An Uninvited Guest!
It's been a warm, wet summer.
Swarf, Mostly!26/10/2021 13:18:57
615 forum posts
65 photos
Hi there, all,
Posting these photos is inviting scorn but I hope there'll be some sympathy too.
How do you tell when it's been too long since you had any workshop time?
As they say 'Life happens!'.
Identification will be welcome.
Best regards,
Swarf, Mostly!
Nigel Bennett26/10/2021 13:28:10
423 forum posts
11 photos
Looks like ivy to me.
Philip Rowe26/10/2021 13:33:08
219 forum posts
31 photos
It looks like an ivy to me and in all fairness it does grow very rapidly but not overnight. Seems you do need to spend some time out there if only to clear your visitor. Phil
Richard S226/10/2021 14:11:14
225 forum posts
133 photos
From the leaf form, it could be Hedera Hibernica?. And to alleviate your guilt complex of neglect, it is considerably fast growing.
Rik Shaw26/10/2021 14:57:58
1463 forum posts
396 photos
Could be black or white Bryony.
Rik
DiogenesII26/10/2021 15:26:10
366 forum posts
169 photos
..or maybe even Schizophragma..
Dave Halford26/10/2021 15:31:48
1818 forum posts
19 photos
Myford Strangler Vine
Sam Longley 126/10/2021 15:39:50
878 forum posts
34 photos
I have a similar problem and a small length of ivy has just found its way into the shed. Unfortunately I cannot get to the main plant as it is on the corner of the wokshop within 12 inches of the boundaries of 2 other properties. The plant is right in the corner & is quite substantial. I can only get access from the top & it has already started to damage the gutter beneath my pitched roof. My roof is cementous corrigated pitched construction & balancing is difficult on crawling boards
Soooo!! Has anyone any ideas what is the best method of killing it off.. . I did try pouring dieisel down over the leaves with a spray can from above & I believe that slowed the growth. However, it has come back.
Any ideas welcome
Edited By Sam Longley 1 on 26/10/2021 15:41:23
Mark Rand26/10/2021 16:03:14
1082 forum posts
12 photos
Probably need a greater rate of cut and a better chip breaker if the swarf is coming off like that.
pgk pgk26/10/2021 16:47:54
2361 forum posts
293 photos
Going greener - very modern!
pgk
Adrian 226/10/2021 17:30:32
104 forum posts
19 photos
Bamboo is another invader to avoid. I had a shoot grow up inside the studwork framing of my workshop, first I knew of it was when it hit the roof turned and pierced the insulation growing back downwards.
It has taken several years to get rid of but I am winning.
Adrian.
Howard Lewis26/10/2021 17:37:53
5545 forum posts
13 photos
Had a similar problem with the previous workshops. The problem was that the main stem was between the shop and the fence, so VERY difficult to cut off near the ground.
A saw blade fixed to a long pole did the trick, eventually.
Now the problem is one of SWMBOs plants that can cause heave depending on the weather, making the door stick sometimes. What started as a tiny stem is now nearly 100 mm diameter, but cannot be pruned other than gently.
Ivy seems to share some of the genes of Mile a Minute Russian Vine., and is very difficult to keep in check
SWMBO put some weedkiller on the grass,(Supposed to be safe for grass ) Killed the grass as well as the weed, A year on it still has not recovered, despite reseeding. This might be the stuff to put on the root, if you can dribble some down a tube into the area. "Weedol" perhaps?
Squirt from a water pistol may get the killer where it is needed.
Dave Halford26/10/2021 17:47:01
1818 forum posts
19 photos
SBK will do it
Michael Gilligan26/10/2021 17:58:18
19291 forum posts
960 photos
Posted by Dave Halford on 26/10/2021 17:47:01:
SBK will do it
You seem to know your weedkillers, Dave
… is it any good on horsetails ?
We have some growing up through a rockery which appear to have re-grown from root-fragments in the clay, and probably date back 100 years or more crying 2
Brian Wood26/10/2021 18:07:47
2475 forum posts
39 photos
Michael
I regret to say horsetail is notoriously difficult to eradicate. It dates back to the age of the dinosaurs and has learned some survival tricks. Fossils are frequently found in coal measures.
RHS Harlow Carr in Harrogate had it in their rockery, a very big rockery and the whole lot had to be dug up with excavators to a depth of maybe 20 feet to reach the base of the roots.
Selective weedkillers do not touch it either so I fear you have few options.
Best of luck Brian
Michael Gilligan26/10/2021 18:53:59
19291 forum posts
960 photos
Posted by Brian Wood on 26/10/2021 18:07:47:
Michael
I regret to say horsetail is notoriously difficult to eradicate. […]
Thanks for the empathy, Brian
Yes, I am unfortunately aware of all that … which is why I asked specifically about SBK
https://www.progreen.co.uk/sbk-brushwood-killer-1l-kplus-250ml-marestail-woody-weeds/
Grizzly bear26/10/2021 19:20:04
285 forum posts
8 photos
You give the horsetail a good thrashing before applying SBK, Roundup and/or diesel.
It needs to be well bruised. Enjoying it, isn't compulsory.(The thrashing.)
Howard Lewis26/10/2021 21:44:15
5545 forum posts
13 photos
Grizzly,
It is more blessed to give than to receive. Especially where this stuff is concerned
Keith Wyles27/10/2021 14:47:14
79 forum posts
Never manage to totally wipe out Horsetail. weedkillers will knock it back, as will WD40 etc after a good bruising. It does come back, but i have it under control.
DMB27/10/2021 16:01:44
1190 forum posts
I believe that bamboo can be controlled by copious applications of seawater and paraffin guarantees death to virtually any vegetation. I once had a tree growing a thin trunk my side of my back garden wall and anoth on my neighbours side. I could foresee the eventual fate of my wall and the renter's next door would be unlikely to do anything. I dealt with both trunks by cutting to ground level and pouring a small quantity of paraffin on the stump. No regrowth after a decade or more, so can vouch for the paraffin,but be careful as I suspect it is a serious pollutant and nothing will grow if spilt in quantity on soil.
rapid Direct
walker midge
JD Metals
