Vic | 25/10/2021 15:29:53 |
3074 forum posts 8 photos | We need to buy a new microwave, are there any parts worth removing from the old one before I take it to the tip?
Grindstone Cowboy | 25/10/2021 15:44:14 |
858 forum posts 64 photos | If the bulb is still working, you could keep it in stock as a spare for your next one. Turntable motor could be useful, but that's getting into "electrical" territory. Safety note - there are generally some big capacitors in microwaves, so make sure they are discharged before sticking your fingers into the circuitry. Also, if dismantling the magnetron(?) unit to get at the strong (and therefore quite useful) magnets, bear in mind there are some ceramic looking components (usually pink) that contain something nasty. The name of it escapes me now, think it starts with B. Relatively safe unless they get scraped, broken or crushed into a powder form which could be inhaled. Hope this helps. Rob |
martin perman | 25/10/2021 16:02:13 |
![]() 2044 forum posts 86 photos | Rob, Beryllium is the word your looking for, as said very good insulator but if damaged to powder state is toxic, natural colour is white. Martin P
KWIL | 25/10/2021 16:06:42 |
3554 forum posts 70 photos | Much thin stainless steel sheet. |
peak4 | 25/10/2021 16:09:12 |
![]() 1712 forum posts 183 photos | Other engineering folk might find the HV transformer useful to make a spot welder.
john fletcher 1 | 25/10/2021 16:19:09 |
793 forum posts | Regarding Micro wave cookers, once discharged the capacitor, the high voltage diode are useful and the wire from the transformer for recycling. Some PC boards have useful components which can easily removed with a hot soldering iron. And, as some one already said the cabinet, if you can make a new door and chassis the cabinet are very useful, for a power supply etc. I might add some gas cooker, gas boilers and washing machine are a good source of sheet steel. John |
Vic | 25/10/2021 16:28:03 |
3074 forum posts 8 photos | Thanks for the replies folks. I was aware of the potential dangers from the capacitors in these things but well worth mentioning again. |
Grindstone Cowboy | 25/10/2021 16:29:10 |
858 forum posts 64 photos | Posted by martin perman on 25/10/2021 16:02:13:
Rob, Beryllium is the word your looking for Thanks Martin, thought it was either beryllium or boron, wasn't sure which. Rob |
Andrew Johnston | 25/10/2021 16:51:22 |
![]() 6601 forum posts 701 photos | Posted by Grindstone Cowboy on 25/10/2021 16:29:10:
..........it was either beryllium or boron.......... Technically it's neither, the white insulator is beryllium oxide. Beryllium is a greyish metal. Both are toxic if dust is inhaled. Andrew |
Jim Young 2 | 25/10/2021 16:59:09 |
39 forum posts 5 photos | This might also be interesting. |
SillyOldDuffer | 25/10/2021 17:01:03 |
Moderator 8677 forum posts 1965 photos | Posted by peak4 on 25/10/2021 16:09:12:
But beware! A Microwave Oven Transformer is the most dangerous electrical item in the home. Bad enough they step-up mains voltage to a couple of kilovolts, but the design of the core means there's virtually no limit to the amount of current they can deliver. They cause severe shock and horrible burns. Old Sparky stuff - victims have been known to catch fire... This image is from a YouTube Video intended to highlight the risks. About 5:30 minutes in: Despite approaching these beasts with extreme caution there have been a number of nasty accidents in the Tesla Coil community. The answer is simple: don't plug it in until the High Tension winding has been removed!!! Dave |
Frances IoM | 25/10/2021 17:35:50 |
1265 forum posts 28 photos | it would have to be a very old microwave oven to have a transformer in it - modern power supplies are much lighter and very much cheaper. |
Rik Shaw | 25/10/2021 18:31:16 |
![]() 1483 forum posts 398 photos | "victims have been known to catch fire" The mind boggles when contemplating the future technology of crematoria but I think this could be just the TING. Rik |
Russell Eberhardt | 25/10/2021 19:17:09 |
![]() 2736 forum posts 86 photos | Posted by Andrew Johnston on 25/10/2021 16:51:22:
Technically it's neither, the white insulator is beryllium oxide. Beryllium is a greyish metal. Both are toxic if dust is inhaled. Splinters can get under the skin and can be absorbed by the body. Nasty stuff, we had strict rules for handling it when I worked with it at a research lab in the 70s. Russell |
Vic | 25/10/2021 20:00:05 |
3074 forum posts 8 photos | I’ve decided I can’t be bothered for just a couple of magnets. |
Phil Whitley | 25/10/2021 20:43:22 |
![]() 1443 forum posts 147 photos | Many small and very useful microswitches!
Phil Whitley | 25/10/2021 20:43:35 |
Mick Bailey | 26/10/2021 09:53:47 |
30 forum posts | There's usually some good high-temperature wiring with glass fibre/silicone insulation, as well as decent lengths of glass fibre screening. Also plenty of 6mm spade terminal insulation boots. I've used these for vehicle restoration projects where high temperature resistance is needed for wiring. |
