Warco digital readout broken
mike barrett03/12/2021 16:37:00
16 forum posts
I have a Warco 500mm digital readout on my miller.
The Y axis has stopped working, number on display not changing when the axis is moved. Swapped input to the readout and the readout is working fine.
Have taken the slide to bits and cant see any damage or swarf so assume that the LED and sensors are failing.
Before I pay Warco £115 to but a replacement anyone else had problems and are there any fixes?
BTW it started to fail intermittently so would work on part of the track and then stop incrementing the reading and then start again. Luckily I wasn't doing anything precision at the time...
not done it yet03/12/2021 17:08:01
6736 forum posts
20 photos
I suggest you enquire to Warco. I doubt it needs a 500mm scale for the y axis?
DiogenesII03/12/2021 17:34:11
520 forum posts
202 photos
Posted by mike barrett on 03/12/2021 16:37:00:
... ...Have taken the slide to bits and cant see any damage or swarf so assume that the LED and sensors are failing.
Have you checked for broken wire / continuity in the lead..?
mike barrett13/12/2021 16:22:37
16 forum posts
tested for broken wires and bad joints but cant find any problems, it seems to work over certain parts of the range so begining to think the glass slide is damaged.
New one from Warco all now working again..
mike
Edited By mike barrett on 13/12/2021 16:23:07
Dave Halford13/12/2021 19:44:50
2007 forum posts
23 photos
Remove an end plate, slide the head out and use a tissue and alcohol to clean the glass.
Did you check that the led lights?
Clive Steer13/12/2021 20:16:17
93 forum posts
5 photos
Usually there is also a glass scale on the read head that produces a interference pattern with the main glass scale and I've have one of these becoming detached. I'm not sure you'll see the LED's light up as they are normally Infra-red but not sure what modern scales may use.
mike barrett 114/12/2021 08:17:10
11 forum posts
Posted by Dave Halford on 13/12/2021 19:44:50:
did take the head out and cleaned everything. Couldnt check the LED as I think there are IR. Might try again using a IR receiver and a scope.
Would still like to repair it.
mike barrett 114/12/2021 08:18:23
11 forum posts
Posted by Clive Steer on 13/12/2021 20:16:17:
I will have another look at it. Although I have brought a new one I would like to fix the old one or understand whats broken.
David Jupp14/12/2021 08:56:25
822 forum posts
17 photos
Digital camera sensors will respond to IR. I've used a video camera before to check that an IR remote control was actually emitting. Phone camera may well work for this - check first against a known working device (TV remote ?).
Rapid RC
Dreweatts
