Dave Breeze | 03/10/2021 14:39:25 |
5 forum posts | Does anyone know of a design for a vertical boiler about 6" dia and preferably top-firing?
I'm building an own-design model of a Sentinel shunting loco in 7.25" gauge.
Dave. |
noel shelley | 03/10/2021 14:59:20 |
1281 forum posts 21 photos | Reeves do or did a 6" vertical boiler design, but bottom firing. Noel |
Brian Baker 1 | 03/10/2021 15:10:24 |
![]() 194 forum posts 36 photos | greetings Dave, have a look at K N Harris's book "Model Boilers and Boilermaking", which has several designs for vertical boilers, and I think Martin Evans did one designed for injector testing. published in ME, a while ago. Regards Brian B |
noel shelley | 03/10/2021 16:42:20 |
1281 forum posts 21 photos | It might be worth looking up the steam tractor designed by John Haining and published in ME back in the 90s.. Verticle boiler but not sure of the firing. Noel. |
Howard Lewis | 03/10/2021 16:49:05 |
6013 forum posts 14 photos | Could you produce a smaller version, suitably modified, of the Sentinel boiler? It was reckoned to be a very effective and efficient steam raiser. The original design was intended to provide ease of maintenance. Howard |
Dave Breeze | 03/10/2021 18:58:19 |
5 forum posts | Thanks for the suggestions. There is a 5" gauge Sentinel design called Sirena in Model Engineer in the early 60's, so I could scale that up, but I guess I'm looking for something requiring minimal modification as the boiler tester I'd have to work with never seems keen on any sort of changes to boiler designs. There's also the boiler of the 2" scale Clayton wagon design. In theory my loco is about 2" scale too, but the Clayton boiler seems very small compared to the loco.
Dave. |
Durhambuilder | 03/10/2021 21:25:26 |
72 forum posts 5 photos | There is the 3” Ray Prime Atkinson waggon as supplied by Reeves which would be a fair bit larger than the 2” Clayton, don’t think it top fired though. |
noel shelley | 03/10/2021 22:32:13 |
1281 forum posts 21 photos | The calculations for a boiler are fairly easy and if your boiler inspector is not willing to accept nornal practice I would consider joining a club where the inspector is properly able to fill his role - and understands it ! I also had a boiler inspector who thought he knew better than published designes - I left the club ! Noel |
