of attack and will be breaking the model down into small projects and only thinking about that section that I am working on but also being mindful of other parts adjacent checking the measurements marry up just in case of any the plans do have any measurement mismatches.
DiogenesII12/01/2022 19:07:23
516 forum posts
202 photos
Good luck and happy engineering, Derek, sure it will go well!
Derek Lane13/01/2022 17:20:13
719 forum posts
164 photos
Posted by DiogenesII on 12/01/2022 19:07:23:
Thank you.
The journey begins spent the day riveting the two plates together and the set up on the mill cleaned up the left edge and long edge so that the rivets are close to the centre of the horn cutouts. I did give the right side a clean up so that it was parallel to the left edge but not yet down to the right length of the chassis.
I will be using the bottom right as a datum to start with as not all measurements are not taken from there so may have to change that as I go along luckily I have the DRO to assist in this
The beginning
Bazyle13/01/2022 22:56:17
6295 forum posts
222 photos
Derek. You have obviously been on the site for some time so I hope you have read the other threads about the Rob Roy valve gear not lining up.
Derek Lane14/01/2022 07:50:04
719 forum posts
164 photos
Posted by Bazyle on 13/01/2022 22:56:17:
Not yet but will have a look as it is 4 of the holes on the chassis need moving this is the first I know of and there are some others that I am aware of but not taken any notice of until I move to the next stage to check if any are needed then. One piece at a time.
KWIL14/01/2022 09:23:43
3549 forum posts
70 photos
One suggestion is that you provide some form of "fence" in the rear table slot. That would enable you to replace the frames (should you need to) in exactly the same place front to back with only the side to side movement to be finely adjusted.
Derek Lane14/01/2022 10:12:22
719 forum posts
164 photos
Posted by KWIL on 14/01/2022 09:23:43:
Thank you for that tip worth thinking about but as it stands I will be doing a lot of work 90% on these without having to take them off the mill just move the clamps one at a time to mill the back edge of the plates to the correct width and take out a 3/8" along just under half the length.
All tips are very much welcome. I know that many will say that I should have started with a simpler model but I felt that this was not beyond me with a little pre-planning , One of my  favourite subjects when I was at school(I will not say how many years ago) was  technical drawing so reading plans is fairly easy, and as I stated there will be mistakes but I am prepared to learn from them as well as tips that I am offered.
As I have put on the bottom of posts I make on woodworking sites "He who never made a mistake never made anything"
Edited By Derek Lane on 14/01/2022 10:24:58
Chris Mate14/01/2022 16:44:59
136 forum posts
32 photos
Made 2x fixtures that bolt to the lower bed each side(Can be easily removed) to adjust the swivel bed accurately square without tapping it..
Decided to mill the fixtures flat to fit to bed, very happy with some milling for the 1st time, and how the quil fine asdjustment worked.
Previously ightend the MT4 Drill chuck as suggested on this forum with drawbar. Had no problem removing it, just one light tap with aliminium mallet. Replaced with Facemill that came with milling machine.
Rob McSweeney14/01/2022 16:54:20
73 forum posts
For the first time in ages I have something worth reporting. Finished laying plastic gravel grid and put down the gravel base in readiness for my new shed. We had the electrician working in the house this morning, so was able to discuss the outside power supply and shed wiring with him, I await his quote.
lee webster14/01/2022 17:15:01
43 forum posts
5 photos
OldMettaler.
A friend and I used to do the Guardian cryptic prize crossword. We won it three times, once in her name, once in mine and just for a laugh we entered in the name of my friends cat Lizzie. She won!
Rapid RC
Dreweatts
