Gas Mark what for a crankcase?
Iain Downs | 23/12/2021 16:56:29 |
852 forum posts 747 photos | I have recently been attempting to paint my vertical mill engine. I have chosen rust-oleum black BBQ paint based on reviews. However, things have not gone as well as they might. I suspect that one reason is that I was painting them initially in a damp workshop at a low temperature. Only later did I read the instructions that said, 'not below 10 degrees'. The symptoms are two-fold. Firstly, the paint seems to chip off with a strong glare and secondly, the parts remain tacky (sticking to worktop surfaces, paper and the like) over a week after being painted. With a later batch, I kept them and the paint inside and had the shed heater on for an hour or so before painting (so only a bit under 10 degrees, but paint and parts at 18 - 20) and that seems to have gone better. It's been suggested that sometimes these paints need to be baked before they set properly. I'm up for that and have gained permission from SWMBO to do some cooking tomorrow. I should note that this paint does not appear to need baking either from the website or reviews, but may be worth a try. But at what temperature and for how long? The largest pieces are the flyhweel (2kg) and crankcase (3.3kg). I look forward to your advice!
Iain |
pgk pgk | 23/12/2021 17:25:06 |
2549 forum posts 293 photos | My wife has a lot of experience at baking things black. She says that temperature is less important than time and best to wait until the smell of burning gets to another room... Get shed properly warm before further attempts pgk |
david homer | 23/12/2021 18:36:33 |
35 forum posts | Phoenix Precision Paints do a Higher temp paint in their range of Cherry Paints maybe be a little more expensive, haven't used my tin yet but have used their normal temp black and it gives a good finish. They recommended it for a loco smoke box. David |
david homer | 23/12/2021 18:44:05 |
35 forum posts | I should add that it does not need baking to cure it and it is recommended that you paint below 10 degrees C David |
JasonB | 23/12/2021 18:49:10 |
![]() Moderator 22560 forum posts 2634 photos 1 articles | You don't mention any cleaning or degreasing before painting, you should at least wipe the parts down with a solvent first to remove any traces of oil from the surface. Cold metal in the workshop will be the ideal place for warm moist air from your breath to condense onto and paint does not take too well to a steamed up damp surface. I always bring any paint I intend to use into the house the night before at this time of year and more often than not the parts too. Warm paint is thinner so will come out of the can in finer droplets and the combination of warm paint and metal will allow the paint to gas off faster and flow out better. Once they are touch dry they come back inside to sit near a radiator overnight. I've not used that particular one but the Thermacure I usually use on exhausts and flame lickers etc does need backing to fully cure but the VHT colours don't |
DMB | 23/12/2021 21:11:42 |
1293 forum posts 1 photos | As a matter of interest, when I was in a fellow club members workshop in his house, spare double bedroom, I saw a model aircraft fuselage, nose down on floor and tail near ceiling, it was that big. I asked him how he got such a wonderful paint finish on it, dead smooth, looked like it was plastic. He said he warms the tin of paint and applies it hot so it runs, eliminating brush marks and leaves an even coating. |
larry phelan 1 | 24/12/2021 16:30:40 |
1169 forum posts 15 photos | Put the job in the oven with the turkey ! Both results should be interesting. ! Many years ago, I recall using standard spray paint on a job, put it in the gas oven for a short time, no idea how long, low heat ,and the result was good. Worth a try. |
old Al | 24/12/2021 17:20:19 |
186 forum posts | Painting in the cold is nor recommended and if it doesnt cure in a week, its best removed and done on a warmer ,dryer day. Even after 40 years, i still try my luck, but getting good at stripping paint now |
david homer | 24/12/2021 17:46:22 |
35 forum posts | if you look at this link it gives some information about painting with Phoenix Paints and temperature, of course it may not apply to other makes, I have been doing some with both a brush and an airbrush in an unheated garage with no problems. Parts were placed in garage before hand and paint taken out at time of application. https://www.phoenix-paints.co.uk/application-of-precision-paints-and-temperature David |
Neil Wyatt | 24/12/2021 21:08:43 |
![]() Moderator 18990 forum posts 734 photos 80 articles | This is curious. Barbeque paint is ideal for blacking the inside of telescopes as it doesn't reflect infra-red light, unlike ordinary matt black paint. I have sprayed the inside of a 12" diameter tube with it, but I'm not sure if it was Rustoleum or not (a good chance it was). I recall that a coat was dry very quickly, although taking a bit longer in the middle of the tube, but under an hour.
I once had problems with a can of paint that wouldn't set after weeks; the manufacturers were at a loss to say what the issue was.
Neil |
Iain Downs | 29/12/2021 10:52:17 |
852 forum posts 747 photos | Thanks for all the responses.. I ended up baking at 120 C for about 40 minutes after a gentle warm up fro 15 mins at 60 degrees. Don't ask me why I picked these numbers, there wasn't much science behind it. I thought that over 100 C was needed but felt it would be better with a more gradual heat up than just sticking it on at 120 C to start with. The results? Well, in general I would say successful. It's all murky and subjective of course, but the paint seems much more stable, though it is a bit prone to chipping / scraping on the sharp(ish) edges. On the other side, as I handle the pieces, I find my fingers getting dirty (even after cleaning the pieces with a damp cloth), so I'm not sure it's entirely successful. In short - a success, but certainly the better approach is to start in a warm place!
Iain |
duncan webster | 29/12/2021 11:22:22 |
3919 forum posts 61 photos | Posted by Neil Wyatt on 24/12/2021 21:08:43:
This is curious. Barbeque paint is ideal for blacking the inside of telescopes as it doesn't reflect infra-red light, unlike ordinary matt black paint..........
Neil I had this problem with a reflective opto sensor, painting a mark on a pulley. Blackboard paint worked, but a slight film of oil seemed to go back to not working. Quick wipe with white spirit sorted it for another few weeks. |
Nigel Graham 2 | 29/12/2021 11:34:11 |
2009 forum posts 27 photos | Some paints intended for hot work will not cure at all, at ordinary temperatures, so it may be wise to carry out a little research first. I recall once at work we wanted to paint the wooden transport-cases for certain items, black to hide their origins. The boxes were in normal grey paint with stencilled lettering. One of the group obligingly bought a tin of black paint from a local ironmongers, and we applied it; all over the box, not just the sign-writing. People were still getting black marks on their hands from it three years later, though by then the surface was more powdery than sticky. The tin was clearly marked "stove paint" with a note on its purpose! |
Steve355 | 29/12/2021 13:11:37 |
215 forum posts 150 photos | I’ve had good results with Paragon paints recently, in a fairly damp and cold shed environment, and it curing nicely it seems, and fairly quickly. Also the nicest surprise was the amount I needed, I bought 2.5 litres and must have used 0.5 litres for two coats on my horizontal mill. Enough to do 4 more. If only I’d known that when I bought the stuff. Steve |
the artfull-codger | 29/12/2021 16:28:30 |
![]() 294 forum posts 28 photos | I use smith & allan vehicle enamel for models & also for all my alloy castings ,but I allways 2 pack etch prime everything first as paint just chips off alloy & brass if not etch primed ,it sprays, airbrushes & brush paints well & then into the rayburn cooler bottom oven overnight,& I don't need the mrs "permission" either!!.for spraying I thin with cellulose thinners. or white spirit if needed for brush painting Edited By the artfull-codger on 29/12/2021 16:30:34 |
