Vic | 12/10/2021 11:46:28 |
3089 forum posts 16 photos | For the Wood Lathe.
Ian Parkin | 12/10/2021 12:05:00 |
![]() 1035 forum posts 243 photos | I have the one thats in your first link sold by boffin guy on eBay its great works well and I wouldn’t think making one any better is going to make it better to use…it does the job out of the box. And at the price he sells them for I wouldn’t go to the trouble of starting to make a copy. if you want a ball turning jig rather than making a ball turning jig that is |
Paul Lousick | 12/10/2021 12:05:14 |
2077 forum posts 727 photos | Hi Vic, It;s normally called a ball turner and there are lots of articles and designs on metal work forums, youtube, etc. (and the previous post to this one) |
Michael Gilligan | 12/10/2021 12:09:25 |
![]() 20289 forum posts 1064 photos | You may get some inspiration from this alternative design, Vic : **LINK** https://youtu.be/fmzD8wI8RIA MichaelG. |
Vic | 12/10/2021 16:10:19 |
3089 forum posts 16 photos | Thanks folks. I’ve actually got two ball turners already, one for the metal lathe and one similar to the one Michael linked for my wood lathe. Having used a ball turner there are however a couple of small things I don’t like which I think I can easily improve upon. |
Sam Stones | 12/10/2021 19:59:39 |
![]() 880 forum posts 326 photos | Vic, FWIW - I have a faint idea that this one was described in Model Engineer many years ago, perhaps in the 60's. A round cutter (e.g. a piece of broken drill bit) is inserted into the left hand end and pokes out as per the illustrations in the links above. Other than making a couple of stainless steel handles (for a six-way turret and a rear tool post, oh and an aluminium ball on the end of the handle which I carelessly cropped off in the photograph), I hardly ever used it. Capacity? About 50 mm max. One extravagance was the bronze body, a left-over from another job. The bronze body was made to be clamped in the normal (ML7) tool post. I seem to recall making the lead screw with a 40 tpi thread. It allowed very fine adjustment. Cheers, Sam Edited By Sam Stones on 12/10/2021 20:01:28 |
Vic | 12/10/2021 20:03:30 |
3089 forum posts 16 photos | Thanks. I did see that one during a search. I’ll be using a round carbide insert for the cutter as it works so well on my other jig. I’m looking to turn wooden spheres up to about 250mm diameter. |
Paul Lousick | 12/10/2021 22:06:47 |
2077 forum posts 727 photos | Sam, It looks like an earlier version of the ball turners that use a boring head. (Possibly where the designer got the idea) |
Sam Stones | 12/10/2021 22:45:25 |
![]() 880 forum posts 326 photos | Yes Paul, very similar. As my memory mist clears slightly, I feel sure it was described with drawings in ME. That would have to be pre '72. When I made it I'm not sure. Late 60's or early 70's. It went out with my ML7 and most other stuff in '07. Cheers, Sam From a still chilly Melbourne.
