john steel 1 | 15/10/2021 12:22:40 |
![]() 21 forum posts 12 photos |
Also the lathe wont traverse automatically both in cross slide and in thread mode I have tried ever thing with the levers but I can only use it by hand traverse left to right the clutch wheel only moves slightly to right and left, Before I strip the apron down I just wondered if I was doing it wrong as I am a complete novice. Thank You for any help. |
William Chitham | 15/10/2021 13:07:56 |
139 forum posts 57 photos | That's a Model A, looks nice. There should be a serial number on the right hand end of the bed where the tailstock is sitting in the photo. Have a look at lathes.co.uk for Boxford information, there is also a Boxford group on Facebook with lots of scanned documents and knowledge. William. |
Bill Davies 2 | 15/10/2021 13:14:37 |
278 forum posts 11 photos | Hi, John. Many years since I used one, however, engage the middle 'three position' lever in either of the outer positions? Then carefull tighten the star-shaped knob to engage the friction clutch. You should then get movement. You can only operate one axis at a time. Bill |
Csl55 | 15/10/2021 13:19:34 |
4 forum posts | hi it’s an AUD , motor in the base. i have one very similar. join the boxford lathe group on groups.io. you wi;; find the “know your lathe” manual can be downloaded. |
Bazyle | 15/10/2021 13:32:39 |
![]() 6300 forum posts 222 photos | It is an AUD. Tat is an Under Drive model A. Also use the search function on this site's main page to search for the hundreds of threads on the Boxford, Southbend, and Hercus. First the leadscrew must be turning which you will check while turning the chuck by hand. Then the chromed lever in the middle of the saddle must be in the middle position. Then the black handle on the right will be able to engage the half nuts (up) to enable threading - check still only under hand power. Then release that lever (down). There is an interlock between it and the chromed lever. The clutch does not affect this. Move the chrome lever up to select feed. You may need to jiggle it a bit to release the interlock. Now turning the chuck will cause the clutch star wheel to rotate. Don't forget the apron needs oil which has probably leaked out. If you do strip the apron there are two traps. The clutch central screw is a reverse thread. The grubscrew on the right side of the apron that should release the black lever has a second grubscrew deep down the hole. Read all the Boxford threads on the forum. Th above advice and more has been repeated many times. |
Clive Brown 1 | 15/10/2021 14:00:48 |
807 forum posts 39 photos | The Boxford handbook "Know Your Lathe" will tell you how to use it. A rather poor copy is here |
john steel 1 | 15/10/2021 14:14:00 |
![]() 21 forum posts 12 photos | Thank you for your very prompt replys I have tried all what you have all said and have watched all the videos and joined all the forums includind the boxford one, the half lever to the right have tried up for the threads and down. also moved the lever on top of the lathe but nothing works so I think there is some thing wrong Thanks again for all your replys. |
Yngvar F | 15/10/2021 14:54:48 |
72 forum posts 53 photos | Check the gear train The lever on the left must be in the up or down position. |
Yngvar F | 15/10/2021 15:00:26 |
72 forum posts 53 photos | |
Bazyle | 15/10/2021 15:46:15 |
![]() 6300 forum posts 222 photos | The lever on top of the lathe is for the backgear. If the electrics are ok and the chuck goes round under power you can go on to the next step, but do the tests without power, just rotate the chuck by hand to avoid breaking things. Does the leadscrew go round when you rotate the chuck? That's the long rod that goes all the way along the front. If not as Vngvar says have you tried the lever to the very left of the lathe. You need to move the machine so you can open the left cover and see what is going on under it. |
Richard Millington | 15/10/2021 21:40:00 |
64 forum posts 4 photos | Left cover; Move the white knobbed lever up or down, this is forward or reverse for the leadscrew. Looks like it is in neutral. |
Speedy Builder5 | 16/10/2021 08:13:53 |
2593 forum posts 208 photos | looks to me to be an ex schools lathe. At the left hand end of the lathe is a cover which has been locked shut to keep kids fingers out of the way. Remove the small bracket held by an Allen screw and open the cover. I think that you will find that the gear drive has been disconnected. Most covers/doors on the lathe have microswitches on them. When opened, the power to the lathe will be cut off and you will need to shut the door and re-start the lathe. (May also shut off when you select / change the top lever which engages back gear for slow revs) Ps back gear may be blocked off with an Allen screw - typical schools modification! You have one of the best small lathes - lucky lad to have picked it up. |
john steel 1 | 16/10/2021 08:39:47 |
![]() 21 forum posts 12 photos | It's a single phase as you can see by the double socket I fitted to the wall and I am only a novice where the Boxford is concerned, Enginerr and electrical wise well let's say I am OK, I have made some bushes and used the Boxford milling attachment that came with it already. Thanks for your input anyway.Today I am going to pull the lathe out and open the door on the left as I thik like you all say it's in there, I managed to slide the lathe in alone but I think my son will help pull it out as I'm 87. Thanks again for ALL your very kind replys |
Speedy Builder5 | 16/10/2021 08:44:16 |
2593 forum posts 208 photos | I am afraid that you may have to re-arrange things a bit. The left hand door swings wide open, and you will need to open it on occasion to change the odd gear or two to swap between metric and imperial screw cutting. Your wooden bench is somewhat in the way ! Bob |
john steel 1 | 16/10/2021 11:30:29 |
