Michael Gilligan | 07/11/2021 14:47:58 |
![]() 20182 forum posts 1053 photos | In a recent thread : **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=175373 We considered the use of GPS as a Speedometer for use on a Miniature Railway. … I continue to have some reservations about its applicability [ unless, of course, a sophisticated system is installed at the track ] Today, I took my ‘old but respectable’ hand-held GPS [Garmin GPSMap76] for a walk over the hill. The Trip Computer recorded the following: Odometer 7.83 km Stopped time 00:05:18 Moving Average 5.1 kph Moving Time 01:32:52 Overall Average 4.8 kph Total Time 01:38:10 Which all seems reasonable, and consistent within itself. . There were, however, two oddities : Max Speed was recorded as 12.0 kph and for about thirty seconds whilst I was standing on the doorstep, the Speed continued to display 3.0 kph . I would be interested to see the results of similar journeys by others. MichaelG. |
Martin Connelly | 07/11/2021 15:16:23 |
![]() 2137 forum posts 222 photos | The readings are not continuous and the accuracy is not to a fraction of a metre so it doesn't seem odd to me. If you got continuous readings every 0.1 of a second and the accuracy was also 0.1 of a metre you would have a much smoother graph if it was plotted. If you got two readings 0.1 second apart and the position accuracy was 5m too far north for the first one then 5m too far south for the second one it would think you had travelled 10m in 0.1 seconds, equivalent to the 100m sprint in 1 second. When you add the irregular readings to poor positioning the average over time and the distance travelled will be about right but for short times or distances you can expect bizarre results to pop up on the screen. Martin C |
SillyOldDuffer | 07/11/2021 15:32:24 |
Moderator 8676 forum posts 1965 photos | Posted by Michael Gilligan on 07/11/2021 14:47:58: ... . There were, however, two oddities : Max Speed was recorded as 12.0 kph and for about thirty seconds whilst I was standing on the doorstep, the Speed continued to display 3.0 kph ...GPS is accurate to within a 1m radius with absolutely everything in order and a couple of virgins sacrificed. In practice, accuracy is degraded by weak signals, how many satellites are in view, reflections, solar storms and the quality of the receiver and it's antenna. Various figures quoted, but within a 5 to 10 metre circle is typical. If the receiver can only see 4 satellites, about 15m. Watching the NEMA output of my GPS module with a antenna looking south through a Window, shows the number of usable satellites seen from my dining room varies between 8 and 16 as the earth rotates, and sometimes drops to 5. The receiver calculates speed by comparing previous positions. If signal conditions vary whilst stopped, the receiver may detect false movement due to the size of the error circle changing. From the data it appears as if the receiver is moving slowly or jumping rapidly about. Later GPS and most smart phones incorporate an accelerometer, gyroscope and magnetometer : if present these can detect the GPS is reacting to noise and ignore false signals. I'm not up-to-date with these devices, but I believe quad-copter software has integrated data from all the sensors available for several years. Military for even longer. The mix of position fixing and dead reckoning maintains accuracy in the event one or more sensors are confused. There's no reason why this technology won't end up in a smart phone, hiking system, or car navigation system, or model railway speedometer. Perhaps it already has! Dave |
Another JohnS | 07/11/2021 15:40:03 |
832 forum posts 56 photos | Michael; A couple of things to think about. 1) Over here (Canada) "WAAS" helps with GPS accuracy, so long as you have line of sight to a satellite in geostationary orbit. Down to about 1.2metres, if I remember correctly, which helps with positional accuracy. Otherwise it's about 8 metres accuracy. 2) I do have a UBLOX GPS receiver with Kaman filtering and (of course) accelerometers; it's used to "smooth out" GPS readings. Unfortunately, you have to do some maneuvers to set it all up; 20km/hr, left and right turns, that kind of stuff. Hard to do that in a sailboat with a displacement hull speed of 6.5 knots, so I do have an accelerometer and have recorded tracks (GPS, with corresponding accelerometer values) to try and roll my own filter; some sailboat owners have found GPS lacking in northern fjords. 3) Heber Valley Railway #618 has/had a GPS speedometer; now way back at 2002 when I was helping, I was informed that the GPS speedo was not accurate below about 5mph. That was before WAAS, etc. 4) You may be near enough to an airport with a GPS augmentation system, but I'm not sure off-hand how normal GPS receivers would find and track this.
All fun stuff - John.
Clive Brown 1 | 07/11/2021 15:51:01 |
825 forum posts 41 photos | The instrument will calculate speed based on calculated position, which will vary fairly randomly within the margin of error. The screen display of speed will normally be damped to provide a steady reading. Michael's 30 seconds of 3 kph might have been due to the loss of satellite cover as he stood in a doorway. The 12 kph could be the max. instantaneous speed which was damped out and not actually displayed. (Or perhaps he dropped it!) . Edited By Clive Brown 1 on 07/11/2021 15:52:31 |
Michael Gilligan | 07/11/2021 16:04:43 |
![]() 20182 forum posts 1053 photos | Posted by Martin Connelly on 07/11/2021 15:16:23:
The readings are not continuous and the accuracy is not to a fraction of a metre so it doesn't seem odd […] but for short times or distances you can expect bizarre results to pop up on the screen. Martin C . Perhaps I didn’t make myself clear, Martin The reason I was doing this was to test whether or not the GPS system would be suitable for the low-speed application discussed previously … I thought, and continue to think, that it is not MichaelG. |
Michael Gilligan | 07/11/2021 16:13:49 |
![]() 20182 forum posts 1053 photos | Posted by Clive Brown 1 on 07/11/2021 15:51:01:
[…] (Or perhaps he dropped it!) . No he didn’t ! I am incapable of walking at 12 kph, and I was walking fairly steadily. The 12 kph was most likely due to a brief loss of reception quality … too little to trigger the alert, but enough to diminish the location accuracy. MichaelG. |
Martin Kyte | 07/11/2021 16:51:53 |
![]() 2751 forum posts 48 photos | iPhones have pretty good accelerometers these days. If you are up for it building an app (unless its already been done) to act as an inertial nav should be acheivable when coupled with the 3 axis magnetometer to provide direction information. regards Martin |
Michael Gilligan | 07/11/2021 17:36:13 |
![]() 20182 forum posts 1053 photos | Posted by Michael Gilligan on 07/11/2021 14:47:58:
. I would be interested to see the results of similar journeys by others. MichaelG. . I am grateful for your comments thus far, gentlemen ... but, if it's not too much to ask: Could someone please do me the simple kindness of [approximately] repeating my exercise, using a different GPS. I have neither an Android 'phone with GPS, nor an iPhone, so I cannot do the comparison myself. My car GPSs don't have the detailed 'Trip Computer' which the GPSMap76 provides. I am more interested in the actual slow-speed performance of available/affordable devices than the hypothetical merits of cutting-edge developments. This is simply a quest for knowledge and understanding. Thanks MichaelG |
peak4 | 07/11/2021 18:05:17 |
![]() 1712 forum posts 183 photos | Michael, I have a variety of devices of varying age; Plain Garmin GPS, Garmin Satnav, and Android phone(s), as well as older stuff such as PDA that I used to use, with built in GPS, and a laptop with a GPS aerial. There are dedicated car/motorcycle speedos available, though not UK legal as the sole speedo in the UK. This should give you another rabbit hole to disappear into for the rest of the day. Edited By peak4 on 07/11/2021 18:09:31 Edited By peak4 on 07/11/2021 18:12:49 |
John Haine | 07/11/2021 18:07:35 |
4673 forum posts 273 photos | In the other thread I reported some informal experiments with a GPS cyclometer and my phone using a dedicated GPS speedometer and the "GPS Status" app. At least at walking speeds these all gave similar performance, with little sign of erratic readings. I have observed the cyclometer a lot at speeds varying from a few mph up to 20 and above downhill and again it responds smoothly, without erratic readings. Unfortunately neither the cyclometer nor the two apps tested have logging features to directly compare with MG's experiment. The OS app can log routes, I'll see if more detail is available. Interesting to note that neither the cyclometer nor the phone shows any sign of spurious velocity readings when stationary, GPS does not compute speed by differentiating position w.r.t. time. It has to track doppler shifts of the signals from all the satellites anyway which are moving at a variety of velocities relative to the receiver, so the speed measurement is a by-product of this. Modern GPS has a load of optimisations including for low speed navigation so the latest chips (and the GPS integrated into smartphone chipsets) could be expected to work pretty well. Note also that smartphone GPS makes use of downloaded assistance data. Most modern dedicated "GPS" chips also use 4 satellite constellations, with Glonass, Galileo, and Beidou as well. I think that a modern GPS, either a cyclometer type or a smartphone running a suitable app, would be very adequate for a model train track speedometer. Edited By John Haine on 07/11/2021 18:08:01 |
Michael Gilligan | 07/11/2021 18:32:23 |
![]() 20182 forum posts 1053 photos | Posted by peak4 on 07/11/2021 18:05:17:
[...] This should give you another rabbit hole to disappear into for the rest of the day. . Thanks, Bill ... That's one of several papers that I looked yesterday [and realised that I was already being drawn away from my specific area of interest] : Avoiding this 'scope-creep' was why I decided to conduct a simple practical experiment and ask for a little support. It looks like it's not going to get me anywhere. Happy to let the thread die peacefully MichaelG. |
peak4 | 07/11/2021 19:12:17 |
![]() 1712 forum posts 183 photos | Posted by Michael Gilligan on 07/11/2021 18:32:23:
Thanks, Bill ... That's one of several papers that I looked yesterday [and realised that I was already being drawn away from my specific area of interest] : Avoiding this 'scope-creep' was why I decided to conduct a simple practical experiment and ask for a little support. It looks like it's not going to get me anywhere. Happy to let the thread die peacefully MichaelG. Like you, I've tried, but never had much success with "normal" GPS units for walking pace speed measurements. Bill |
John Haine | 07/11/2021 19:19:31 |
4673 forum posts 273 photos | If anyone wants some light bedtime reading, this looks like fun: u-blox was my last employer before I retired... |
SillyOldDuffer | 07/11/2021 21:58:44 |
Moderator 8676 forum posts 1965 photos | Posted by John Haine on 07/11/2021 18:07:35:
,,, GPS does not compute speed by differentiating position w.r.t. time. It has to track doppler shifts of the signals from all the satellites anyway which are moving at a variety of velocities relative to the receiver, so the speed measurement is a by-product of this. ...
Well, you live and learn! Checking John's statement the first 4 search results all 'confirmed' it was done by calculating d/t. One of the sources is a big name. Then I found this comment on the fifth wrong answer: GPS receivers do Not measure speed by differencing the positions over time. They could, but it would be grossly inaccurate. The speed is actually measured as a side effect of the solution to another problem: the satellites are moving, causing a Doppler shift in the received radio frequency. The receiver has to adjust for each satellite - but any remaining discrepancy of the received frequency must be due to the movement of the GPS receiver itself. Thereby, the GPS ends up knowing exactly how fast it is moving, to and accuracy much greater than that attainable from position differences. Try searching for GPS Doppler. Searching for GPS Doppler as suggested by the comment confirms what John says. Dave
duncan webster | 08/11/2021 00:04:30 |
3984 forum posts 65 photos | No matter how it works, my Garmin doesn't work under trees especially when it's raining |
Ady1 | 08/11/2021 01:21:59 |
![]() 5089 forum posts 736 photos | Only the military have access to really accurate GPS Civilian kit has built in errors and degraded signals to prevent it being weaponised |
John Olsen | 08/11/2021 05:54:13 |
1249 forum posts 94 photos 1 articles | Ady that is no longer true. The feature was called selective availability, it was turned off in May 2000. You can now get the full accuracy that the system is capable of, provided of course that you aren't standing under wet trees. John |
Michael Gilligan | 08/11/2021 07:31:44 |
![]() 20182 forum posts 1053 photos | Posted by John Olsen on 08/11/2021 05:54:13:
Ady that is no longer true. The feature was called selective availability, it was turned off in May 2000. You can now get the full accuracy that the system is capable of, provided of course that you aren't standing under wet trees. John . Thanks for putting Ady right on that, John … As I wrote on the other thread: . The basic issues are nicely summarised here: **LINK** https://www.gps.gov/systems/gps/performance/accuracy/ . MichaelG. |
Gary Wooding | 08/11/2021 07:36:13 |
983 forum posts 254 photos | A little while ago I sent the following email to the authors of a GPS app running on Android. My wife and I both use Trip Recorder, she on an Alcatel and me on a Moto G. Last week her's registered 3.2 miles and mine was 3.1 miles for the same journey. Today hers said 3.7 and mine was 3.5, again for the same journey. We start and stop recording at the same time, and walk together. What's wrong please? They never found a solution. |
