I just don't beliieeve it..
..paint but not a paint question
pgk pgk21/11/2021 14:46:37
2425 forum posts
293 photos
I had need to cover a ceiling stain and thought easiest would be a coat of oily white gloss it won’t bleed through, then emulsion later.
I had a tin o Dulux Weathershield external 6yr brilliant white gloss. New and unopened but likely bought a few years ago 'cos I don't remember when, why or where.
I opened it up... Burgundy all the way to the bottom..
pgk
HOWARDT21/11/2021 14:57:33
836 forum posts
39 photos
Better to use one of the stain blockers, even gloss paint will stain through eventually. I have a small spray can and use it occasionally.
pgk pgk21/11/2021 15:20:34
2425 forum posts
293 photos
'Twas a case of what was on hand - and that my reading reviews on a few varieties of stain blockers had many disappointments. Recommendations? Spraying would be a pain in this case with lost of masking between roof light and wall window
pgk
john fletcher 121/11/2021 15:27:41
754 forum posts
Several years ag I covered a creosote stain with several application of Aluminium metal paint, not the wood primer, still OK. John
Phil Whitley21/11/2021 16:11:49
1394 forum posts
147 photos
White pigment is usually titanium dioxide which is heavy, and so settles out, but if you have stirred it thoroughly right to the bottom my only suggestion is a new fashion trend for burgundy gloss ceilings!
I'll get me coat!
Phil
the artfull-codger21/11/2021 16:29:42
283 forum posts
8 photos
I used zinsser bullseye 123 on a stain on our ceiling & it cured it ok
JasonB21/11/2021 17:12:21
21999 forum posts
2539 photos
Zinsser for me but I tend to use "Cover Stain"
Rick Hann21/11/2021 19:50:42
9 forum posts
Prime with white lacquer and Bob"s your uncle!
Rick
walker midge
rapid Direct
JD Metals
