Pm11 240v ac to 240v dc
James Lake | 26/11/2021 23:04:14 |
4 forum posts | Hi, please can anyone help. I have bought a parvalux motor to power my Universal Pillar Tool as described by George Thomas.I need to power this motor through a inverter or converter of some sort to allow it to run from 240v ac mains. I would also like to have control over the speed so would need a potentiometer. Also I have a no volt release switch which I would like to use. PLEASE could someone supply me with a circuit diagram complete with all the components detailed on it, with any numbers or electrical values detailed. I have tried Parvalux but they were not forthcoming, and as I have already destroyed one of these motors I am getting desperate. Needless to say all expenses will be met. Please help |
Grindstone Cowboy | 27/11/2021 00:53:16 |
894 forum posts 64 photos | A photo of the motor and, more importantly, any information on it (probably stamped on a plate) would be most useful. Rob |
Michael Gilligan | 27/11/2021 08:15:19 |
![]() 20289 forum posts 1064 photos | Posted by Grindstone Cowboy on 27/11/2021 00:53:16:
A photo of the motor and, more importantly, any information on it (probably stamped on a plate) would be most useful. Rob . +1 for that Parvalux is a manufacturer, not a type of motor Please tell us what exactly you have bought, James … and how you contrived to destroy the first one. MichaelG. |
Gray62 | 27/11/2021 08:23:21 |
1058 forum posts 16 photos | Without specific details of the motor we can only make assumptions. You talk about running from an inverter so we will assume we are dealing with a 3 phase motor. There will be no need for a NVR switch as this functionality can be programmed into most decent inverters as can speed control and start/stop parameters. A photo of the motor information plate will be a good starting point. Gray |
Clive Brown 1 | 27/11/2021 08:49:35 |
863 forum posts 47 photos | Hi James, Do you really need variable speed on this device? Mine is pretty much as specified by GHT with a 2800 rpm fixed speed motor, not Parvalux but similar. This gives speeds, from memory, of around 3000 and 2000 rpm. Since the drill capacity is 5/32" dia. max. I find this completely adequate. The machine isn't really suited to anything much larger. |
Baldric | 27/11/2021 09:22:44 |
180 forum posts 30 photos | The title says "Pm11 240v ac to 240v dc" on their website I can't see a 240v dc motor, is that the correct voltage?
Baldric. |
Michael Gilligan | 27/11/2021 09:39:32 |
![]() 20289 forum posts 1064 photos | Posted by Baldric on 27/11/2021 09:22:44:
The title says "Pm11 240v ac to 240v dc" on their website I can't see a 240v dc motor, is that the correct voltage? Baldric. . At a guess, it would be the 220v one then : **LINK** https://www.parvalux.com/search/pm11/ MichaelG. .
Edited By Michael Gilligan on 27/11/2021 09:41:56 |
Michael Gilligan | 27/11/2021 09:53:40 |
![]() 20289 forum posts 1064 photos | [quote] DC shunt wound and permanent magnet motors can be operated as variable speed using a thyristor or PWM controller.[/quote] Ref. __ **LINK** https://www.parvalux.com/resources/faqs/can-single-speed-motors-ever-be-operated-as-variable-speed/ MichaelG. . Edit: __ Plenty of commercial products, and schematics available This is a good place to start : https://www.electroschematics.com/motor-speed-regulator-with-triac/ Edited By Michael Gilligan on 27/11/2021 10:01:08 |
John Haine | 27/11/2021 09:58:52 |
4715 forum posts 273 photos | I would recommend a KBE controller such as this one. I use one on my Novamill and it has performed well. Look at the manual for the wiring diagram. |
Journeyman | 27/11/2021 10:06:51 |
![]() 1174 forum posts 236 photos | A suitable power supply with 220V DC output seems to be required have a look *** HERE *** It may be easier to get an AC motor of similar size which Parvalux also make! *** HERE *** for example. John Edit: link Edited By Journeyman on 27/11/2021 10:20:36 |
John Haine | 27/11/2021 10:59:22 |
4715 forum posts 273 photos | The supplies that Journeyman links to look highly overspecified for the task and aren't really designed for motor control. The KBE ones have "armature resistance" compensation to keep the speed constant under load and can control the speed smoothly over a wide range with its integral potentiometer. Output is fuse protected and I can vouch for the fact that you can stall the motor at high speed by running the cutter into the material, blowing the fuse, but the controller is undamaged (just need to replace fuse). The only downside is that the whole internal chassis is floating with mains - the outer casing is earthed so the unit is fully safe (and the speed control pot has a nylon shaft for safety), but this does mean that controlling the speed from an external voltage needs an isolation circuit. But for James' application that isn't needed and the integral pot will be just fine. Based on my experience over several years I can recommend KB. You can also get much lower cost speed controllers from eBay but I have no experience of these. |
An Other | 27/11/2021 11:22:39 |
261 forum posts 23 photos | RE JH's comment about 'eBay' and similar suppliers. I have a 220V DC controller bought from BangGood, and it seems fine. control is by a potentiometer (supplied with the controller), and is from 0 up to full voltage (in my case, about 1300 rpm) - I use it on a spindle motor in a CNC system I built. My only 'criticism' is that the casing is drilled for ventilation, so it needs to be mounted where swarf can't get in. I've had it for some time, and can't remember exactly what I paid for it, but I think it was only around 30 Euros - there are many different controllers on their website - delivery from China was 10 days (no connection with BangGood) Edited By An Other on 27/11/2021 11:23:09 |
Jon Lawes | 27/11/2021 12:10:48 |
![]() 984 forum posts | Second question in almost a decade, no replies to the answer given last time.... |
derek hall 1 | 27/11/2021 14:34:27 |
231 forum posts | Hi recently contacted Parvalux for a price for a 2800rpm, 3 ph SD28........Glad I was sat down when I looked at the quote....over £500 Regards Derek |
John Haine | 27/11/2021 14:37:55 |
4715 forum posts 273 photos | Derek, worth haunting eBay - I got one, brand new, for well under £100. |
Michael Gilligan | 27/11/2021 14:38:47 |
![]() 20289 forum posts 1064 photos | Posted by Journeyman on 27/11/2021 10:06:51:
A suitable power supply with 220V DC output seems to be required […]
. [blushing again] Ah, yes … if the motor is DC only, then it will need a DC supply … and if speed-control is required, it would then be by PWM MichaelG. |
Michael Gilligan | 27/11/2021 14:45:19 |
![]() 20289 forum posts 1064 photos | Posted by Michael Gilligan on 27/11/2021 09:53:40:
. Just striking-out the erroneous edit in my earlier post ^^^ … the main text remains valid. MichaelG.
Michael Gilligan | 27/11/2021 14:59:01 |
![]() 20289 forum posts 1064 photos | Posted by John Haine on 27/11/2021 09:58:52:
I would recommend a KBE controller such as this one. I use one on my Novamill and it has performed well. Look at the manual for the wiring diagram. . That does look near-ideal, John MichaelG. . Edit: __ Looks nicely built too : https://youtu.be/SWlFJpRLtiI
Edited By Michael Gilligan on 27/11/2021 15:09:30 |
James Lake | 28/11/2021 12:52:11 |
4 forum posts | So sorry, I seem to have left out the important bits. The motor plate is very faint and does not lend itself to photography. But here are details ; PARVALUX MPM11-0034/cont. W-2950707-11181 MOTOR TYPE: PM11 voltage supply 220/240 dc power 110watts current 0.64 speed 5000rpm RATING CONTINUOUS insulation F thermal [TP] capacitor enclosures TENC type GB speed GB torque GB ratio Part 1 BGM 1 this is all copied verbatum . Hz and Phase are mentioned on the plate but no values given. I purchased this motor direct from Parvalux as it appears to be the same motor that came ready fitted to my QUICK-STEP MILL, anyone familiar with these? I would realy like a much quieter motor perhaps along the lines of the one that is fitted to my Cowells 90ME lathe. Can anyone recommend a motor perhapsmwith simpler wiring!!! |
John Haine | 28/11/2021 13:25:16 |
4715 forum posts 273 photos | Thanks for the additional details James. That is clearly a DC commutator motor which it is why it's noisy (brush whine). If you just want fixed speed then an equivalent Parvalux induction motor would be fine - suggest that you contact them for suggestion. If you want variable speed and silence then a 3-phase motor with VFD is one approach, though probably quite expensive. Alternatively a few people posting here have fitted brushless industrial sewing machine motors which can be had from well-known auction sites for reasonable prices complete with controller - some searching the forum should turn up a recent thread. I think recently someone fitted one to a Unimat which is the kind of power you want, This is an ideal opportunity to broaden your engineering knowledge to embrace electrical engineering. |
