Martin King 2 | 06/11/2021 13:07:47 |
1018 forum posts 461 photos | Hi All, Today's early morning haul included this at the bottom of a crate of nice tools: Main part is 5" long, there is what looks like a threaded section at the top then an arm with a double worm one end and screwdriver tip at the other. The spike sits in a nice recess on the shaft and pulls out for use. There is a square recess in the end a bit like a clock key? Is it some kind of tool for an old pistol or other gun? Cheers, Martin Cheers, Martin |
DiogenesII | 06/11/2021 13:49:57 |
589 forum posts 234 photos | I'm no expert, but it does look like a pistol tool - ball-puller, touch-hole pricker, turnscrew.. ..the square socket could conceivably be for a wheellock.. ..they did make wheellock pistols for self-protection so could be quite short, but still firing a biggish ball.. ..worth getting it checked out.. Edited By DiogenesII on 06/11/2021 13:50:19 |
vic newey | 06/11/2021 13:51:04 |
![]() 188 forum posts 84 photos | Strange item, the two pronged thing looks very like I have on the rear end of a ramrod on one of my old guns, it's used to pull out a lead ball or wadding from a gun barrel in the event of a failure to fire, it's far too short though and looks too crude for small pocket pistols Again, the spike looks like a tool to clear the touch hole on a muzzle loader but maybe it's nothing to do with guns. If you get no identification I can put it on another group who will identify it for sure |
DiogenesII | 06/11/2021 13:56:39 |
589 forum posts 234 photos | There's a picture of a more recent M/L tool here; Unknown muzzle loading pistol tool ..similar range of tooling, slightly different arrangement, this one looks mass produced, yours looks older & handmade. |
Speedy Builder5 | 06/11/2021 14:13:50 |
2654 forum posts 219 photos | Looks more like a canon touch hole un-blocking tool. |
vic newey | 06/11/2021 14:34:32 |
![]() 188 forum posts 84 photos | Posted by DiogenesII on 06/11/2021 13:49:57:
Ithe square socket could conceivably be for a wheellock.. ..they did make wheellock pistols for self-protection so could be quite short, but still firing a biggish ball.. Edited By DiogenesII on 06/11/2021 13:50:19 ----------------- Far too crude for that I think, wheellocks were extremely expensive and beyond the capabilities of the local blacksmith, the bore of pistols was often 1/2" or less and the tools that came with them were also finely made, sometimes ornamented as well. I posted my wheellock pistol on here a few weeks back
David Jenner | 06/11/2021 14:36:35 |
30 forum posts | The spike is for clearing the touch hole possibly for a flintlock, but could be for percussion. The other attachment is to extraxt either a stuck lead ball or the wadding. The screwdriver needs no explanation! The square recess is possibly to remove the flint, but some early percussion nipples may have a square to allow removal from the action. It is not uncommon to have gun multi tools, saves stuff going missing in the field. One old pistol I had was completly strippable using the tools incorporated in its design. Pressing a sprung button allowed the cylinder pivot to be removed which had a srewdriver to remove the grips. Once these were removed, a lever was rotated to release the hammer mainspring, thus allowing te remaining components to be disassembled. Soldiers loose tools in battle, so having it all built in makes good sense. |
Martin King 2 | 06/11/2021 15:06:15 |
1018 forum posts 461 photos | Thanks to all for the help here! Vic, by all means post elsewhere. Diogenes, it certainly looks the same sort of tool I saw similar, but MUCH larger worm things on my recent trip to HMS Victory. What would the crude thread be for on the end? Cheers, Martin |
Grindstone Cowboy | 06/11/2021 19:25:33 |
895 forum posts 64 photos | Yes, it's a fairly common combination tool for a muzzle-loading weapon. As David Jenner says, there's a screwdriver, wad-puller (to use, it would be threaded onto the ramrod supplied with the gun, stored under the barrel), the square recess is indeed for removing a percussion nipple, and the spike for clearing the hole in said nipple (or the connecting hole to the breech once the nipple is removed. A similar type is shown below, which has an additional bullet puller (looks like a woodswcrew). Rob |
Martin King 2 | 07/11/2021 13:01:17 |
1018 forum posts 461 photos | Hi All, After a closer examination and the judicious use of gentle heat this tool came apart to reveal more tool ends! There is also a very small makers mark showing an "E" over a CROWN over the numbers 38 ? Also does the team think that the larger threaded bit is for a handle perhaps? Cheers, Martin |
Grindstone Cowboy | 07/11/2021 14:04:08 |
895 forum posts 64 photos | The crown with E was the inspection marking for the Enfield Armoury. Not sure, but the 38 may refer to the year (1838) or may just be a reference number. If by the threaded bit you mean the thread just behind the screwdriver bit (around the 8 o'clock postion in your photo), I don't think it has any use except as storage for the wad-puller (it screws on there with the pointy bits inwards so they don't catch on anything). Rob
Martin King 2 | 07/11/2021 18:15:21 |
1018 forum posts 461 photos | Hi, I meant the threaded bit at about 1 o'clock in the photo. Martin |
Grindstone Cowboy | 07/11/2021 19:44:02 |
895 forum posts 64 photos | Ah, right - didn't see that as a thread. I don't know what that might be for, to be honest. Probably does have a use, though, along with the cross hole which most of them seem to have - no room in the military for pointless decoration Rob |
JohnF | 07/11/2021 21:27:35 |
![]() 1175 forum posts 193 photos | Not read all the posts but the tool is similar to an 1850 Enfield .577 rifle military tool, this may well be a civilian model, lots of military replicas about made by Parker Hale of Birmingham same as the photo posted by Rob. The lug on the side of this one is to enable the very strong V spring to be removed or a new one inserted should the original break. John |
Robin | 07/11/2021 21:52:50 |
![]() 592 forum posts | Looks like the Enfield rifle tool to me, would it fit a .577" bore?
Martin King 2 | 07/11/2021 22:14:34 |
1018 forum posts 461 photos | Diameter of the worm boss is 0.560" so I guess .577 would be about right? Martin |
Robin | 08/11/2021 10:01:43 |
![]() 592 forum posts | There is a lovely Illustrated London News article on making the Enfield barrel from strips of Marshall's iron. The Time Team excavated Marshall's B'ham factory to reveal the super hot furnaces where he melted the crucible steel |
Michael Gilligan | 08/11/2021 10:17:15 |
![]() 20289 forum posts 1064 photos | Posted by Robin on 08/11/2021 10:01:43:
There is a lovely Illustrated London News article on making the Enfield barrel from strips of Marshall's iron. The Time Team excavated Marshall's B'ham factory to reveal the super hot furnaces where he melted the crucible steel . Very interesting, thanks Robin … do you have a link [for the benefit of the idle] ? MichaelG. |
Robin | 08/11/2021 11:05:14 |
![]() 592 forum posts | I have snapped it with the jolly old Nikon and stuck it on my web thingy http://www.robinhewitt.net/LIN.png Hope it works |
Michael Gilligan | 08/11/2021 11:21:21 |
![]() 20289 forum posts 1064 photos | Many thanks, Robin MichaelG. |
