Unwanted Taper
Steve35502/10/2021 20:08:54
135 forum posts
92 photos
Another newbie thread - sorry!
I am trying to turn a 2” long brass  cylinder to 0.5” diameter, at the same time I’ve been trying to follow Harold’s lathe adjustment instructions on his website.
I am finding I am getting an unwanted taper of about 0.008 across 2”.
1) I have used a level to check the ways for twist and it seems minimal.
2) The gibs all seem tight
3) I added tail support (I was getting 0.015 before I did that). I realigned the tailstock when I did that.
can anyone please suggest the most likely thing to check or recheck?
A few pics below.
thanks
Steve
Edited By Steve355 on 02/10/2021 20:09:35
Andrew Johnston02/10/2021 20:40:55
6316 forum posts
677 photos
What sort of level? If you're going to use a level it needs to be an engineers precision level; DIY levels aren't even close.
There are methods of correcting tapers that don't need levels, but I'll leave those to others to explain as I've never needed to use them. To start with don't try and machine/measure with the tailstock in place. It simply creates two variables (bed and tailstock) to adjust but only one measurement. So it's doomed to failure.
fizzy02/10/2021 20:45:08
1824 forum posts
120 photos
thats a lot so im guessing your tail stock is not correctly dialed in. If I ever get taper it is always my tailstock alignment which it to blame.
Steve35502/10/2021 20:47:23
135 forum posts
92 photos
Posted by Andrew Johnston on 02/10/2021 20:40:55:
Andrew Johnston02/10/2021 20:58:23
6316 forum posts
677 photos
Doesn't look like a precision level; I'd expect to see a number of graduations? What is it's sensitivity? For example on my engineers level one division equates to 0.0005" (half a thou) in 10".
Michael Gilligan02/10/2021 21:04:10
19266 forum posts
959 photos
That’s a neat looking little level, Steve … but have you checked its sensitivity ?
At that length: If you want to ‘level’ the lathe with it, a piece of cigarette paper needs cause a visible movement of the bubble.
Edit: Andrew [predictably enough] beat me to it.
Edited By Michael Gilligan on 02/10/2021 21:05:31
Steve35502/10/2021 21:09:07
135 forum posts
92 photos
Posted by Michael Gilligan on 02/10/2021 21:04:10:
Obviously it’s an eBay special, but I had to try to find a small one as the lathe is only tiny, I don’t have much info on it other than it’s a Starrett. I will check it with the smallest feeler gauge I can find and see what it does.
Pete Rimmer02/10/2021 21:10:42
1094 forum posts
69 photos
Put the mag base for the dial gauge on the front of the saddle and do your measurement again. That way the dial gauge will be following the path of the tool and should read zero all the way.
That gauge setup is a poor way to check for taper if that's what you're doing Steve. You should be using a micrometer to take measurements at each end of your cylinder. The dial gauge reading can be affected by twist or wear in the bedway.
Clive Brown 102/10/2021 21:12:42
720 forum posts
34 photos
Surely that's not the way to use a level, even if it's a good one? It should be across the ways
I'd advise Steve to set his lathe up to turn parallel by adjusting the mounting feet. Then adjust thr tailstock after that.
Also agree with above. The dial indicator might well not be showing anything useful.
Edited By Clive Brown 1 on 02/10/2021 21:15:16
Steve35502/10/2021 21:16:59
135 forum posts
92 photos
Posted by Clive Brown 1 on 02/10/2021 21:12:42:
Surely that's not the way to usea level, even if it's a good one? It should be across the ways
According to Harold’s website I should measure along and across the ways. Across the ways gave an imperceptible difference, there is a tiny difference along the ways so those are the pics I took. I’m used to winding sticks on wood so across is where I went naturally, I was surprised about the longitudinal measurement too.
Steve35502/10/2021 21:18:56
135 forum posts
92 photos
Posted by Pete Rimmer on 02/10/2021 21:10:42:
i measured it with the micrometer and got exactly the same result, but it’s easier to show on a picture with the dial gauge. But I will try what you suggest,thanks.
Michael Gilligan02/10/2021 21:39:29
19266 forum posts
959 photos
If it’s any help … I found this statement which presumably originates with Starrett:
Starrett improved machinist level series is a truly American product that is available in varying lengths of 4/6/8/12 inches. The company offers five different models under this series each having a long graduated spirit level that has a sensitivity of 0.42 millimeters/meter or 0.005 inches/foot or 80-90 seconds of arc.
Given that your vial is not graduated, I have to assume that it comes from another range.
Maybe inferior, or maybe just earlier … but certainly worth checking the sensitivity.
Clive Brown 102/10/2021 21:45:30
720 forum posts
34 photos
Steve, levelling along the length of the lathe bed is of no real consequence. Across the bed should give identical readings at either end, but I doubt if your level is sensitive enough to really set the lathe up well.
The real test is to take a very light cut along, say, 2-3" of bar held in the chuck and shim the lathe feet to give parallel turning. A tedious job but light lathes have surprisingly flexible beds. Thr bench should be sturdy of course.
Steve35502/10/2021 22:06:57
135 forum posts
92 photos
Ok, just had a close look at it, it isn’t a Starrett but a Rabone. That makes more sense,
here is a 0.004 feeler gauge under one end. I would imagine that makes it sensitive enough to be useful?
Steve35502/10/2021 22:17:10
135 forum posts
92 photos
Posted by Steve355 on 02/10/2021 21:18:56:
i measured it with the micrometer and got , but it’s easier to show on a picture with the dial gauge. But I will try what you suggest,thanks.
Ok, you are right, it’s all me. I did that and it’s very close to parallel - about 1 thou out. I checked again with the micrometer and got the about .5 thou. Luckily this is the “beginners” forum so I am allowed to be an idiot.
Why did it give me an incorrect reading on the other side then?
Michael Gilligan02/10/2021 22:28:31
19266 forum posts
959 photos
Posted by Steve355 on 02/10/2021 22:06:57:
I agree … so that’s one ticked-off the list yes
Steve35502/10/2021 22:28:32
135 forum posts
92 photos
Posted by Clive Brown 1 on 02/10/2021 21:45:30:
I will give that a go once I’ve finished the current thing, thanks.
Andrew Johnston02/10/2021 22:34:52
6316 forum posts
677 photos
Not really, it needs to be more than an order of magnitude more sensitive, along with multiple graduations.
Pete Rimmer03/10/2021 10:12:02
1094 forum posts
69 photos
Posted by Steve355 on 02/10/2021 22:17:10:
Hard to describe in words coherently but easy enough to show.
Your dial is not actually measuring taper as such, I mean it MIGHT be or there might be a taper when it's showing no movement. To measure taper with a dial you'd use a comparator stand.
With the dial on the front and mounted on the saddle it is following the same path that the tool took when it did the cutting. It should therefore give the same reading all along the length. If there is any wear or twist in the bed then where the tool was caused to move away from the centreline of the part, so would the dial point. It would show no change.
With the dial on the opposite side of the part if there was wear or twist causing the tool to move away from the centreline of the part then the same wear or twist would cause the dial to move TOWARDS the centreline which would give a rising reading.
SillyOldDuffer03/10/2021 10:16:07
7681 forum posts
1694 photos
To be explicit, an ordinary bubble level won't cut the mustard. They're good for putting up shelves and most other purposes but aren't sensitive enough to detect a twisted lathe bed.
You need an Engineers aka Machine Level. They are made to detect tiny deviations from level, as required to set a lathe accurate to a thou or two over several inches. Typically, in a new installation the lathe stand is set up with an ordinary level first, and then the lathe is tested. If not cutting straight a Machine level is used to check for bed twist, which can be corrected by shimming a foot: some machines have screw-adjustable feet.
This example is made by Dasqua and sold by RDG.
In theory new lathes are confirmed to cut straight on a true level surface in the factory, so plonking them down on any decently stiff flat surface should be good enough. In practice, don't expect too much of inexpensive hobby or elderly lathes. Note flat rather than level. It's not necessary for lathes to be level provided the bed is straight: they work perfectly well in storm tossed ships. Levelling is just one way of eliminating twist, and a bent stand is one way of accidentally twisting a machine.
In my book Machine Levels aren't good value for money. Pricey and much too sensitive for ordinary work. Fussy and the bubble takes an age to settle. Good for anyone installing lots of machines, dubious for putting one into a shed! After being used once to set-up the owners lathe, I suspect most Machine Levels end up in a cupboard. As an alternative, Rollie's Dad's Method takes longer and is more complicated to do than detwisting with a good level, but it requires no special equipment.
A word of warning: high-precision measuring is so difficult it's quite easy to lead oneself up the garden path into a deep maze of confusion. A wobbly DTI moving on a slide will cause trouble. When measuring into the 0.02mm / 0.001" region don't rush to adjust anything based on amateur measurements: they're likely to be flawed because taking them properly is a skill you don't have!!! Therefore, keep measuring simple and use the right tools: detect taper with a micrometer, not a DTI. Check everything - it may take several hours practice to get a micrometer to repeatedly read the diameter of a precision rod consistently. Positioning the micrometer correctly is important, and so it applying the same pressure to the screw every time. The ratchet helps, but trained craftsmen rarely use it; they develop a 'feel'. Some are better than others, so find out how good you are by practising. In the meantime, don't jump to conclusions!
rapid Direct
JD Metals
walker midge
