anadale 210v-g lathe
varible speed
gordon brian davies29/12/2021 20:21:11
1 forum posts
hi, there everyone im new to this hobby which i enjoy experimenting trying to
make things on my lathe, i have a anadale 210-g varible speed lathe,the varible
speed does not run at constant speed when set, any one come akros the same
problem? im down in carmarthenshire thanks
Andy_G30/12/2021 10:38:55
167 forum posts
Hi, Do you mean an Amadeal 210V lathe?
https://www.amadeal.co.uk/acatalog/AMAT210V.html
Is the problem that the speed varies as you start to cut, or does it just run erratically, even with no load?
If the latter, I would look first for sticking or worn brushes in the motor, and if there wasn't a problem there, it could be a worn control potentiometer (they're not good quality and do fail).
Pete Cordell30/12/2021 11:07:47
15 forum posts
I would give the potentiometer speed controler a clean with some switch cleaner
Rapid RC
Dreweatts
