mike barrett | 09/11/2021 10:00:35 |
16 forum posts | We have brought (mostly secondhand) Blue trackmaster track and trains. these are all about 10/15 years old. they have a battery, motor, and a clever clutch mechanism to try to make them kid proof. |
noel shelley | 09/11/2021 10:09:35 |
1278 forum posts 21 photos | If mechano or lego don't help then DAVALL STOCK GEARS, at hatfield may be worth a call, they do a vast range of gear wheels in many substances including plastics. Good luck Noel |
Trevor Drabble | 09/11/2021 12:46:43 |
![]() 280 forum posts 5 photos | Mike , Any of the following Hobbies products of interest ? 1) Gearwheel set @ £15.99 2) Axle Gearwheel set @ £17.99. 3) Multi Ratio Gearbox @ £7.99 . Trevor. |
Trevor Drabble | 09/11/2021 12:56:42 |
![]() 280 forum posts 5 photos | Also , any of the MFA 951 motor and gearbox combinations available for Cornwall Model Boats @ £9 ? Trevor. |
Jeff Dayman | 09/11/2021 13:30:11 |
2221 forum posts 47 photos | Hi Mike, no idea exactly what diameter and no. of teeth we are talking about here, but an idea - make or have made brass or mild steel gears, split them into halves, clean the shaft, flux, and solder / sweat the gear together in place on the shaft. Use just the tiniest pieces of solder, just enough to wick some in, so it doesn't run into the teeth. If the gear to shaft bond is not good a drop of 609 loctite cylindrical retaining compound would likely bond it. Depending on quantity scope of the project and your budget, it is very possible to have an injection mould insert set made to produce new gears in acetal resin, with 3 pin gates for hottest knit/weld lines in the plastic and thus minimal chance of splitting again. |
Trevor Drabble | 10/11/2021 21:57:34 |
![]() 280 forum posts 5 photos | Also , replacement r/c servo gears available from larger r/c model shops and also Ripmax . Trevor. |
pgk pgk | 10/11/2021 23:25:28 |
2549 forum posts 293 photos | +1 for servo gears - may even be cheaper to buy cheap servo’s than gear sets. pgk |
Alan Charleston | 11/11/2021 05:03:45 |
134 forum posts 22 photos | Hi Mike, What about replacing the broken gear with an O ring and friction driving the next gear? Regards, Alan C. |
