Mick Bailey | 14/10/2021 13:15:45 |
25 forum posts | For anyone who isn't familiar with this type of cutter it uses a tungsten-carbide single point tool that machines out the seat at the appropriate angle. It behaves like a lathe tool - in reality creating a spiral cut. It's remarkably versatile in that DIY cutters can easily be made. Last year I rebuilt a Honda CB450 head and made up the required tool by brazing a tip to a piece of tool steel. Unlike most cutters that only use a pilot to loctate a cutter head in the valve guide, this uses an additional outboard support clamped to the head for rigidity and precision. Any number of seat angles can be cut - I used a 3-angle cut on the Honda. The question I have is that I would like a PDF copy of the original instruction manual that came with the set. Mine is missing and I know there are many setups illustrated for different applications. It's perhaps an early 60s Mk1 set in a wooden case.
steamdave | 14/10/2021 15:36:25 |
510 forum posts 44 photos | I had never heard of a Ludwig Hunger valve seat cutter before, so did a quick search and I found out the company is still in business. https://www.ludwig-hunger.de/index.php/eng/Products/Automotive/Counterboring-valve-seat-ring-bores Maybe worth contacting them. Dave |
Mick Bailey | 14/10/2021 16:58:42 |
25 forum posts | Thanks Dave. I contacted them a while back and they sent me a link to the latest version, which I already had. This doesn't have the contemporary vehicle specific instructions - mainly for aircooled VW and other applications. Also, there are different accessories and fixtures that are no longer shown in the newer instructions (mainly because its all obsolete). I also posted on the Samba forum and had a reply from an owner who had an original manual and he said he'd scan and email it but never did. His account is no longer active. I can use the cutter set without issue, but would like to get the manual to go with it anyhow. |
Oily Rag | 14/10/2021 21:53:35 |
![]() 540 forum posts 184 photos | Mike, I have the remnants of a 'partial' set of Hunger seat cutting tools and there may be an instruction manual buried in the box with those remnants. I had it a long time ago and used it regularly, then someone borrowed it and when it came back I foolishly didn't check the contents! It went with a Hunger valve lathe that was a beautiful little thing, single point valve seat cutting at any angle desired. I'll dig it out the shed and look as soon as I get the chance. Martin |
Mick Bailey | 15/10/2021 09:31:38 |
25 forum posts | That would be great. I'd also be interested in the remnants if you wanted to sell what you have as my own set is incomplete.
Oily Rag | 15/10/2021 12:01:32 |
![]() 540 forum posts 184 photos | Mick, I'll dig it out and PM you as to what is there. Martin |
