John Billard 1 | 06/12/2021 22:35:35 |
108 forum posts | Is type correction fluid, e.g. Tippex, the thing for this? John B
Dave Smith 14 | 06/12/2021 22:57:58 |
212 forum posts 43 photos | Yes. |
JA | 06/12/2021 23:03:10 |
![]() 1345 forum posts 80 photos | Yes, yes. It works. If you have doubts use more than one coat. After Dave's reply. JA |
JasonB | 07/12/2021 06:54:24 |
![]() Moderator 22588 forum posts 2641 photos 1 articles | Best if it is the solvent based one. |
Bo'sun | 07/12/2021 08:20:54 |
602 forum posts 2 photos | Best stock up on it, typewriters are probably a thing of the past. |
Baz | 07/12/2021 08:38:23 |
713 forum posts 2 photos | +1 for Tippex, a lead pencil also works fairly well. |
Circlip | 07/12/2021 10:10:47 |
1500 forum posts | Is solvent based Tip-ex still available? Solvent used was Trichlorethane, H and S and all that garbage. Regards Ian. |
Massimo Dalmonte | 07/12/2021 10:13:13 |
33 forum posts 18 photos | A "paint" made with jeweller's rouge and water, applied with a brush, works too. Best regards, Massimo |
JasonB | 07/12/2021 10:17:24 |
![]() Moderator 22588 forum posts 2641 photos 1 articles | Posted by Circlip on 07/12/2021 10:10:47:
Is solvent based Tip-ex still available? Solvent used was Trichlorethane, H and S and all that garbage. Regards Ian. Yes but now has a different solvent here Edited By JasonB on 07/12/2021 10:20:25 |
Circlip | 07/12/2021 10:35:00 |
1500 forum posts | Thanks for that Jason, seems due to all the precautions stated, Tip-ex shouldn't be exposed to any heat source and Naptha has a slower evaporation rate than Trike. Regards Ian.
Baz | 07/12/2021 13:24:16 |
713 forum posts 2 photos | When I was working we used to use a Nikrobraz stop off pen, very similar to a felt tip pen, it deposited a very light green liquid a bit thinner than Tippex on to the work, we have were using it in a vacuum furnace and it worked perfectly every time. Just need now to find someone who sells the pens in small quantities. |
john fletcher 1 | 07/12/2021 14:49:04 |
785 forum posts | Years ago when Men were men, plumbers would wipe a lead pipe and under ground cable jointers would make a live joint, they used "Plumbers Black" as a resist. It came In a Yellow tin, they would dribble, a drop of water on to the black and paint it onto the pipe to make a very neat connection. After the work, the residual would wash off. I live where it was made and sold, and have tried for several years to find out what it composed of. Certainly effective at high temperature and cheap in 1950/60's. I'm sure it would be a good alternative to Tippex and no solvent involved. Does a forum member know what the Black was composed of ? John |
Bill Phinn | 07/12/2021 15:44:25 |
737 forum posts 103 photos | Posted by Circlip on 07/12/2021 10:35:00:
I've regularly used Tipp-Ex when soldering. Yes, it emits a green smoke when heated and an unpleasant smell, but I can live with that, or at least I have done so far. Massimo's suggestion is probably the best one from a safety standpoint. It just requires a bit more work to keep some mixed up and ready for use.
Edited By Bill Phinn on 07/12/2021 15:49:33 |
pgk pgk | 07/12/2021 15:47:43 |
2552 forum posts 293 photos | I found this reference via google: ‘plumber’s black’ –
SillyOldDuffer | 07/12/2021 16:29:17 |
Moderator 8496 forum posts 1900 photos | Posted by john fletcher 1 on 07/12/2021 14:49:04:
... when Men were men, ... they used "Plumbers Black" as a resist. ...I live where it was made and sold, and have tried for several years to find out what it composed of. ... Henley's 20th Century Formulas, Processes and Trade Secrets says: a protective mass consisting essentially of carbon (graphite, coke or charcoal), powdered talc or asbestos, ferric hydrate (with or without ferrous hydrate) and, if desired a little Aluminium Oxide, together with a a binding agent of the customary kind (glue solution, beer). Example recipe: Graphite, 50 parts; powdered coke, 5 parts; powdered talc, 5 parts, glue solution, 2.5 parts; drop beer, 2.5 parts; ferric hydrate, 10 parts; aluminium oxide, 5 parts. By glue, they mean animal glue made from bone and sinew. Drop Beer seems to be low-alcohol beer, less than 0.5% I could only find Ferric Hydrate - modern name Iron(iii) Hydroxide - sold as a laboratory reagent. £104 for 5g, ouch! Might be possible to make your own cheaply by mixing garden centre Iron Sulphate with Caustic Soda. I don't suppose it needs to be pure. Dave |
Steve Skelton 1 | 07/12/2021 18:39:05 |
140 forum posts 6 photos | I'm also with Massimo on this one. Jewellers rouge lasts forever and is easily mixed with a little water and if it goes dry in storage just add a little more water. Works a treat and is low cost - £4 for 50g (eBay) which will last for a lot of soldering. |
Former Member | 04/01/2022 05:09:41 |
[This posting has been removed] | |
Neil Wyatt | 05/01/2022 15:23:05 |
![]() Moderator 18993 forum posts 734 photos 80 articles | Chalk and charcoal ground up with a little bit of meths will make usable plumbers black. Neil |
Dave Wootton | 05/01/2022 16:43:08 |
290 forum posts 65 photos | Recently I couldn't find Tippex brand locally, so tried W H Smiths own solvent brand it works just as well as the genuine article and turns out to be much cheaper too! Dave |
john fletcher 1 | 06/01/2022 14:58:26 |
785 forum posts | Many thanks Dave for the list of ingredients for PLUMBERS BLACK, I'll give it a try and let you know how I get on. In the means time I'll give Jewellers rouge a go. John |
