chris bale 1 | 23/10/2021 10:16:42 |
10 forum posts 9 photos | I'm after a bit of info if anyone has one, i need a few dimensions from the gear fork of a little drummond, to help get this lathe running again, my intension is to make a 3d printed version as a mock up to prove, then maybe make a 2part piece from 2 bits of ali, round stock and a bit of plate. Made a quick sketch on freecad. Proberbly a bit much but here is hoping, thanks in advance. I need: the angle between the forks the length of the slots A rough distance of the start of the slots from the center of the fixing boss The distance of where the shoulder bolt/gear bolts are in relation to its mounting boss machined face on lathe bed. Seems to be inline with the recess around the boss. |
Ady1 | 23/10/2021 11:00:48 |
![]() 5180 forum posts 738 photos | Is it the banjo you mean? (Perhaps a mod would change the title) |
Martin Kyte | 23/10/2021 11:06:52 |
![]() 2801 forum posts 53 photos | If it's a roundbed I could perhapse help. I do have one in bit's. regards Martin |
Michael Gilligan | 23/10/2021 11:14:48 |
![]() 20289 forum posts 1064 photos | Posted by Martin Kyte on 23/10/2021 11:06:52:
If it's a roundbed … . From Chris’s album photos … it would appear not MichaelG. |
DiogenesII | 23/10/2021 11:16:51 |
589 forum posts 234 photos | Think this is for the OP's Type B? Er, Ady, (and others?), do you think the M type (or any other Drmd. fitment) might be the same? Edited By DiogenesII on 23/10/2021 11:17:39 Edited By DiogenesII on 23/10/2021 11:20:41 |
Ady1 | 23/10/2021 13:11:42 |
![]() 5180 forum posts 738 photos | My answer is probably but needs to be checked My lathe boss is 1.75" outer diameter |
chris bale 1 | 23/10/2021 15:02:33 |
10 forum posts 9 photos | Yes the banjo, last photos didn't upload so reuploaded. Its the one with the screw feed at the front, still unsure of the model |
Lee Rogers | 23/10/2021 16:10:44 |
![]() 176 forum posts | Posted by DiogenesII on 23/10/2021 11:16:51:
Think this is for the OP's Type B? Er, Ady, (and others?), do you think the M type (or any other Drmd. fitment) might be the same? Edited By DiogenesII on 23/10/2021 11:17:39 Edited By DiogenesII on 23/10/2021 11:20:41 Round bed Pre B, Btype and M are all different. Your best bet is to keep an eye out for a donor lathe . This is how I ended up with 6 1/2 B types but in the end it is an economical way of stocking up on spares . theres a healthy market for anything you don't need. |
Lee Rogers | 23/10/2021 16:11:02 |
Think this is for the OP's Type B? Er, Ady, (and others?), do you think the M type (or any other Drmd. fitment) might be the same? Edited By DiogenesII on 23/10/2021 11:17:39 Edited By DiogenesII on 23/10/2021 11:20:41 Round bed , Pre B, Btype and M are all different. Your best bet is to keep an eye out for a donor lathe . This is how I ended up with 6 1/2 B types but in the end it is an economical way of stocking up on spares . theres a healthy market for anything you don't need. |
DiogenesII | 24/10/2021 18:33:17 |
589 forum posts 234 photos | Chris, if you haven't seen this page, it's worth a look in detail, particularly the photo about 3/4 of the way down whose caption begins 'Instead of a single slot L-shaped...' & which shows a compound reduction train for fine feed, which is likley to take up as much 'banjo-room' as you are likely to need - it's common to put one's largest wheel on the leadscrew, leaving the next largest pair and the next smallest pair to be compounded into two sets to fill the gap between the spindle and that - as the 'top' pair will be on the 'main leg' of your banjo, the length and angle of the lower slot will constrained quite narrowly by the need to mesh these to the leadscrew gear.. It's a rather complicated thing to describe, I hope the pictures help explain it better.. I notice that the ends of the banjo are shown in the picture, you may be able to approximate the lengths and angle by experimenting with cardboard templates or by drawing them up.. |
