Joining 20g brass
How to solder a small component to a large brass sheet
Alan Marshall 118/10/2021 16:03:36
11 forum posts
The sole plate of my loco tender is 20g brass sheet. It is 26" x 9 1/2".
There are eight wheel splashers to be soldered in place the splashers being 20g and 2 1/8" long by 9/32" high in 7/8" wide slots in the sole plate.
Now the heat needed to solder (at 180 degrees) causes the sole plate to bow when using a large soldering iron (1/2" tip) which means the splasher plate cannot adhere to the sole plate in a level plane. The same occurs if I use a gas torch (naturally so).
An advice on how to make a sucessful joint would be appreciated.
Michael Gilligan18/10/2021 16:09:28
20289 forum posts
1064 photos
Have you considered ‘Resistance Soldering’ ?
’American Beauty’ [ yes, really ] makes some useful looking tools, and has several instructional videos:
https://americanbeautytools.com/Resistance-Soldering
Clive Brown 118/10/2021 16:14:19
862 forum posts
47 photos
Could they be lightly riveted and aso glued with epoxy resin, assuming the sole-plate forms part of the water tank?
I've successfuly used epoxy to seal tanks. If slightly warmed, it runs very freely into gaps.
duncan webster18/10/2021 16:29:21
4105 forum posts
66 photos
Someone many years ago in ME described constructing a tender using rivets and epoxy.
JasonB18/10/2021 16:29:41
23022 forum posts
2763 photos
Clamp a limp of metal to the sole plate to act as a heat sink then only the bit you want should get warm and the rest stay cool and not warp. Tin both parts so you have minimal need for heat.
Edited By JasonB on 18/10/2021 16:30:29
Alan Marshall 119/10/2021 11:24:29
11 forum posts
Thanks for the reponses.
I have a resistance soldering unit but it is not man enough to provide the heat required.
I prefer not to use epoxy if possible but it is not ruled out.
A big lump of metal as a heat sink made it more difficult to heat so I did not pursue it further.
I did however discover that if I used the soldering iron from inside the splasher components and the bits were adequately tinned I could get the solder to flow and make a join. This way I am not heating up the big mass of sole plate and letting the small bit get very hot and the heat transfer through the solder occurs. Its very fiddly as it needs the big iron. That worked for the splasher side plates OK. Getting the top of the splasher on I used a lower melting point solder (140 degrees) to try to avoid desoldering the sides and because it is curved the big iron was even more fiddly but evenyually it made the joint. So that was one done as a trial to get the method. Just another7 to do.
Rapid RC
Dreweatts
