Locomotive boiler wrap
Michael Callaghan22/10/2021 14:18:32
16 forum posts
Hi, what is the best way to mark out locomotive boiler wrap. With the price of even thin brass sheet now at very high prices I need to know the best way to make out the boiler wrap so I get the holes etc in the right places. I don’t think using paper would work as it tends not to keep a good shape. Thanks
Clive Brown 122/10/2021 15:05:00
723 forum posts
34 photos
I've used good quality thin card, obtainable from craft shops. Plasticard styrene sheet is also useful. Pieces of either can be stuck together with Sellotape and held around the boiler with string or elastic bands.
Michael Callaghan22/10/2021 16:31:56
16 forum posts
Good idea Clive. Thanks
Baz22/10/2021 17:24:27
609 forum posts
Empty cereal boxes are useful for templates and are basically free!
Speedy Builder522/10/2021 17:34:04
2454 forum posts
196 photos
If you use thin Clear celluloid , you can see what is happening underneath !
Michael Callaghan22/10/2021 17:54:26
16 forum posts
All good ideas, I just found that the Amazon small parts envelope works very well. However I have a second question. I have lots of .9mm sheet aluminium, will that be ok to use. Thanks again
Chris Gunn22/10/2021 21:28:21
404 forum posts
27 photos
Michael, plus 1 for plasticard templates.
I would not use aluminium, as you will have a job to get the paint to stick.
Steel would be my choice of material.
Chris Gunn
Michael Callaghan22/10/2021 21:39:05
16 forum posts
Hi, I am ok with getting paint to stick to aluminium there are a few very good etch primers to aluminium these days.
Baz22/10/2021 22:29:42
609 forum posts
Michael if you can get paint to stick to ally I would go for it, especially if you already have plenty of it.
duncan webster22/10/2021 23:40:59
3597 forum posts
66 photos
Isn't ally more likely to get dents? Don't forget to allow for the cladding when making your templates. I think cork sheet is as good as anything.
Michael Callaghan23/10/2021 08:48:14
16 forum posts
Hi Baz, I have made a few items with aluminium over the years and found that with all things to do with paint, good prep and good materials are the way to go. DUncan I have used fire blanket for the cladding and that’s in place. Ally dents no more or less then thin brass. I would like to use brass to be honest, but I have sheets of aluminium doing nothing.
rapid Direct
JD Metals
walker midge
