John Billard 1 | 18/10/2021 15:14:54 |
108 forum posts | All the references I have seen advise that a front tube plate should be driven into the boiler shell before soldering. What about the capillary gap? Do we rely on the boiler shell expanding? John B
Clive Brown 1 | 18/10/2021 15:55:24 |
807 forum posts 39 photos | The shell expansion would presumaby be matched by the tube-plate expanding a similar amount. I haven't seen provision of a gap as an issue in boilers I've made. More like getting the tube-plate a reasonably close fit in the shell. If a capillary gap was seen to be needed then filing a very shallow taper around the tube-plate flange would suffice in my view. |
John Billard 1 | 18/10/2021 20:29:21 |
108 forum posts | Thanks Clive. Presumably the tube plate is sealed by a fillet of solder. In any case I accept that if there was a gap it would be difficult to maintain it. Kind regards John B
noel shelley | 18/10/2021 20:48:27 |
1281 forum posts 21 photos | Not sure of the wisdom of a drive fit ? If heating is correct then the capilliary and surface tension will pull the tube plate into the centre and maintain an equal gap all round, all be it only may be 3 or 4 thou. The harder part is to hold the tube plate in place in the shell, there are many ways. If the soldering is sound there will be a very small fillet, the joint will be filled by solder and therefore steam tight. Good luck Noel. |
Grindstone Cowboy | 18/10/2021 21:18:32 |
854 forum posts 64 photos | Never built a boiler myself, but have been following the Blondihacks Youtube series on making a vertical boiler. She made the tube plate a loose fit and used pins to hold it in place whilst soldering - for example here. Rob |
fizzy | 18/10/2021 21:31:36 |
![]() 1841 forum posts 120 photos | Yes, maintain a slight interferance fit. There will be plenty of so called gap for the solder to penetrate the joint. Whatever you do dont try to manufacture a gap. How can I be sure of this? I make boilers for a living and have never had a joint faiulre - ever (having made hundreds of them). Anyone wanting to learn is very welcome to come visit me as Pendle Steam Boilers in sunny Burnley. |
John Billard 1 | 18/10/2021 21:32:03 |
108 forum posts | Thanks Noel You are quite right about a drive fit. What if it goes in awry and how do you retrieve it without damage? Thanks Rob The Blondihacks viewing is compulsory particularly as she is so honest about how it went wrong. John B
John Billard 1 | 19/10/2021 12:59:29 |
108 forum posts | Thanks Fizzy, for sharing your experience. Thanks for the invitation! I am near Reading, but if I the the chance.... John B |
fizzy | 19/10/2021 14:01:43 |
![]() 1841 forum posts 120 photos | No problem John. If you want any one to one advice feel free to contact me via my website **LINK** |
John Billard 1 | 19/10/2021 15:33:16 |
108 forum posts | Thanks Fizzy All going well so far, but you never know! Tubes soldered in to the firebox tube plate and firebox outer wrapper soldered to the barrel using 424 and 430. John
Speedy Builder5 | 19/10/2021 16:43:54 |
2592 forum posts 207 photos | Nice video Blondihacks. Question: What is the black flux she was using. I have seen White, pink, but never black. Bob |
Grindstone Cowboy | 19/10/2021 16:57:22 |
854 forum posts 64 photos | The flux is Stay-Silv Black by Harris Products apparently - I found their website here. Don't know if it's available in the UK though. She mentions it contains boron to extend the temperature range. Links to https://www.harrisproductsgroup.com/en/Products/Alloys/Brazing/Fluxes/Stay-Silv-Black-Flux.aspx Rob |
fizzy | 19/10/2021 17:33:55 |
![]() 1841 forum posts 120 photos | The flux is available from the cup twins... I use it as a base and mix other fluxes with it to get the grade I like. It lasts a very long time and goes a very long way. Regarding the video - putting my neck on the tracks here but it is a video of how not to solder a boiler. Follow it at your perril - nuff said. Think Eutectic. |
John Billard 1 | 19/10/2021 17:58:34 |
108 forum posts | Yes, this what I am using. Very impressive. As Fizzy says lasts a long time under the torch at high temp for the 424. Regarding Blondihacks yes plenty of errors there but she admits them. Cheers John B
Bill Phinn | 19/10/2021 21:21:07 |
732 forum posts 103 photos | Posted by fizzy on 19/10/2021 17:33:55:
The flux is available from the cup twins... Please could you provide a link for the flux. |
fizzy | 19/10/2021 21:31:34 |
![]() 1841 forum posts 120 photos | strangely its not on the cup website - but thats where i get mine from - I bulk order so dont go via the website |
Luker | 20/10/2021 07:20:07 |
![]() 160 forum posts 116 photos | Posted by fizzy on 19/10/2021 17:33:55:
Regarding the video - putting my neck on the tracks here but it is a video of how not to solder a boiler. Follow it at your perril - nuff said. Think Eutectic. Hi Fizzy, I watched the second video of Blondihacks and I thought the end result came out ok. I'm a little curious as to what you mean by eutectic? |
